[Closed] Car transmission makes a noise when moving off – Should I think about selling a
2010 1.8 DTCi SMax. 88k on the clock.
Moving off in first gear I sometimes get a “screech”, but only at revs just above tick over. More or less revs and there is no noise.
No funny smells.
No evidence of slipping as it pulls normally at low and high speed.
No vibration, or other noise.
Shall I brace myself for a whopping bill?
I'm going to guess....kidney?
Or child. It certainly won't be a bike.
Worn fan belt?
I got a screech like that from my 2004 Focus - same engine - that turned out to be the coupling between alternator and the pulley that drives it.
Is it definitely the transmission? If theres no slipping of the clutch could it be a drive belt to the alternator or power steering having a bit of a squeak?
Try cracking an egg into the radiator
Sounds cheaper than a clutch!I got a screech like that from my 2004 Focus - same engine - that turned out to be the coupling between alternator and the pulley that drives it.
Yup, sounds like something belt / pulley related
Potentially a failing/failed Clutch Release Bearing.
Brakes and/or brake seizure non release of handbrake fully or calipers binding...
suspensionkoala could be loose
[img]
?imwidth=1240[/img]
[url= http://www.telegraph.co.uk/news/2017/09/16/koala-takes-10-mile-road-trip-hiding-behind-car-wheel/ ]http://www.telegraph.co.uk/news/2017/09/16/koala-takes-10-mile-road-trip-hiding-behind-car-wheel/[/url]
dry spigot bearing on end of crankshaft/gearbox input shaft.
Could be contamination on the clutch plate.
Have you checked the flux capacitor?
[img] http://www.backtothefuture.com/news-events/news_images/1_FC-PartI_850.aspx [/img]
