Central Heating.......
[Closed] Central Heating....What Has Happened?
[#9813319]
Radiators upstairs hot, as normal.
Radiators downstairs cold.
Up and down on the same circuit controlled by a 3 way valve (for the hot water as well).
Any clues.
Posted : 02/02/2018 7:12 pm
TRV’s turned down or stuck.
Posted : 02/02/2018 7:14 pm
No TRV's.
OK this morning.
Not OK this afternoon.
Posted : 02/02/2018 7:29 pm
Airlock?
Posted : 02/02/2018 7:37 pm
Warm water rises, so how long has the system been running? What's the system pressure if it's an indirect closed loop? Have you bled the rads yet?
Posted : 02/02/2018 7:38 pm
Pump stopped working.
Posted : 02/02/2018 7:46 pm
Could be your pump that has failed. Should be able to feel it vibrate slightly if its working.
Edit. Beaten to it!
Posted : 02/02/2018 7:48 pm
if it is a stuck pump then they can often be restarted - there is usually a big silver screw in the face of the pump - remove it ( a bit of water will come out) and then you can access the pump spindle to give it a flick - sometimes gets it running again for a short time
Posted : 02/02/2018 8:08 pm
Air in the pump will stop it - as above, undo the screw in the middle of the pump.
Also turn off all upper rads and see if heat circulates downstairs - air lock.
Posted : 02/02/2018 8:50 pm
The main suspect is the pump.
I increased the main thermostat to 'call the boiler on'. Cannot feel any vibration in the pump, nor hear it running.
Co-incidently, the central heating has been a bit 'noisier' than usual just recently. Perhaps that was a signal of the pump giving up.
Will call a pal tomorrow morning (he is a heating engineer).
Thanks chaps.
Posted : 02/02/2018 9:56 pm
