Car Problem!
[Closed] Car Problem!
Any Mechanics on line?
I am having trouble with the rear lights on my car, the R/H light is a lot less bright than the the left one. I think it may be an earthing problem but I do not know what I should be looking for i.e wire/connector/other can anyone give me some advice. By the way the car is a VW Bora Sport.
Cheers.
Posted : 17/05/2009 11:34 am
Silly Question: if you checked it has one bulb in both sides, have you tired swapping the bulbs round to mimic on opposite lights?
I would clean the contacts. Check water seals.
I had a prob with a Ford with this once and Ford fitted a new loom!
Same result so I wired up a cable from the brake light switch to the rear lights-sorted.
Posted : 17/05/2009 11:56 am
I have put a new bulb in just in case, same result. Contacts are all clean.
Posted : 17/05/2009 12:03 pm
Grab a manual, or track down the earth point for the rear lighting, it'll be somewhere near the back of the boot and fairly obvious if you pull out a few panels.
Posted : 17/05/2009 12:08 pm
Yep sounds like dodgy earth. Normally bolted in the rear somewhere.
My old mans Beemer has the same prob, put a new (crimp)loop terminal and cleaned up the earth contact and bingo.
Posted : 17/05/2009 12:18 pm
Posted : 17/05/2009 12:55 pm
Another quick one to check is that the brighter bulb isn't a stop/tail lamop and been fitted the wrong way round as i have seen a lot likt this.
Posted : 17/05/2009 1:11 pm
