Central heating rad...
[Closed] Central heating radiator problem
I have a radiator that gets hot at the top but is cold at the bottom. I’ve got a bloke coming round to have a look and service the boiler at the same time but I’d like to be forewarned about the cold rad before he starts work.
Any ideas what is causing it or could there potentially be a whole list of things?
Posted : 10/10/2012 12:29 pm
If all of your other radiators are hot all over then suggest that this one just needs bleeding (removal of air as per hydraulic brakes) and problem will go away. If it is just a bleed its a simple fix and should take him minutes.
If you have a radiator key it is a job you can complete yourself fairly simply. (youtube or google for more detailed explantion)
HTH
Sunday
Posted : 10/10/2012 12:35 pm
This rad is hot at the top and cold at the bottom. Wouldn't air in the system cause it to be the other way round?
Posted : 10/10/2012 12:36 pm
When was it last bled?
Posted : 10/10/2012 12:37 pm
Hot at the top is odd.. When they need bleeding it's more usual for them to get hot only at the bottom. Maybe it's Rad sludge build up at the bottom stopping water cirulation there.
 ski
Is it half full of sludge, time to get your marigolds? 😯
Posted : 10/10/2012 12:41 pm
It'll be full of shit.
Posted : 10/10/2012 12:44 pm
This, one would assume, is a bad and expensive thing to sort then?
Posted : 10/10/2012 12:51 pm
You can buy stuff to put in the system.. then you have to drain it I think.
Posted : 10/10/2012 12:52 pm
Shut off the valves, drain the rad, dismount & takes it outside, flush it through with a hose pipe.
Very messy
Has someone added the wrong inhibitor to the system?
Posted : 10/10/2012 12:53 pm
Shut off the valves, loosen the two joints then lift the rad off its bracket and swivel the top out and down to the floor. Drain it through the bleed screw. CLOSE the bleed screw and then disconnect the rad and carry it outdoors upside down for flushing with a hose. That way you won't pour black sludge all over your floor.
Posted : 10/10/2012 1:00 pm
 Bear
It is caused by poor circulation either from a build up of 'sludge' or a badly balanced system.
Best to take radiator outside with a hose as others have said if sludge. You will probably be sold a power flush which may or may not cure the problem.
Posted : 10/10/2012 1:05 pm
I’m not doing it, the blokes who we have used before are when they come to service the boiler.
Over the phone they said it could require balancing or a system flush, one being a lot more expensive than the other, and they would try a balance first.
I just thought I’d throw it to “The STW Hive Mind” to see what it thinks.
Posted : 10/10/2012 1:09 pm
I've replaced all of the rad's in my place as part of renovations
I couldn't believe how much and how thick the black sludge was in the rads, the heating had certainly been neglected for some years before we moved in. The old chap had lived there for 56 years and basicly hadn't maintained anything
I'd put money on a flush than bleeding/balancing too from the symptoms
Posted : 10/10/2012 1:21 pm
