Computer tech - SSD...
[Closed] Computer tech - SSD - Anyone tried one yet?
I'm rebuilding my desktop PC. All new components and I was thinking of installing a 64G SSD as the main drive for the OS/everyday programs with a 1TB drive as the data/lesser used program drive.
I reckon the SSD as the main drive will give me lightning fast boot up and every day use. I'll use my USB drive as a backup.
So has anyone used an SSD drive in the ir PC yet? I know they're massively quicker for normal program use, I've watched a few videos, I'm assuming they also boot up lightning quick too.
Any recommednations to which one?
Posted : 15/05/2009 3:03 pm
They're still quite expensive considering the speed they give vs a raid array.
Couple of Raptors in raid will do you fine.
Posted : 15/05/2009 4:14 pm
I've heard of people installing flash card readers and stuffing a big card in to use as the boot-up and application partition, with significant speed improvements. See no reason at all not to do what you're doing. My Powerbook only has an 80Gb h/drive, with a 500Gb external, so there's no real difference that I can see. Anyway, with the new SDXC card standard just announced, you'll soon be able to put a 2Tb card in and just shove everything onto that! :mrgreen:
Posted : 15/05/2009 9:47 pm
Visit www.IveGotTooMuchMoney.com for better advice on this subject.
Posted : 15/05/2009 9:51 pm
nah, I tried http://www.IworkinITandafastdesktopsimplyearnsmemoney.com which was much better.
Posted : 15/05/2009 11:37 pm
Problem with using flash memory for boot/programs is the fact that it'll keel over eventually, it is write-life-limited. Unless you set up one of the interesting read-only-boot systems on linux and make sure the swap partition is not on the mem card.
Posted : 15/05/2009 11:39 pm
Have you stole these from work?
Posted : 15/05/2009 11:47 pm
we've not got any in yet. I've stole lots of other stuff but not SSD's.
As above at some point, I've done a bit of research and it looks like I should wait for things to settle down a bit. We'll see a few hard drive manufacturers with massive investment in their spinning disk creation infrastructure go under, maybe even some of the big players and then a whole load of very cheap SSD devices will become available with ultra high speed and capacity.
Looks like computing is heading for a way big shakeup in the next couple of years. We have a massive disk array at work for storage. I reckon in two years it'd be cheaper to simpy ditch it and buy in 300TB of SSD which will go in one cabinet/shelf and just buy some more cards when things get close.
Posted : 15/05/2009 11:58 pm
