Cars, garages, trau...
[Closed] Cars, garages, trauma. What would you do?
In the interests of fairness, I'm going to try and give a full account of this.
Friday morning on the motorway the battery warning light starts flashing. I'm late for work so ignore it, roughly fifty miles later get to work in one piece still.
Set off from work to go home, no lights flashing, all good. Stop off halfway for fuel, start the car again and it's dead - won't even turn over. Breakdown chap comes along, diagnoses the alternator is rogered and drops me and car at home. I check out a couple of garages online, give a couple of calls, select a chap who sounds reasonable and has good recommendations.
Saturday morning, car is collected from mine, dropped at garage. Yesterday alternator is replaced.
This morning I pick car up, all working fine, pay for the work and drive off happy.
A mile down the road there is a very weird knocking sound, 200 yards further on battery light comes on again and 200 yards later all power to the car is gone.
Ring garage back - 'oh that's weird'
'I'll call breakdown and bring it back to you'
'Yeah no problem'
Breakdown man arrives. I explain the above to him. Pops bonnet and pulls a mangled length of cord from the depths. 'This is your alternator auxillary belt. It should be changed when the alternator is changed. Are you sure you want to take it back to the guy that did this?'
Okay maybe not, so pop back to the garage he's come from. Mechanic there has a look, tries to start it. 'The timings out. Cam belt looks a bit mangled. Looks like alternator belt has wrapped itself around cam belt.'
Okay says I, I'll take it back to chap who did the work originally and ask him to sort it.
Original chap rings this afternoon. Timing has gone out, bent a piston. Engine rebuild, will cost more than car's worth, basically it needs scrapping. Come in for a chat tomorrow.
What would your thoughts be and what angle would you be taking for this chat?
Posted : 21/07/2009 8:17 pm
He has to put you back in the position you were in before it happened. i.e. he fixes it, gives you a car or some cash. Figure out how much it's worth before you go.
Does the bill for the car mention any belts? Did he mention it to you? Start out nice get him to do the talking/offering to begin with and then start mentioning solicitors etc if you're really getting knowhere.
Posted : 21/07/2009 8:37 pm
This is going to get painful, what car do you have?
Most cam belts have a cover to stop this kind of thing happening, I'm interested in the set up of yours.
Good luck.
Posted : 21/07/2009 8:42 pm
I agree initially go in and see what he has to say, they seem at fault from your story and should rectify. Sounds like he knows they are at fault.
See what he offers, you're not obliged to say yes, just listen to it.
You can always walk away and think about it.
I guess if its anything less than 'sorry mate we screwed up but we'll completely fix yer car' then its time to consider the options.
Hopefully he's genuine and will offer a free fix. If he does then ask to get the work inspected at his cost if you can.
Otherwise maybe get trading standards involved.
Posted : 21/07/2009 8:45 pm
Oh I forgot to say that the decision is yours not his as to what to do.
Posted : 21/07/2009 8:48 pm
Steve - he said he'd looked at the aux alternator belt and 'it looked alright' so he hadn't changed it.
Brief look on autotrader suggests the max it could be worth is 2.5k. I think it's more like 1 - 1.5 for mine, possibly a bit less. 2000 Polo (but a nice spec) with 97k on it.
2u2r - yup, there is a cover over the top but it wrapped around underneath or possibly around the lower pulley
Posted : 21/07/2009 9:00 pm
Probably bent valves, not piston. Still expensive. Still his fault. If it was still turning over it might need valves and valve stem overhaul - maybe a tenner per valve, some valve guide work and new seals, plus effectively a cam belt change and head gasket change in the process.
However its more likely he didnt *adjust* the belt/alt properly - fairly rare for a belt to go walkies due to being old, normally they just snap, its only if they have re-fitted it badly that they wander off etc. I've re-used alt belts COUNTLESS times on cars. Its highly possible he forgot to tighten up one or all parts of the alternator mounting, which would cause it to walk off the pulley due to misalignment.
Never trust garages. Buy a book and some spanners and do it yourself.
Posted : 21/07/2009 9:05 pm
It could be one of the rollers or something else like the waterpump/ac compressor has seized & caused the belt to snap, this could be because the alternator bearings going have put unnecessary strain on other components leading to the failure.
It's a fine line on whether or not to change the whole lot at the same time, but most customers will moan or say someone else has quoted less, so you don't advise or insist they change the lot.
I hope you get it resolved soon.
Posted : 21/07/2009 9:19 pm
2u2r - btw its apparently very common on the HDi pugs for the bottom pulley to fail "partially" and make the belt walk off the pulley, taking the timing cover and belt with it so I suppose it's not unheard of even on covered cars, but you'd not expect it would you? Replaced mine only last month for this very problem thankfully.
