Connecting W7 and W...
[Closed] Connecting W7 and W8.1 PCs to one homegroup or just sharing files
I've recently got a Linx 7 tablet which runs W8.1 and for £60 is frankly brilliant.
The one issue I've run into is with trying to access files (eg video files) on my W7 PC which is the media PC. I can see the W7 PC on the network from the tablet but I can't access it. I was previously able to access files on it from a (no longer used) W7 laptop so I'm fairly sure that the sharing settings are right though I can't be certain that they still are (I've since installed plex on the W7 PC and that may have changed the sharing settings I can imagine).
I noted that I can't get the tablet to connect to the homegroup of the W7 PC - I only get an option to create a new homegroup rather than join the existing one.
Given that, I've also tried connecting directly (eg \\W7PC\drive\etc ) as I've done before and that asks for logon credentials which don't work with details for either the W7 PC or the tablet. I note that the credentials state that I'm on a domain named the same as the tablet name.
Any suggestions? Much appreciation in advance 🙂
Posted : 07/01/2015 11:29 am
lunchtime bump
Posted : 07/01/2015 12:36 pm
That's just a naming convention. If you're on a domain it'll be DOMAIN\username (or username@domain.whatever), if you aren't it'll be MACHINENAME\username etc.
I don't know much about Homegroups, never used them in anger. Wouldn't surprise me if you could join a W7 machine to a W8 homegroup but not the other way around though, might be worth trying that?
Posted : 07/01/2015 12:45 pm
Good point though the documentation from MS suggests you can do it either way.
Maybe I'm better off just trying to get network shares working and go that way as I know that the different PCs can actually see eachother.
Posted : 07/01/2015 1:09 pm
It does work. I've got a Win 7 machine as a HTPC/media server and a Win 8 desktop and Win 8.1 tablet reading from it.
If I remember rightly you need to go in to the sharing settings for folders and add an 'everyone' user.
As for homegroups, I couldn't get it to work for a while - turned out it was the clocks. They all need to be synchronised to the same clock service.
Posted : 07/01/2015 2:02 pm
Ah, maybe that everyone user is what I'm missing. The clocks all appear the same though I haven't checked on specific sync settings.
Posted : 07/01/2015 2:06 pm
