Code/combination lo...
Code/combination lock for gate
8 Users
1 Reactions
In need of a new lock for the garden gate. It's 70mm thick and currently has a key lock that you turn and push to release the latch. It's a bit stiff and fiddly to use so ideally want a simple code/combination lock but not seen anything suitable for a 70mm thick door. Also nothing electric.
Any recommendations?
Posted : 23/07/2023 12:02 pm
Edit: re read the OP, my suggestion was just wrong
Posted : 23/07/2023 12:13 pm
There might be something from Lockinox but they are mostly for mounting inside a steel framed gate (and cost a fortune).
Screwfix has a lot of codelocks stuff.
I've recently fitted a key operated "locklatch deluxe" from Toolstation and they are very easy to use. The key works like a switch so turn one way until clicks then back to centre and remove key to leave it unlocked (but latched) and vice versa to lock.
Posted : 23/07/2023 12:37 pm
EDIT. ignore me.
Posted : 23/07/2023 1:12 pm
Oh, hang on, I may not have been so wrong after all. This is suitable for 70mm thick frames. We have one although a smaller (50mm) size. Really rate it but obviously its not what you've specified being a key lock. It would fit though....
https://www.toolstation.com/gatemate-euro-profile-long-throw-lock/p71612
Posted : 23/07/2023 1:17 pm
Stupid suggestion, any reason not to just have a normal latching handle and secure the gate with a simpler separate staple and hasp using a (combination) padlock?
The door doesn't sit flush with the post on the outside. Only on the inside. The door is 70mm bur the post is 180mm.
Posted : 23/07/2023 4:26 pm
Ignore the locklatch then. The latch mounts in the post rather than the gate, and I think the supplied actuation rods only allow up to 150mm (although suppose you could notch it 30mm into the front side of the post).
I presume a hasp and staple with code padlock also couldn't be accessed from both sides of the gate without a very big access hole.
Posted : 23/07/2023 4:37 pm
You could just recess the gate a bit with a router to fit a lock designed for a narrowed width.
Posted : 23/07/2023 4:40 pm
Is the existing lock actually rubbish, or is it just weathered/gunked up/needs good clean out?
Posted : 23/07/2023 4:44 pm
 gray
How about one of these:
https://metalines.com/gate-locks/603-gatemaster-digital-gatelock-surface-fixed-gate-lock-dglw.html
I'm considering something similar for a side gate that will be quite solid and tall, so padlock and hasp on one side wouldn't work too well, especially for the younger members of the household.
Posted : 23/07/2023 4:55 pm
Rust and corrosion mostly. Also I'd like to not need to carry a key when I go out.
Posted : 23/07/2023 5:50 pm
Also I’d like to not need to carry a key when I go out.
Key safe, I have one by the back gate, just lock all my keys in when I head out on a ride.
Posted : 23/07/2023 5:59 pm
