I just went to the garage and it is too cold to do anything so decided it is time to fit a heater. There seem to be a lot of little 'parking heaters' for motorhomes etc for £100-£150 which appear to be little more than a small diesel engine with the exhaust vented out the wall and a fan blowing air over the engine to heat it up and warm the room. Seems easy and lots of rave reviews on YouTube etc.
Anyone on STW got one or had any experiences?
Any recommendations of which ones to choose / avoid?
Before you do consider your carbon footprint, global warming, the ethics of buying stuff you don't really need that's travelled round world etc.
You've just depressed me, my son's future is ****ed and I understand his reluctance to have kids.
Edit: I'mm working outside in sub-zero temperatures today, the answer is wrap up warm and come in to have a coffee and type on STW now and then.
Yes, fitted one to my van about 2+ years ago during the conversion. New ones have a better thermostat but as a heater they are great. I only use it occasionally but it is very good. only problem is it gets too warm and has to be manually turned on and off, less of a problem when heating a much larger space I am sure.
This guy has really tested one I would recommend his channel.
I bought one in a case with a small fuel tank and took it to pieces to fit where I wanted it in my van which worked for me. You will need to replace all the hoses and clips for better quality ones...
Crikey, Edukator, a man’s gotta stay warm. Yeah, cheap electricity from renewable sources would be the best way to do this, but until global leadership get their shit together, people gonna do what’s affordable.
I’ve got one of those heaters; They kick out some heat and are reasonably economical, especially on kerosene or cherry. Noisy though, best to install them outside (weather protected) and run the hot air vent through the wall. Safer that way too, noxious gasses wise.
I’m sure you’ve done the YouTube trawl already, but in case you’ve missed him, this guy is pretty much the go to resource for everything Chinese diesel heater related.
I've had an Eberspacher* diesel heater in my van for 10 years - they're awesome.
Santa is bringing me a chinese one for the garage for christmas, I have high hopes. Unfortunately, everyone has had the same idea this year, and supplies are running low...
I suspect they all come from the same factory, but Vevor get consistantly good reviews (although they're an importer rather than manufacturer and they are out of stock of them all!)
*All the chinese heaters are a copy of these.
And people have the cheek to slag off the air-conditionned stadiums at the World Cup.
if you can’t see the difference between making a vast area cool enough to play (and have a huge crowd spectate) a cold weather sport in the desert and a chap trying to warm a work area up enough to be productive in a cold climate, then there’s not a lot of hope for you.
@Edukator
[i]Before you do consider your carbon footprint, global warming, the ethics of buying stuff you don’t really need that’s travelled round world etc.[i]
If I didn't need it, I wouldn't be buying it. I cannot work in sub-zero temperatures stop things like glue, varnish, paint, resin etc actually working.
[i]You’ve just depressed me, my son’s future is **** and I understand his reluctance to have kids.[/i]
I am amazed you decided to have children. Can you imagine the carbon footprint that you have inflicted on the planet? You really want to check you hypocrisy meter before those environmentally committed people who have chosen not to pollute the planet with further unnecessary people*.
[i]I’mm working outside in sub-zero temperatures today, the answer is wrap up warm and come in to have a coffee and type on STW now and then.[/i]
I assume your coffee is grown in your own back garden and you haven't "buying stuff you don’t really need that’s travelled round world etc."
@Everyone Else
Thanks - I will check out what Vevor have
*No criticism of your son intended. THe comment is largely tongue in cheek but you started it so ner-ner-na-ner-ner
your workshop isnt exactly off grid - I can see the point if those heaters for a camper if you're wild camping. Why do you want to go out and buy fuel and bring it home to fuel a heater when theres a socket right there you can plug a into? My local Sally Army charity shop is selling brand new fan heaters for £3 - you'd be running it for about 300 hours to cover just the purchase price of a diesel heater.
Air-con in a warm place to stay cool is exactly like heating a cold place to keep warm - using energy to change the temperature. The difference being you can wrap up to keep warm but once you're down to football kit you can't take more colothes off to stay cool.
I'd like to bet that the energy cost per spectator is lower than diesel heating a garage for one.
Heating tented terraces in front of cafés has been banned here.
No need to get personal and insulting my intelligence, think about it, how intelligent is a species green-housing itself into extinction?
Is it really going to work out better than a calor gas heater?
Propane and butane are also slightly lower CO2 per kWh.
For working out value one litre of diesel contains about 11kwh of heat. I don't know what the efficiency of those heaters will be but maybe only 60% as the need to push the exhaust out so one litre of diesel will give about 7 kWh of heat to your workshop.
