If you were casting something what would this mean?
I finished the mold today & shot a couple of waxes to detail
what are they casting?
Probably using the lost wax technique.
i'm guessing they've carved the item in clay or similar, made a mold around this, and then cast up some wax versions of the item which will then be used to make a casting of the final item in metal. They're probably going to check and if necessary add detail to the wax castings before they are then used to make a metal casting.
http://en.wikipedia.org/wiki/Lost-wax_casting
Definatly using lost wax technique.
So when she says
She has made positive castings in wax from a clay original?
yeah thats what i would think, then she can check and add detail to these before its sprued and the final casting mold made.
Its MOULD, Mold is a place in wales,
i wondered if it was mould too, but i copied off Soma-rich, its his fault!
Unless of course the OP is talking to an American; they do like to modify our spellings and spell it mold
I am....
Could be using injection moulding to make the waxes? Maybe if they "shot a couple of waxes". Shot is an injection moulding term and it's common now to make waxes this way. Then its shelled in various slurries, they go hard and you have an outside mould, melt the wax out and fill with molten metal. But given the lack of info this is all just a wild stab in the dark.
If its lost wax in the clay-wax-bronze statuette sense then I would guess at it being a few wax copies of the original being cast in order to add fine detail, perhaps because the wax takes those fine marks more readily, perhaps because those details are so fine they'd be lost through too many mould-making steps, or maybe several waxes are made so that there's more than one shot at getting those details just so.
Edit - or if the mould is complete maybe wax positives are being cast to test the result before making final cast, as with many techniques you destroy the mould with the actual pour
PS in the injection moulding industry I often get correct even by UK operators as they like to use the american spelling as they tend to have the money. I just can't help using mould though as I agree Mold is in Wales.
I nearly misread the thread title.
Did you know that casting translation is an anagram of slanting castration?
