Connecting freesat ...
[Closed] Connecting freesat to sky dish
I've done a search and I know it is possible - but how??
I presume I can use the existing cables, but the ends of the cable do not appear to be compatible with the back of the Humax box:
Looks like I need a male and a female standard aerial connection to recieve 2 channels at the same time. Is it a simple case of cutting off the sky ones and fitting different ends onto the cables?
Anyone any experience of this and also, do I need to point my dish in another direction - thanks!
Posted : 27/11/2012 6:17 pm
Thats looks like a Youview box - for an aerial, not satellite.
You need a freesat box, just plug and play swap for sky / sky+. Same cables. No need to move dish.
#Edit: or a Freesat+ box for recording / pausing etc.
Posted : 27/11/2012 6:21 pm
As above, that's a Freeview box with Belling Lee Coax connectors
Posted : 27/11/2012 6:26 pm
Freesat box just plugs straight into sky dish. Your pic looks like a terrestrial freeview box.
Posted : 27/11/2012 6:28 pm
Thanks - schoolboy error!
This looks better I think
๐Ÿ˜ณ
[EDIT: Have I got the right forum? No rude, cheeky comments!!!!]
Posted : 27/11/2012 6:29 pm
You mean this:
Foxsat HD 500gb
and yes your cables are compatible from the LMB etc.
Dont use the middle hole ๐Ÿ™‚
Posted : 27/11/2012 6:31 pm
Sowhat won't fit then?
The cables from the dish should have F type connectors on them
Posted : 27/11/2012 6:33 pm
You can't just split satellite cables like aerial cables btw, you need two seperate feeds coming from the dish (which you've probably got if you had sky)
Posted : 27/11/2012 6:37 pm
All sorted folks - I was looking at the freeview not freesat ๐Ÿ™„
Posted : 27/11/2012 6:42 pm
Your user name has three superfluous letters ๐Ÿ˜‰ Only Kidding.
Posted : 27/11/2012 8:34 pm
๐Ÿ˜ฅ
Posted : 28/11/2012 3:29 pm