At £1.80 per litre this is about 25p per kWh of heat.
That is going to need quite a long time to offset the cost vs a fan heater or second hand calor both of which will be nearly 100% efficient as they don't push heat out in the exhaust.
Butane in 7kg bottle is about 30p per kWh and about 25p in 15 kg from calor website prices. Unless you fancy fitting a new toy to the workshop whilst gaining more chilblains then I'd go fan heater or calor all the way.
NB other gas brands are available.
I did look at a calor gas heater but then would need buy one of those and the size and ability to locate the heater better made diesel easier.
I agree with the electric heater cost argument but I do have the idea of making the heater a portable fixing so I can take it elsewhere if needed. Also the possibility of a motorhome conversion has been mooted with MrsWCA and she only said "Over my dead body" so not totally rejected. I thought I might use this to see what it is like in case I want to use one in any motorhome conversions that may or may not happen in the future.
imagine just burning diesel to get warm.
How much of the price of diesel is just tax?
when there are so many alternatives: waste oil heaters (not in Scotland though), wood burning stoves, infra red heaters etc
So people would be looking at insulation first.
How big is this garage?
This guy reviews the Vevor heater, and makes a load of other diy heaters using different fuels and materials
Im making one (or two) so I can keep warm IF we get a load of power cuts, and make the heat supply better suited to my needs.
Also I have a large butane bottle in the shed so I need a little heaeter to use that up
But yeah, I dont know the current regs for veg oil or red, but biodiesel doesnt look that hard to make
The Chinese 5Kw gas heaters are good value, seem to work pretty reliably now, and come with a self contained kit including tank. The propex gas heaters and eberspacher diesel heaters are very good and probably more economical, but you pay for the name
whatever you do, don't buy a gas "space heater' - the one that produces a massive flame.... easiest way to empty a butane tank Ive ever seen apart from blowing it up.
[i]imagine just burning diesel to get warm.
How much of the price of diesel is just tax?[/i]
Garage is partially insulated with a ceiling or sorts attached to the rafters so there is an airgap above.
Diesel is not the only fuel. There are much 'greener' alternatives. This does depend on how you judge 'greeness' obviously but local burning, relatively efficiently of what would otherwise be waste could be considered better that the remote power generation with associated transmission inefficiencies.
Plus there is always to option to run it during power cuts etc - not that Putin and pals would ever try to squeeze the energy markets in Europe. It is only the weak Europeans on the mainland that are giving government warnings about potential power cuts and suggesting their population take measures to prepare. Here in the UK we are immune from such challenges as we voted BREXIT, remember.
Hugely popular this year as lots are buying them for their campers, many who live in them permanently. Keeping warm in your workshop seems sensible to me and they’re very efficient by all accounts.
@Edukator - think of the heating as saving NHS time and resources. If WCA can’t feel his fingers while working there’s more chance of him chopping something off! 🤣🤣🪚🖐
but Kerosene is about 75p/ltr at the moment, and they run beautifully on it. Als red is about £1.10/ltr.
I suspect your efficiency estimates may be a bit off too, although these heaters also need a permanent 12v feed with quite a high initial draw to heat the glow plug, so that needs to be taken into account too.
Unless it’s coffee. Then it’s fine. 😂 you couldn’t make it up 😃
It’s going to warm up this time next week. You could buy a fan heater and have heat in your workshop by lunchtime or you can buy a heater for a camper van you don’t own and have it up and running in time for spring
were half way through December and workshop heating has only just become an issue. Whatever you get you won’t use it a lot
What about an IR panel heater - just heat's you and uses significantly less energy, circa 300w. Do look carefully as some 'panel' heaters are the traditional type and use 2000w or more.
In principal you could run it on waste cooking oil and be (roughly) carbon neutral if you can find a chippie that'll sell it to you. Engine oil also works, but is illegal.
As above. You'll need a 12v supply too.
FWIW we have one in the campervan and it's great for heating that. There is a constant low-level hum from the fan. Uses very little diesel to warm up our wee van but that's also well insulated.
I reckon a small electric fan heater would be a better option if you have mains supply though.
I've just installed a cheap 8kw (actually outputs about 4-4.5kw) all in one to heat our garden office, only had it a week but first impressions are very good, I've positioned the unit outside and ran the heater duct into the building to minimise the noise, next step is to make an insulated box to reduce the noise externally.
