car tyre pressures
[Closed] car tyre pressures
[#3048235]
It's an older car, 1998, and I'm wondering if I should be going with what the car manufacturer says or the Tyre manufacturer says?
Posted : 14/08/2011 7:08 pm
Is there a wild difference?
Posted : 14/08/2011 7:09 pm
IMO - If its the original size tyre as came on the car when first bought, then the car manufacture pressures as they'll (should) be suited the the kerb weight of the vehicle.
Posted : 14/08/2011 7:11 pm
As Carlos said....
I would be surprised to hear a tyre manufacture recommend otherwise!
Posted : 14/08/2011 7:32 pm
There's about 15% difference. I was surprised myself.
Posted : 14/08/2011 8:12 pm
I too would go with the original recommendations with one word of warning-if the sidewall construction of the tyre is significantly different in construction from the original ie old fitted tyres were steel braced radials as opposed to aramid fiber with less/no steel bracing then I would suggest the higher pressures to prevent tyre roll. I know that on my VW Passat Estate on an R plate there is a selection of tyres in the size with different side wall characteristics/build. Any knowledgeable tyre fitter/suppiler should be able to point you in the right direction if you are still unsure.
What sort of psi on what tyre/vehicle/axle?
Posted : 14/08/2011 9:59 pm
Tbh I set my own tyre pressures depending on time of year and tyre fitted.
Need more information though - car, age, type of tyres, pressures you are referring to etc etc.
Posted : 14/08/2011 10:07 pm
Not related but....... I thought my tyres looked flatish on my Golf on Friday (first time checking the air pressures since buying 🙂 ) the fronts had 11psi & 16psi in and the rears 20psi. All now have 35psi, so I'm expecting higher than the 44mpg I've averaged over the last 2.5k!!
You are one lucky man who has not had a blow out on a motorway or other fast road and a big accident. Hope you check them weekly if not monthly from now on. I could go into full rant mode but its late....
Posted : 14/08/2011 10:11 pm
No need to go into a rant I'm fully aware. Hadn't drove the car much recently.
Defo will be checked every time I fill up as a matter of course!!
Posted : 14/08/2011 10:15 pm
The tyre manufacturer states the MAX pressures, surely?
Tyre pressure depends on the weight of the vehicle, how would the tyre manufacturer know that?
Posted : 14/08/2011 10:27 pm
Good man-just a word of caution if you have been running them at that lower a pressure for so long the sidewalls are probbaly damaged significantly and will be weakened and could still be in danger of an unexpected blowout. I would suggest for safety's sake that you take the car to a reputable tyre fitters for them to examine all the tyres and reseat them if they are not damaged as it may be that they are leaking from the beads/not seated. If you dont want to take each wheel off the car yourself to examine the inner and outer sidewalls for any cracks/wear of surfaces or blistering. Its not the legalities that concern me but you and your passengers safety. Hope it doesnt work out too expensive for you.
Posted : 14/08/2011 10:40 pm
I would go with the tyre makers recommendation for your vehicle. 🙄
Posted : 15/08/2011 5:57 am
From where did you obtain the tyre manufacturers recommended pressure?
Normally speaking, tyre manuafacturers 'recommendation' charts are only a compilation of the car manufcaturers data.
Posted : 15/08/2011 6:22 am
