Computer Help Pleas...
[Closed] Computer Help Please Wifi cards
I have a hp lenova desktop that needs a pci wifi card but the one I have received the silver steel bracket on the back of the card is about 1-2 inches to long can someone point me in the right direction to the correct one please
Posted : 16/02/2016 8:39 pm
Do you need it to be a card? Just get a usb one. Pretty universal and very cheap. In the old days when pc bits were expensive I have cut and bent the bracket to fit.
Posted : 16/02/2016 9:41 pm
It's a small (smaller than a standard atx case, I'll guess micro atx standard) case on your pc I'm guessing.. So you'll need a low profile card and bracket.
Asuming the card is low profile it should come (hopefully) with a long bracket that sounds like what you've got, and a short stubby bracket for smaller cases. If yes, you can swap the brackets over to the correct size, if not, you'll need to exchange the card for a low profile one with the shorter bracket.
Or just be ghetto and remove the bracket all together assuming the card fits inside the case ok.
Posted : 16/02/2016 9:42 pm
What he said. ^^
Posted : 16/02/2016 9:43 pm
I tend to prefer a proper card but I'm currently using a USB dongle that cost about £12..seems to work fine.. But on a small case you may well not want to use up spare usb slots.
Posted : 16/02/2016 9:45 pm
So what usb one would you recommend it for a computer in the garage so need to have good strength & speed
Posted : 16/02/2016 10:44 pm
If its in your garage, all WiFi will struggle.
Buy these:
http://www.argos.co.uk/beta/static/Product/partNumber/4273888.htm
Hook one up to your router, one up to the ethernet port on the garage PC. They plug into power outlets, and carry ethernet across them.
Posted : 16/02/2016 10:52 pm
Link doesn't work
Do the power things work?
Posted : 16/02/2016 11:40 pm
Don't know about the powerplugs but another alternative is a wifi extender and then a network cable between that and the PC. The advantage here is that you can then stick the wifi extender up somewhere high in the garage where you can get a good signal from the house.
Posted : 17/02/2016 8:34 am
The link seems to work ok for me rottweiler, but go to the Argos website and look for:
TP-LINK 500Mbps Nano Powerline - Twin Pack.
Product code:427/3888.
I'm dubious about WiFi and garages as it all depends on a)how far away from the house it is. Whereas powerline units generally work ok.
Posted : 17/02/2016 9:38 am
 xora
I have now used them in three different houses without an issue!
Posted : 17/02/2016 10:34 am