I did worry a bit about the environmental impact but, in the grand scheme of things I'll use less diesel heating the office for 8 hours than I do driving into my 'actual' office and it has also given me the excuse to add solar to the office (to keep the car battery the heater runs from charged) which long term will be expanded to supply power for computers etc and the air con unit we use to keep cool in the summer.
I'm also going to get one for the garage/workshop to replace the propane space heater I currently use as they output dry heat, propane produces a lot of water which isn't seperate from the heat output like the diesel heaters so you get a lot of condensation and surface rust on tools.
I’d like to bet that the energy cost per spectator is lower than diesel heating a garage for one
The heaters run on an absolute dribble of fuel. About 100ml an hour. You could heat the garage for 10 hours for £1.80 at current prices
Do you know what happens to the waste engine oil that is collected from garages?
It is burnt.
If I was running a motor servicing business I know what would be heating the place in winter.
Or a couple of days....
As above. You’ll need a 12v supply too.
No. You can get 240v ones.
IR panel is what I’m looking at too. Kids’ school uses them, they work well and not intense like the patio heaters.
You get ones with led lighting integrated, just replace a light fitting on the ceiling.
There's a very busy FB group dedicated to these heaters which used to be almost entirely hashtag vanlife people. Now there's loads of people installing them in sheds, garages, conservatories etc.
I've never owned one yet but they do really pump out lots of hot air and they sip tiny amounts of fuel. Apparently they run beautifully on kerosene.
This is a useful page which gets updated regularly...www.vanlifeuksurvivorsguide.co.uk/post/tried-and-tested-diesel-heaters-3-0-2022-2023
I've had pre-chinese era diesel Eberspachers and gas Propex heaters in my campervan and work vans. They are a good choice where you have a limited 12v supply. I cannot see that they'd make any sense in a building with mains power.
You are paying tax and duty on diesel and having to collect it, and running it in a heater that is not 100% efficient and is not designed for long term operation (a few weeks a year is fine, hundreds of hours each winter is likely to cause reliability issues)
Electric heating is 100% efficient, is pretty close in price per kWh to diesel I'd have thought, so IR panel for instant heat on you, or oil filled rads for comfortable all day heating so you don't notice the fan heater (or Chinese diesel heater) cycling on and off and instantly making the room feel colder.
And...you can sign up to a green tariff if concerned about your carbon footprint
The joys of the northern climate workshop 😆
If you'd access to free timber i'd suggest a wood burning stove. Those are the traditional way to heat a workshop. But from you tube im seeing a lot of these heaters being installed and used to great effect so go for that.
They work well. Two winters for me in a detached single skin garage. Mines a van type, sits on a shelf I cobbled up land runs fine on “parrafin”. Dry heat as mentioned up there, keeps cast machine tools dry and rust free. I use a leisure battery on a ctek charger as it uses a fair amount of current initially running the glow plug as mentioned previously.
I put a “all in one type” ( looks like a large PC tower) in my dads garage and he is in there a lot as a model engineer and it works a treat.
The FB group has loads of info as they tend to arrive with a variety of control panels and remotes that can take a little sorting.
Do you think hectoring people in that pious self-righteous tone is going to change anybody’s mind? It almost makes me want to set the car idling for an hour or so to even out the karma for your pompous post.
Tinas, gobuchul, I thought you can get a license to run a waste oil heater.
Given this is wca, I'm surprised he's not welding up a few bits of pipe and an old gas bottle to make one.
I was given an old Calor gas heater recently. Love the thing. Instant toasty heat. Might be a good option for a workshop. Jury is still out on cost as I’ve only had it going a week.
The condensation caused by gas heaters was a consideration as I don't want rusty tools.
My experience or IR heaters is not good. If you are not stood in front of them you don't get warm, Paint, resin, glue etc doesn't warm up, all the tools are still freezing to work with.
Electric mains fan heater would have been a valid option but, as mentioned earlier, I want to keep my option open about moving this away from places with power.
I don't think Edukator was being serious in his post. I assumed it was just a gentle trolling, hence my gentle reply. If it was serious then he is obviously a hypocritical earth rapist for drinking coffee and contributing to the over populationof the climate. I would try to over react more but I am not a trained climate campaigner.
Waste oil does need a license to dispose of. It is £3,000 initially and then £1,00 a year after that I think. Then it is just burnt. This is not just a cynical money grab apparently but a genuine attempt to save the planet by ensuring people who burn it have paid for the pleasure or pay tax on new fuel, otherwise they would be getting all the benefits and recycle more oil without any tax revenue being generated which is clearly bad for the planet.
