Changing european p...
[Closed] Changing european plug sockets in campervan ? Any electricians ?
The campervan I imported last year from Germany has European plug sockets is it just a case of wiring UK plug socket ? Anything else I should be aware of ?
Is this okay to install ? [url= http://www.screwfix.com/p/13a-1-gang-single-pole-switch-socket-metal-clad/43926# ]screwfix[/url] or this [url= http://www.screwfix.com/p/lap-13a-1-gang-unswitched-socket-ip55-240v/38339# ]screwfix 1[/url]
[URL= http://i1354.photobucket.com/albums/q685/unfitggeezer/895E9640-3498-4AB0-8F3A-7E417D092D1A-914-000001F47E90245B_zps09c4b1c4.jp g" target="_blank">http://i1354.photobucket.com/albums/q685/unfitggeezer/895E9640-3498-4AB0-8F3A-7E417D092D1A-914-000001F47E90245B_zps09c4b1c4.jp g"/> [/IMG][/URL]
[URL= http://i1354.photobucket.com/albums/q685/unfitggeezer/15DD837F-3BDF-4307-9B3A-3098DC670EB3-914-000001F4480614FD_zps3c07c3e2.jp g" target="_blank">http://i1354.photobucket.com/albums/q685/unfitggeezer/15DD837F-3BDF-4307-9B3A-3098DC670EB3-914-000001F4480614FD_zps3c07c3e2.jp g"/> [/IMG][/URL]
Posted : 14/05/2014 10:31 pm
The easy answer is yes, as continental europe uses a 220v system and ours is 240, so most appliances are rated at 230 with a buffer to be usable on both,
Posted : 14/05/2014 10:43 pm
not an electrician but yes
assuming it is inside the van and not external - it must be as you use a 3 point thingy outside- then any standard UK socket will do you do not need IP rated ones [ basically how outside wet and dirty]
An electrician will explain this with the correct words tomorrow
I assume it has an RCD fitted as well.
Posted : 14/05/2014 10:44 pm
thanks for answers and by RCD you mean these ?
[URL= http://i1354.photobucket.com/albums/q685/unfitggeezer/2E6E9A1F-4485-4334-A591-22DBAC776662-2008-00000160E3ED0E1B_zpsdc5e6336.jp g" target="_blank">http://i1354.photobucket.com/albums/q685/unfitggeezer/2E6E9A1F-4485-4334-A591-22DBAC776662-2008-00000160E3ED0E1B_zpsdc5e6336.jp g"/> [/IMG][/URL]
Posted : 14/05/2014 10:50 pm
one thing i forgot some european sites (particularly in France) can have the live and neutral wired 'back to front'so check your van isn't similarly wired, you can get a plug polarity tester to do this
[url= http://www.ebay.co.uk/itm/like/251516778234?limghlpsr=true&hlpv=2&ops=true&viphx=1&hlpht=true&lpid=108&device=c&adtype=pla&crdt=0&ff3=1&ff11=ICEP3.0.0&ff12=67&ff13=80&ff14=108&ff19=0 ] one on ebay[/url]
Posted : 14/05/2014 10:51 pm
I have one of those and all okay...its the french that play that game !
So do I have RCDs then ?
Posted : 14/05/2014 10:53 pm
yes
Posted : 14/05/2014 10:54 pm
Many thanks
Shucks I love this forum ๐Ÿ˜›
just looked at your screwfix links, can you not get new faceplates (probably from a camping shop) to fit the current back boxes?
Posted : 14/05/2014 10:58 pm
The boxes are pretty small I shall measure them and see but tbh if they do exist they'll be twice the price as they would have come from a "camping shop" and that will inflate the price !
I have 3 to change
Thanks for advice and ideas ๐Ÿ˜‰
Posted : 14/05/2014 11:03 pm
Yes the blue thing is your RCD switch you only have one whihc then sends the power to the two circuit breakers [ on the right]
The T button tests the RCD - press it and it should trip the RCD if it does not it is either broken or not wired up and [b]get someone to look at it [/b]
I could explain how it works but trust me you want it to work!!!!
Posted : 14/05/2014 11:42 pm
Not ideal, but when I moved back to germany (with lots of appliances on Uk plugs) I made up some patch lead extensions. Use a European plug on the one end and a UK multi socket on the other end of a short extension cable. Job done.
Posted : 15/05/2014 12:25 am
why dont you just put a Tesco adaptor in them at about one quid each??
Posted : 15/05/2014 8:27 pm
Looks like its been wired in standard solid core cable?
Really it should be braided copper flex as the solid stuff can crack/break due to the vibrations when driving.
Also, there should be a good earth to the body/structure of the van to ensure it is earthed via the electric hook up.
Posted : 15/05/2014 9:30 pm
