About to change energy suppliers - we are currently with Bitish Gas
Looks like i can save about £450 a year with ... Bulb.
Never heard of them
Is there any danger in moving to a small energy supplier - power cuts etc?
Nope they're resellers not proucerrs, I've just switched them funnily enough. Got a £50 credit too thanks to a referal code.
I have just moved to the Peoples energy co and my account no is under 2500 so I will see how that goes.
I've stayed with First Utility now for a few years. Same sort of setup - never had an issue, service has always been exemplary and the only minor issue I have ever had is trying to explain to their Indian call centre operative what an Aga is
Depending how much credit you build up with them on direct debits, you might be risking losing it if they went bust. Happened to me on a commercial contract once, lost hundreds.
changing wasn't an issue, very easily handled. And it's all the same gas in the same pipes, just a different billing operation (and price)
Getting my accrued credit back out of my previous supplier (First Utility, FWIW) was a different matter. Took months of phone calls, misinformation, finally resolved with a cheque a week or so back.
Next (minor) gripe with my new supplier is that they are using past usage to calculate my monthly payments - but I had a new efficient boiler installed earlier in the year which by my reckoning based on month to month usage comparisons is 40% more efficient. But they want me to continue to pay for an estimated usage based on past history, hence I'm building up another large credit balance over these warmer months July -> Oct that won't get all used up in the cold months any more because I'm using 40% less. Which at a rough count means they'll be holding about £250 of my money for me until they can 'review' usage and correct.
Seems to be the business model, was practically admitted by the guy at F-U, that they want to hold your money as long as possible, I assume they invest it in future gas deals or something.
Been with Good Energy for years. 100% renewable sourcing and no nuclear. They've been excellent.
they're the ones that are committing to 100% renewable? (10% on Gas) . Although as I understand it, their tariffs are variable (ie you can't fix it at all)
so if renewable is important, and you can cope with a variable tariff, you could save some money. Don't know what their customer service is like though.
Christ, I need to get out more... 🙄
I suspect you're covered as a domestic customer. Our supplier folded (GB Energy) and the regulator just persuaded another supplier (Coop) to take everyone on with the exact same contracts - was totally painless move, we did nothing, just got a letter saying our supplier had changed, everything was as is.
https://www.cooperativeenergy.coop/why-us/GB-Energy/
I use this to compare prices.
[url= https://www.moneysavingexpert.com/cheapenergyclub ]https://www.moneysavingexpert.com/cheapenergyclub[/url]
It will also monitor the prices and tell you when you're paying too much and then you can swap again. Works very well for me.
Yup not fixed but you're also not locked in so can change if need be.
Thanks - been a big help.
I might look at getting a fixed tariff.
Will sort over the weekend.
Captjon - if i go with bulb i will use your referral code.
I use this to compare prices.https://www.moneysavingexpert.com/cheapenergyclub
I do this too. My recent British Gas fix comes to an end in the next few weeks, which would see my bills increase by £300-400/year. I considered Bulb but switched to OVO* which is fixed for the next 2 years and was only a pound or two more per month. If you think that works for you be quick though, the tariff ends tomorrow!
*is also the MSE recommended tariff
GlennQuagmire - Member
thanks for that, very useful. Incidentally, I am on virtually the lowest tariff I can be at the mo with a potential saving of £10 a year, not worth the bother of swapping right now.
Don't forget to check Topcashback, there's a weekend promo that needs activating for bonus £3 cashback for a single qualifying purchase over 15 squids excluding VAT&del.
just been looking at switching to bulb. whats my best method? through moneysavingexpert or direct? MSE says theres a £25 cashback after 3 months but im not sure if once ive put bank details in ill still be able to use the code above ^^^ to get me and a stw member £50 off....
My gas Zog fixed period is ending next month. Does anyone know where you can find a comparison site which lists standing charges and unit prices? All the usual ones just give a projected monthly cost, which invariably is miles off the actual. Current deal is 8p/day and 2.5p/kWhr, so it's going to be quite an increase when this runs out - cheapest I've found is 15p/day and 3.5p/kWhr.
They should use your figure for KWhs and the use each suppliers daily and unit costs to calc the figure. Last one I used did this and then showed you the calcs. Can't recall which one I used though, poss moneysavingsupermarket?
What rates are you paying for electricity? I was surprised when recently becoming a bill payer again at how expensive electricity has become:
Standing charge: 26p/day
Unit price: 16p/kWh
with Ovo on green tariff. Previous owners of the house were paying very similar with E.On.