I have a quality one in my van which was a lifesaver today for warming toe4s after a snow ride. Based on how well it worked I bought a £100 chinese one to heat my little AirB&B bothy. Mounted in a weatherproof box outside and ducted through the wall, it works a treat and not too noisy once up to temp. I used an old PC power supply to get the 12V source which works great. At the start of the season (which has been pretty warm to be fair) I stuck in about 4 litres of cherry (so £3 worth). I guess it has been used about 10 times on colder nights by guests anbd there are still 2 litres remaining. The space it heats is not large and is very well insulated mind. Pay attention to the exhaust gases mind. I have piped mine up above roof level like a proper chimney. Weirdly though the one in the van exhausts into the prop tunnel under the van as this is the stock route for the factory fit model!
How come no local companies are able to produce/manufacture some cheap reliable heater using diesel like the Chinese diesel heater? I was searching Youbtue the other day and apparently very popular in the state. The Chinese made are rather plastiky otherwise I would buy one to try it out. Not sure how that can work in a flat though.
Oh ya ... my living room temperature is 11.3c at the moment and I am wearing woolly hat, base layer, mid layer, woolly jumper with insulation, thick vest, comfy jogger, merino wool long john and double woolly socks. The only cold part of my body is my hands while typing away ... LOL! Let it freeze!
Last night was cold and I had to turn on the central heating for extra 2 hours.
Me think me should order some proper Inuit clothing, you know the one they wear while hunting.
Because local companies aren't allowed to employ 12 year olds on 60 hour weeks with cheap electricity from poor quality coal and throw all the rubbish in the ditch behind the factory?!
For working out value one litre of diesel contains about 11kwh of heat. I don’t know what the efficiency of those heaters will be but maybe only 60% as the need to push the exhaust out so one litre of diesel will give about 7 kWh of heat to your workshop.
^I would agree with those numbers (I'd use 10.4 kWH / litre for diesel or 9.8kWh / litre for kerosene).
Eberspacher's literature says 69% efficiency at low output for their 2kW diesel heater.
100ml / hour cannot provide more than ~1kWh of heating, and if efficiency is taken into account, it'll be more like 0.7kWh - 10 hours would be about £2.10's worth of electricity at current prices, so you'd need to run the heater for ~300h before it would pay for itself if using pump diesel (vs using an electrical heater).
The Chinese ones are much noisier than Eberspachers or the genuine, European manufactured Autoterm/Planar ones - I have had all 3 (& currently have a Chinese one as a shed heater - I'll be drawing some kerosene out of our heating tank to run it on having worked these numbers out a week, or so ago!).
I've had an Eberspacher that I've had in various vans/vehicles and it's great. They are noisy though - mine has silencers for the inlet and exhaust. I'm currently on with making it fit in a 30l aluminium flight case so I can use for emergency heating.
I used to own a workshop with a used oil heater and again - it was great! It seemed to burn cleanly enough but the need for an expensive licence killed it.
Slight thread hijack, but these IR heaters.
Are they a good shout for heating up an area within a room very quickly where you only really need it heated for say 60 minutes per day?
Electric heater. (Fan)
You really only want it to take the chill off on particularly cold days.
Quiet and can set a temperature limit as well.
Works for me and not used that much.
Insulation may help a bit .
Filling up diesel things tends to be messy.
A battery powered heated vest works well, can charge the battery(s)from solar during the day so purchase price aside it’s free to run and can be used on the bike too
I bought one thinking it would be like my gas truma in the van. For my office at the bottom of the garden.
It wasn't- it was very noisy fairly thisty ( on both kero and pump fuel )
Eventually worked out that an electric oil heater on a remote timer was cheaper to run and considerably more reliable to boot. - but the kero was cheaper than the 13kg butane I was using previously
Pumps and glow plugs appeared to be consumables on both fuels.
[i]It wasn’t- it was very noisy fairly thirsty ( on both kero and pump fuel )[/i]
There is a YT video showing you how to tune them to improve efficiency and reduce coking up. Basically they are sent fromt he factory over fuelling to ensure they fire up and burn hot, initially at least. I think it was something like 20% improvement in efficiency and no visible exhaust after tuning.
Been there.
What you end up with is a much lower kw output.
You can't have it all ways.
Essentially they reach state kw by over fueling.
Are they not all 2kw units with the pump over fueling to give the fantasy outputs on eBay adverts..... Mine was certainly pants once tuned
You can usually pick them up free or very cheap from Facebook or similar. Probably not this week, though.
