Code scanner for ai...
[Closed] Code scanner for airbag light recommendations
4 Users
As above I have a 2014 citroen relay with airbag light on (no reason just appeared) and wonder if anyone has a recommendation for a scanner (up to £150) to check the codes (although reading online it sounds like I will have to send it to crashdata for a reset). Also have an Octavia (2020) so if it compatible with that then all the better.
Posted : 18/02/2022 12:32 pm
I used Torque Lite phone app and an "under a tenner" bluetooth thing, that plugged into the OBD2 port, off ebay.
Reset the emissions light, I actually needed more oil in the engine according to the fault code.
On another Citroen - C1
Edit: Also used the same kit on a Nissan Note to reset the DPF fault a few times
Edit 2: Same sort of thing as  THIS
Posted : 18/02/2022 1:41 pm
CheersI have them they are only really engine specific even with torque pro, it needs to do airbags.
Posted : 18/02/2022 1:54 pm
Many cheap ones won't sort airbag lights, even Carley can't do it. Model specific ones are often better unless you go for an all singing expensive one. For my Z4 i have a C310+ which was about £50 and does the lot. There might be something similar for your car.
Posted : 18/02/2022 1:57 pm
Air bag light very occasionally comes on in our old Golf - always seems to be a connector under one of the front seat needs a jiggle.
I think but cant be sure, the system resets once the connection is reseated, i.e. no code clearance needed (engine off/keys out).
Posted : 18/02/2022 2:51 pm
Usually airbag faults don't reset themselves, they need to be cleared with a reader.
Posted : 18/02/2022 2:56 pm