Electricity:
Standing: 18.9000p
Unit: 11.9700p
Gas:
Standing: 18.9000p
Unit: 2.8035p
With Avro.
My current deal is due to expire end of this month and bulb appear to be giving the best deal. I've had a look on their site and it doesn't ask for any details of current usage before giving a quote which is a bit odd and then they don't do direct debit payments which also seems odd.
I was put off the Bulb website for the same reasons. Went with Zog again.
We've just moved away from Ovo due to their high electricity prices on the green tariff. It doesn't help that they quote prices excluding VAT in a few places which seems really cheeky if it's allowed at all.
Next best deal for me is staying with my current supplier, so it's likely I'll just do that.
Currently fixed at
Gas 2.59p/kWh and 19.569p/day
Elec 12.08p/kWh and 19.569p/day
Coop Energy.
Was close enough to the cheapest when I fixed that it wasn't worth moving (2 ish months ago).
I set the ball rolling with a switch to bulb about a week ago using a referral link to get a £50 credit. You won't be able to combine this with the cashback on offer through MSE, it's one or the other...
I used to do door to door sales for a large provider. One of those annoying beggars who turn up at teatime and ask you if you'd like to save money on your bills.
The training was an eye opener - a didactic script which had to be followed to the letter. You basically pretended to be a gas man, then followed up as if you were helping the homeowner by saving them money.
Most of the time, we really were saving them money but it didn't feel right.
Thank the Lord for uswitch et al.
Affect Energy, fixed to June 2018
Elec 11.996p /kwh and 23.8p / day
Gas 2.618p /kwh and 22.4p / day
both plus 5% VAT but minus £15/yr each for dual fuel by DD which has the effect of knocking the standing charge down by 4.1p / day
Yes it does.
It gives you a quick quote and then you select the refine details button.
Electric
Octopus 12M Fixed
Unit rate 12.75p per kWh
Standing charge 18.90p per day.
Gas
Octopus 12M Fixed
Unit rate 2.94p per kWh
Changed earlier this year from OVO who had gone a bit expensive, swap was painless and so far so good.
Second MSE cheap energy club and also recommend you get (and maintain i.e. scribble down / save the statement) your consumption numbers annually for the most accurate pricing - definitely more helpful than estimating usage based on the size of your house or the cost of your bills.
First Utility - whatever their longer fixed price tariff is
Electricity 11.060p + 24.4p p/d
Gas 2.33p and 20.84p p/d.
Always been good to deal with and have always emailed well ahead of the current deal expiring with details of their best new tariffs.
I shopped around a couple of times when deals were coming to an end but they were always there or thereabouts.
When it starts to get in the realms of .5p difference, one might as well stay with the same provider and just be more mindful of energy use.
Can you not change and be mindful too?
I'm probably going to be switching to bulb in the next couple of days, has anyone got a referral link they'd like to share 🙂
Yes but we don’t allow link on the forum itself, however check your private message. 😀
We'll be moving into our new house soon so will need to choose a new supplier. What does the referral link to Bulb do?
You get £50 credit as does the referer
Ooh, that sounds good...if only there was someone who could send me a link 😉
After years of switching suppliers and regularly checking of prices to make sure I saved money, I have just signed up with Flipper. they search for the best deal for you and by having direct access to your online account can then switch you onto the best deal. They check every few months and then switch you if it will save £50 or more.
They have switched us once so far and all has been fine. You pay £25 a year but that is only if they move you. If they don't move you then you don't pay.
Seems like a great idea as now I can forget about thinking if we are on the best cheapest tariff.
[url= https://flipper.community/?gclid=CjwKCAjw6ZLOBRALEiwAxzyCW34jx3Fa_zCZci2JQ8CVm_Rck8n2MxXDrIaHteJChUbBOLAb6xVadhoCLJQQAvD_BwE ]https://flipper.community[/url]
Steveid, I've sent you a code.
We transferred to Bulb in June. I spreadsheeted our previous 12 months usage, and they came out the cheapest by a clear margin.
The process of switching was fine, but there were a couple of teething problems; which I expect of startups and I'm happy to work through.
They do take payments as a recurring debit card payment which doesn't bother me, but you can now setup a direct debit if you want to; you just need to contact them.
I've entered into a auction type thing through the union. I've put my current details in and on a certain date suppliers will tender offers to be my supplier. Then it's a case of picking one.
Anyone heard or done this before? I'm wondering if I'll get better deals than what's publicised. I've saw it for cars before but not energy suppliers.
Looking at switching to Bulb as British Gas seem to be just upping our DD for fun! Anyone got a referral code they'd like to PM me?
Check your PM.