Bit hypocritical of you “Edukator” to be ranting away after you’ve done the single most damage a human can do to the planet - created more life by breeding.
Aye Aye, we've covered that bit, and no need to go harping on about it.
We all moved out the playground decades ago, so let's leave it behind.
[i]Are they not all 2kw units with the pump over fueling to give the fantasy outputs on eBay adverts….. Mine was certainly pants once tuned[/i]
The tuning shouldn't effect the heat output, just the amount of fuel used and unburnt fuel being exhausted.
Basically you turn the fuel rate down until it drops below maximum temperature and then turn back up one click to it goes back up to maximum. In practice this might mean turning the fuel rate down 5 clicks and then back up 1. That gives you 4 clicks of fuel efficiency and 4 clicks less exhaust fumes. How much a click is worth and how many clicks your machine needs will obviously vary but they come out of the factory turn up high so even the most need one wilkl get enough fuel, all the rest just run inefficiently with too much fuel
So does this mean the cheapo Chinese heater is off the cards and its warm jumper and put a little more effort in 😆
Still not convinced that plugging in an electric heater that will be cheaper and run on about 30% wind power is a better alternative then. 🙁 You've had several posters leading you to water, take a drink.
https://en.wikipedia.org/wiki/Nihilism
That's a link for my my detractors in general and not aimed at you alone WorldClassAccident. These threads often descend into woke versus nihilism.
Given this is wca, I’m surprised he’s not welding up a few bits of pipe and an old gas bottle to make one.
You used to, but not anymore.
These days it gets sent away for incineration, which whilst technically burning it, an industrial thermal oxidation unit with all the pollution controlls is nothing like a Chinese diesel heater.
Engine oil contains all sorts of metal based additives that would make for particularly nasty pollution.
But due to emission laws they dont just send the residue out the chimney, theres filters and things.
[i]Still not convinced that plugging in an electric heater that will be cheaper and run on about 30% wind power is a better alternative then.[/i]
I agree the electric heater plugged in will be a more efficient use within the single scenario but, as repeated a couple of times in the post, I am looking beyond the single scenario and don't want to have to over consume buying a heater for the garage, another for the potential motorhome, another for the trips to unheated cabins etc.
I am trying to be more responsible and find a reasonably ecological solution to multiple issues. I feel that a transportable heater running on bio fuel would meet all of these needs without requiring multiple different heaters.` does this make sense for you?
No, but insulation would.
The garage is already partially insulated with a dropped ceiling to keep the hot air in the working area. There is little point in more extensive insulation for its use pattern.
I am in there for perhaps 2-3 hours at a time so need something to heat the air relatively quickly rather than needing to retain the heat for long periods. As the main loss of hot air was up through the unlined roof tiles, the recycled wood ceiling has had a noticeable effect.
As I am sure you would agree, it is about proportionality of approach. It would be irresponsible to fully insulate the garage given the materials and environmental impact of their production for such a situation.
That’s a link for my my detractors in general and not aimed at you alone WorldClassAccident. These threads often descend into woke versus nihilism.
These threads used to go like this...
• Advice asked for.
• Lot's of good advice given.
• OP goes away happy and others were happy to have helped.
^^ on Singletrackworld? I think this person is lying
Those gas heaters (freestanding “Calor” and the propane rocket type) seem to send fumes straight into the inhabited space though. No one really wants to breathe that for hours. Nasty.
@WorldClassAccident
I've got a spare you are welcome to borrow and give it a try.
I think it will work great but why not just test it and see?
Couldn't you make some sort of generator/system that can charge up off a Zwift bike.
You could power it up for a while, then run it as a heater.. double the benefit 😀
I recently installed a 2kw standalone system on my t4. been a godsend recently.
This is probably the bets up to date guide on chinese diesel heaters
https://www.vanlifeuksurvivorsguide.co.uk/post/tried-and-tested-diesel-heaters-3-0-2022-2023
The newer heaters now have bluetooth and full app control ono yoiur phone which is handy
I have seen ppl add a switchbot so they can set 7 day timers
Just stick an EGR on and feed into a radiator of some sort. (I have an EGR and pump as well if you want to try)
When they coke up just strip and clean... it's not a big deal.
How about a 600 x 1200 t22 rad, 7200btu, or approx 2.4kw. Linked into the house ch?
Ypur garage is close enough, the rads a cheap, plumbing straightforward.
If its cold enough to need a few degrees in the garage then the ch will be running anyway.
Utilise the efficiency of the ch boiler, on cheapest kw/h heating medium. Gas.