Posted : 21/07/2009 9:28 pm
Fair enough, but on a polo I would think it was the plastic veined waterpump to be the possible cause.
I certainly wouldn't replace an alt belt just because the alt failed, but I would obviously inspect it closely before making the call.
My gut instinct would be that it was a cheap recon alt that is to blame, I've had relatively expensive Bosch units fail within a few months, but thats rare, there was/is a place on the A406 that reconditioned starters, alternators etc, we used to laugh & take bets about how long they would last (after giving the customer the choice based on cost & recommending the expensive option).
Posted : 21/07/2009 9:38 pm
Buy cheap, buy twice 'n' all. Works in most areas! Recently did the stupid thing of doign a cam belt and not replacing the w/pump on my other halfs car, needless to say the damn thing is leaking within months!
Posted : 21/07/2009 9:43 pm
Cheers for the responses guys.
With regard to the actual alternator - it looked pretty shiney (although I guess that doesn't mean much) and cost £110. I don't know what that means.
The alternator belt was in a mess. Sounds like it snapped to me - there was a sudden banging as though it had snapped and the end was banging about inside the engine bay. It was raining at the time and I at first thought it had started coming down really heavy 😕
When it was pulled out had a frayed end so yeah, had definately snapped
Posted : 21/07/2009 11:37 pm
beware, the chap is almost certainly going to try to blame the damage on the original failure and not his crapness. Unless you're really lucky. If he does, be prepared to walk out and engage legal advice.
Posted : 22/07/2009 3:29 am
I'm surprised you've not been advised to wee in his shoes actually!
I'd be speaking to Citizens Advice before you go in or look at your car insurance policy as you may have legal advice cover with it. Do the RAC or AA or similar also carry free legal advice? maybe worth checking.
To be frank, the garage chap is hardly likely to offer you a pile of cash for ruining your car now is he.
Also, go onto google maps, find his garage on it and leave an appropriate review 😀
Posted : 22/07/2009 7:09 am
Typical STW. Garage man hung, drawn & quartered 🙂 already...
Yo never know, he might just come good...
Posted : 22/07/2009 8:59 am
 hora
steveh - Member
Totally agree. Garages/dealers will sometimes talk to you as though they are doing you a favour when something is seen to be 'technical'. I personally wouldnt listen much when he says its not his problem. Speak to your insurance company (if you have legal cover) before going down. Do you have the name of the breakdown guy(s) who you spoke to- could you find this out from a reference log etc? Find this out as well.
Posted : 22/07/2009 9:04 am
This happened to my megane, if it's been run with the timing off it will probably have done multiple valves (the knocking noise) and probably the overhead camshaft as well, if you're really unlucky it'll have bent a piston con rod too. Fortunately my dad's a mechanic so it all got fixed, but he still won't tell me how much it cost!!!
Posted : 22/07/2009 9:10 am
No legal cover with my insurance, unfortunately. I've just spoken to consumer direct. They seem to think I've got a good case - work should have been carried out with 'reasonable care and skill' and they mentioned Supply of Goods and Services Act and small claims court. Right, guess I better go and have a word with the garage.
Posted : 22/07/2009 10:22 am
 hora
Good luck.
Posted : 22/07/2009 10:23 am
In parts - not that much. In time and effort - probably more than your car is worth. Buy the man some beers 😀 Full strip down, proper check and rebuild even on a simple engine is 10+ hours labour at the minimum, even at mates rates thats pretty steep.
Posted : 22/07/2009 10:27 am
I've been offered the money back that I spent on the alternator + £200 for the car.
He's saying he's never seen it happen in 10 years and that he'd checked the aux alternator belt and it was fine.
I also spoke to the guy who looked at it yesterday at the other garage and he said he couldn't be sure whether it should have been replaced without having seen it - it's not replaced with the alternator as a matter of course.
So, it could be negligence or could just be bad luck.
I don't know what to do really.
Posted : 22/07/2009 11:52 am
And he'll have your car on Autotrader next wk for £1500.
Small claims court without delay.
Posted : 22/07/2009 11:56 am
That's a crap offer least he could offer is value of car without any problems.
Posted : 22/07/2009 12:00 pm
 hora
What is the car/year and when was it last serviced and by whom?
Posted : 22/07/2009 12:06 pm
Sounds a lot like he accepts some sort of liability if he's offering you anything!
Posted : 22/07/2009 12:10 pm
Sounds a bit rough on you as he could reasonably claim it was co-incidence that the belt snapped at the same time (as it wasn't necessary to replace at the same time).
Did he charge you for a new one?
Posted : 22/07/2009 12:13 pm
Yeah, he went on autotrader and came up with a value of £300!
