Computer "forg...
[Closed] Computer "forgetting" DNS settings?
My computer started to go wrong a few months ago. I figured out that I could go to Internet protocol version 4 and reset it. Would have to reset it every time I switched on my computer. I downloaded windows 10 to see if it would cure it. Now it goes off every few mins. I can't find too much info about it. Watched some YouTube videos showing how to reset everything. Anyone else had this?
Posted : 25/08/2015 10:37 am
Can you describe the symptoms? "Go wrong" isn't very descriptive.
Ever done a malware scan on it?
Posted : 25/08/2015 10:40 am
Losing internet connectivity every few minutes could mean a lot of things, one being you need to do a winsock reset:
[url= https://iihelp.iinet.net.au/Resetting_Network_Adapter_%28Winsock_Reset%29 ]https://iihelp.iinet.net.au/Resetting_Network_Adapter_%28Winsock_Reset%29[/url]
It is an easy thing to try, and is benign if it doesn't resolve the problem. If it doesn't work then you'll need to give us far more information than "computer no worky" ๐Ÿ™‚
Posted : 25/08/2015 10:44 am
Well it just says website not found. I'm still connected though. I use kaspersky, do regular scans. Used to type in the DNS settings manually and then click on "apply this fix". Now click on find settings automatically as it's quicker.
Posted : 25/08/2015 10:47 am
I did winsock reset.
Posted : 25/08/2015 10:48 am
How are you connecting via wifi or wired ethernet ? DO you have anything else on the network, table, smartphone etc?
Posted : 25/08/2015 10:56 am
www.malwarebytes.org
Run this, decline the 'free trial'.
Posted : 25/08/2015 10:58 am
And if so, is it just one machine that's infected?
When it's affected, what does your DNS server address come up as? (Command prompt, type ipconfig /all and scroll back up to your network connector).
Posted : 25/08/2015 11:02 am
I'm not sure what I'm supposed to be looking for in all those numbers?
I ran that malware program and there is no difference, my computer is not infected.
It does the same thing whether I connect wire a cable or use it wireless. I've been resisting the temptation to attack my laptop but I ended up hitting it quite hard. It stopped and restarted. It will be going out of the window soon.
Posted : 25/08/2015 8:28 pm
 MSP
try
ipconfig /all | find "DNS"
to simplify the information you are looking through
Posted : 25/08/2015 8:58 pm
Ok, cheers, seems to be behaving itself after the severe reprimand.
Posted : 25/08/2015 9:02 pm