Ok so its not movable, nor instant, but its cheap to install and run.
A lever valve inside wpuld give you a real simple remote on - off switch,
Im going outside after dinner to tinker, so open lever valve, 30 mins later and the garage will be warming up.
Or fit a woodburning stove, I'll lend you my chainsaw and ypu can go logging in LW. Then we get the double benefits of " anyone want to see what a chainsaw does when it hits ypu" and "i appear to have burnt my garage down"
Garage is close but dropped about 6 feet from the level of the house with a big concrete patio, retaining wall and tarmac path to get to before the pipes reach the garage so that is a No from me. 🙂
Heater is ordered and arriving in the next week.
Stevextc - I am intrigued by the idea of EGR and radiator. As I plan top make the unit moveable I will have some kind of connection between the exhaust from the unit and the out pipe from the garage so I guess I could put and EGR and radiator in there before the out pipe. ANy picture, links, coming round here to show me what yo are talking about is welcome 🙂
Really???
At the very least: buy radiator, drain down the CH system, find somehere to extend the run from, drill holes in the wall, fit pipework, fit the rad, refill CH and bleed system.
Not cheap and your'e heating the rest of the house just to heat the garage for a couple of hours unless you go round turning all the other rads off first.
I'll see if I can send you some video's but check
It works really well, it's really just I didn't want extra holes, hoses etc under the van so I instead made a heat exchanger for the hot air to heat water. (Just 2x cheap PC watercooler radiators) I got one with a 25mm end so it literally just plugs on .. then couple of silicone pipes (to take heat) and a small pump ..
I'll see if I can find the pics/video but this was just a temp knockup POC... but 10L of water from 10C-50C takes about 10 mins... slight decrease in the efficiency of the burn but not anywhere near as much as you recover.
It a full redundant unit so if you want a go and see how it works out we can work something out... It will doubtless include bikes 😉
@oikeith it goes down pretty well very similar to my enduro. The weight is in the right place. Rode it without assist, it's just heavy but ok. Can see me getting twice the amount of climbing done.
A lever valve inside wpuld give you a real simple remote on – off switch,
That's going to be fun when it freezes.
Another option is a small patio type heater.
We have a small one designed to go under a patio table.
It's a bit like sunlight for warmth.
It does not really heat a room up like a proper heater ,but u feel warm beside it.
It's also designed for damp conditions with safe lead etc.
My Mrs uses it behind her desk indoors.
We use it camping when a power point.
Another possible idea.
600w I think but surprisingly warm.
But not garage specific but multi use may suit.
Er.... is that a joke? They're unsafe because they didn't come with proper instructions? Have these people never bought anything from China?
No, not a joke -
All products were found to be unsafe, with listings for all sellers removed on eBay.
Consignments arrived at the Port in October and November and were stopped by the team, with samples sent to a test house for assessment.
Each of the products did not meet the requirements of the Supply of Machinery (Safety) Regulations 2008 because they could present the hazards of fire and death due to poor supporting installation information.
Manuals supplied with the products failed to give measurements for installing and did not give the minimum distance the exhaust pipe can be installed from flammable material, or material that could give off poisonous fumes when heated, such as insulation material.
No warning was provided about heat and dangers to the user if installed incorrectly.
Large parts of the manuals were written in poor English and had incorrect words used. The intended meaning was, in some cases, difficult to understand.
Additionally, the products and instructions did not have the name and address of the importer or manufacturer, and did not included the required Declaration of Conformity (DoC). A DoC is a formal declaration by a manufacturer, or the manufacturer’s representative, that the product to which it applies meets all relevant requirements of all product safety directives applicable to that product.
Our illustrious 'Office For Product Safety and Standards" (no, I hadn't heard of them either) have stopped quite a bit of tat coming in recently:
Link (Vevor comes up a *lot*)
They’re unsafe because they didn’t come with proper instructions?
Never underestimate the stupidity of people!
I have little confidence in plastic parts and heat to be honest.
That's why it is better to manufacture locally with some parts source overseas.
The current energy crisis will last for sometimes to come and anyone who are innovative enough will "hit the jackpot" if they can engineer something that is workable.
Plenty of scientists and engineers on STW forum so why not someone take a lead by coming up with a prototype that is economical, safe and price reasonably etc?
Then "crowd fund" from STW with shares in exchange if it is viable. I rather invest in a company that can make something then to let my money rot in the bank tbh.
It is now time for all you brilliant minds to show that you can do something rather than swinging your handbags at each others.