Top two on here are similar:
http://www2.autotrader.co.uk/search/results/usedcars/postcode/s118yf/make/volkswagen/model/polo/keywords/se/price-to/3000/transmission/manual/engine-size-cars/1-4l_to_1-6l/body-type/hatchback/quantity-of-doors/3/page/2?logcode=s&gquery=pre-owned%20volkswagen%20polo
It's a 2000 polo, 97k, last serviced Feb by back street local garage.
Posted : 22/07/2009 12:18 pm
Mastilles - no, nor did he fit one
Posted : 22/07/2009 12:26 pm
In parts - not that much. In time and effort - probably more than your car is worth. Buy the man some beers Full strip down, proper check and rebuild even on a simple engine is 10+ hours labour at the minimum, even at mates rates thats pretty steep.
Parts was over £800, we did all the work between us as I spent a chunk of my youth lying under various cars (funny that), but yes, he won't have to buy a beer around me fot the rest of his life!
Posted : 22/07/2009 12:31 pm
To be fair to him he has also been unlucky with this sometimes things just happen and it is not really his fault but he would need to prove he did not damage the belt and he fully inspected it before re fit (which is not reallly possible) and is some what countered by its catastrophic failure so close to his premises.
He pays for a scrapper engine and you £100 for his time to fit?
You are out of pocket so is he but hassle free solution for you both?
I think you have probably both just been unlucky.
Posted : 22/07/2009 12:43 pm
 hora
As said. Offering you cira £300 for a £2k car seems abit like he will be carrying out the rectification after all... just not returning the car to you. Cost to him? I'd say he'd make a profit from your loss. I doubt hes paying you scrap value.
Comes down to a burden of proof though. I'd post this thread on www.pistonheads/gassing
Posted : 22/07/2009 12:53 pm
Well at least he's talking to you.
Quick look on ebay says around £300 for an engine, perhaps he has contacts for a cheaper deal.
Maybe there's also some sort of residual value in the old engine.
So the cost to him to replace the engine is not that great over and above the £200 he's already offered, I'd push for (at least) that with a written guarantee.
Otherwise he buys the car from you at the pre damage value?
Posted : 22/07/2009 2:05 pm
An update in case anyone's interested
Has offered to do the work on fitting a new head for free if I pay for the parts. That's still going to be circa £600 though, so I've asked him to have a look for a 2nd hand engine. Going to get back to me later today
Posted : 23/07/2009 11:14 am
 hora
ourkidsam, if he fits a different engine though it'll have to be noted on your V5. That will really affect your resale so you wouldnt get 'book/internet' prices of 2-2.5k if you sold it on. Worth noting.
Posted : 23/07/2009 11:40 am
I did wonder how that might work. Cheers, will bear that in mind
Posted : 23/07/2009 11:41 am
 hora
Im guessing on this bit- different engine number. so it wouldnt match on the records so needs recording. I might be wrong on this being the reason though.
All the best though. IMO, hes showing his hand that hes in part to be blame for this.
Posted : 23/07/2009 11:43 am
Change of engine number wont affect sale price, surely.
Interestingly, I know a lot of people who modify/swap engines in cars regularly, never known one to let the authorities know unless the size changed.
Posted : 23/07/2009 11:53 am
 hora
CK, if there are a choice of 10 Polos and the 11th has a different engine would you pay market price/the same as the previous 10?
Posted : 23/07/2009 11:58 am
Why would anyone notify the dvla of a engine change?
And even if you did, unless you tell people how will they find out?
In all the years I have sold cars I can count on one hand the amount of times people have checked engine numbers, chassis numbers yes, but matching chassis & engine numbers only mater on very important classics.
HTH.
Posted : 23/07/2009 3:39 pm
 hora
I have 🙄 but then Im a nerd 🙁
Posted : 23/07/2009 3:57 pm
With Hora's name change I actually started listening to him... 🙄
Posted : 23/07/2009 4:43 pm
Don't know if this is of any use to you but we recently had a '97 Polo 1.4CL with 51k miles written off in a rear end crash.
Insurance payout was £1150.
Kept the car and sold on Ebay £225
I think the value of £200 he offered you is a bit low. But Ebay prices are less £300 for knackered engines so he's not a million miles out.
He is trying to make a profit from you.
Your car is worth at least £1500 is the body work is half decent.
Get him to source and fit a second hand engine exactly the same as the current one and then sell the car immediately. You'll have no history for the engine he gets you and could have issues down the line.
Posted : 23/07/2009 5:30 pm
For insurance and tax purposes I guess. If you replace that 1.1l engine with a 2.0l turbo and then write your car off, your insurance will be invalidated if they come and inspect it.
Posted : 23/07/2009 5:33 pm
 hora
dooosuk's right. New engine could have been run low on oil/misfuelled, coolant problems/overheating etc etc etc.
Posted : 23/07/2009 8:01 pm
Precisely my plan
Posted : 23/07/2009 10:37 pm
I await your "VW Polo for sale, 1 careful owner, recently serviced" ad in the classified. 🙂
Posted : 24/07/2009 8:49 am
 hora
You know. Its not too late to source either a G60 or VAG 1.8T engine and fit...
Posted : 24/07/2009 8:52 am
Just had a call off him. Has offered me either
me to pay £400 (min) for new head
OR
£400 plus the refund of the work for my car
OR
a newer, lower milage Clio for £200.
Going to have a look at the clio but I think that might be the way to go
Posted : 24/07/2009 9:40 am
 hora
Clio sounds possible- service history, etc etc. Plus has it got any sort of comeback to him?
Posted : 24/07/2009 9:47 am
Haven't gone through the finer details yet. Will be asking for some sort of guarantee on it, plus maybe the next MOT done by him or something.
Anything particular I should be looking for on a Clio?
Plus he rang back to say it was £200, sounded like a straight swap in the first conversation. 🙄
Posted : 24/07/2009 9:50 am
 hora
What year is it? IF it is good I'd say waver the £200 and through in a guarantee. After all, the Polo was worth 2k if you sold it. I doubt the Clio would be 2k to buy.
From memory you can buy a 172 Clio Sport/2002 for circa 2k.
Posted : 24/07/2009 9:55 am
2001 I think, 78k.
To be honest, sounds like the best resolution for all involved. I come out with a working car, provided it's in better nick than mine was, then i'm about evens
Posted : 24/07/2009 10:00 am
 hora
What engine size, spec, how many owners? Will do a private sale search..
If it comes out at £1200, and hes willing to give you a 3month warranty on any mechanicals (ie he fixes) then I'd personally take it.
Bare in mind that at 78k its probably due its second cambelt change. Clios have to be changed before manufacturers recommendations at 40k intervals? Also ALL electrics work.
Im assuming its the 98-01 Gen:
http://www.honestjohn.co.uk/carbycar/index.htm?md=1289
Edit:
[i]1.2 16vs seem to be suffering a lot of timing belt failures at mileages as low as 36,000. Best to change the belts at 5 years or 40k miles max. On 1,149cc D4F 16v and D7F 8v engines it is essential to change the timing belt, tensioners and the water pump every 3 years or 36,000 miles (whichever comes first). Early timing belt failures not unknown on RenaultSport Clio 172s, so best to change belt, tensioner and all pulleys at 4 years of 40k miles whichever comes first.[/i]
Posted : 24/07/2009 10:10 am
It's an X plate so yeah will be that. 1.2. Don't know what the spec is or owners yet.
Will check when it last had the belt changed.
Cheers Mark
Posted : 24/07/2009 10:14 am
 hora
Don't feel brow-beaten into accepting the car. Have a good look round it, ask questions then say you'd like to have a think.
How much was the work that you paid for the alternator?
We replaced the polo that was written off with another one.
N reg (so older than the one written off but in better condition) with 71k miles but had a years MOT and tax for £700.
You can buy cheap reliable cars.
£400 he'll give you + refund + £200 to buy clio = same budget as just buying the clio off him
How much does that give you to play with? Then we can see what you can get instead of a clio.
Clio will be next to worthless when you want to sell it at somepoint down the line.
Posted : 24/07/2009 10:24 am
Alternator work was £160 so £760, though I'm not sure it should be worked out that way.
Posted : 24/07/2009 10:31 am
 hora
dooosuk again is right. Bloody eck, must try harder
You're right, it shouldn't be worked out that way but thats what it effectively boils down to. Anyway you look at it at the moment you're going to be down to the tune of £500 - £1k potentially.
Only way not to be is to get the repair free of charge but that doesn't look like it's going to happen.
Sorry fella, not sure what else to say. You've been very unlucky/misfortunate.
Posted : 24/07/2009 11:02 am
Clio isn't quite as nice a spec as mine but a comparable price on autotrader it seems. If he'll give me a guarantee on it and for less than £200 think I'll take it
Posted : 24/07/2009 12:03 pm
 hora
In that case- a good check over mechanically (dont sign anything that says sold as seen/trade sale), then SELL IT!!
Posted : 24/07/2009 12:50 pm
Nah think it's sound - he drives to work in it at the moment (I did see him pull up in it on Monday when I first went). Got a guarantee on it too and I do enough miles in a week to see if it's going to go pop or not. So, not the fairytale ending I was looking for but I'm reasonably happy.
Cheers all
Posted : 24/07/2009 1:12 pm
 hora
Nay problem 🙂
Posted : 24/07/2009 1:22 pm
Glad you're happy.
Posted : 24/07/2009 1:35 pm
Glad to see everything turned out ok.
