Car headlights at n...
[Closed] Car headlights at night
[#5842872]
You MUST ... use headlights at night, [u]except on a road which has lit street lighting.[/u]
https://www.gov.uk/general-rules-all-drivers-riders-103-to-158/lighting-requirements-113-to-116
Seriously?!
Via Carlton Reid on Twitter.
Posted : 10/01/2014 12:14 pm
You [b]should[/b] also
use dipped headlights, or dim-dip if fitted, at night in built-up areas and in dull daytime weather, to ensure that you can be seen
I wonder if contravening the 'should' would contribute to careless driving or some other catch-all offence..?
Posted : 10/01/2014 12:18 pm
not much point having reflectors on my pedals if the cars aren't emitting light to be reflected...
Posted : 10/01/2014 12:20 pm
Yes, it's all very wooly - is "must" legally stricter than "should" and which over-rules which?
of a similar subject is th eUK history of a dim-dip lamp circuit in 1987
http://dastern.torque.net/techdocs/dimdip.html
Then the EC told the Uk to stop being prats and got rid of the dim-dip requirement. The landy had a dim-dip relay in it that, as usual, had failed. I have taken it out now.
Posted : 10/01/2014 12:28 pm
Shall and should mean a duty on a person; must means 'is required to' and usually is referred to an object. So 'you should use your lights' v 'your lights must work'. They're equivalent really in terms of legal weight.
does that not mean sidelights are ok under street lighting. Not ideal for sure. but it doesn't mean no lights.
Posted : 10/01/2014 12:29 pm
'Must' means there's a law backing it up. 'Should' is just a recommendation. E.g. you 'should' wear a helmet and hi viz on a bike. You 'Must' have a red rear reflector (after dark).
edit:
Grizedaleforest, do you mean in the general grammar sense, or in the highway code specifically. In the highway code "MUST" is backed up by a law. E.g.
[u]114[/u]
You [b]MUST NOT[/b]
use any lights in a way which would dazzle or cause discomfort to other road users, including pedestrians, cyclists and horse riders
use front or rear fog lights unless visibility is seriously reduced. You MUST switch them off when visibility improves to avoid dazzling other road users (see Rule 226).
In stationary queues of traffic, drivers should apply the parking brake and, once the following traffic has stopped, take their foot off the footbrake to deactivate the vehicle brake lights. This will minimise glare to road users behind until the traffic moves again.
[b]Law RVLR reg 27[/b]
[u]115[/u]
You should also
keep your headlights dipped when overtaking until you are level with the other vehicle and then change to main beam if necessary, unless this would dazzle oncoming road users
slow down, and if necessary stop, if you are dazzled by oncoming headlights
[u]116[/u]
Hazard warning lights. These may be used when your vehicle is stationary, to warn that it is temporarily obstructing traffic. Never use them as an excuse for dangerous or illegal parking. You [b]MUST NOT[/b] use hazard warning lights while driving or being towed unless you are on a motorway or unrestricted dual carriageway and you need to warn drivers behind you of a hazard or obstruction ahead. Only use them for long enough to ensure that your warning has been observed.
Posted : 10/01/2014 12:30 pm
God. Brings me on to the number of people I see, on the motorway, with side lights and fog lights on. Truly baffles me how they can see ANYTHING. Probably see 10 of these people a week.
Also don't think people realise fog lights are not daytime running lights, and it's actually not allowed to use them unless in low visibility conditions. I do the kind thing and flash them a full beam and fog light combi to let them know. No one ever reacts.
Posted : 10/01/2014 12:31 pm
The "people who sit in a traffic queue with their brake lights on" thing annoys me too. Though not as much as the other half - she wants one of those high-power lasers so she can pop their tyres from inside the car.
Posted : 10/01/2014 12:34 pm
"side lights" need to be renamed as "parking lights"
And manufacturers should be discouraged from illuminating the dashboard
lights unless the headlights are lit so that drivers cannot drive around with no lights on oblivious to the fact.
Posted : 10/01/2014 12:56 pm
edit:
This was from a law course I did once. Here's a bit [url= http://www.translegal.com/legal-english-lessons/shall-vs-must ]I've just found on the web[/url]. However can't argue with your explanation and the way the Highway code snippet is worded!
Posted : 10/01/2014 12:57 pm
This was from a law course I did once. Here's a bit I've just found on the web. However can't argue with your explanation and the way the Highway code snippet is worded!
You're probably right for a day-to-day sense, but for the highway code specifically they use 'must' to refer to something that has a law behind it.
Posted : 10/01/2014 1:01 pm
You're annoyed because you don't have an automatic car?
And a lot of cars (especially the VAG range) have DRLs built into the fogs so it looks like people are driving around with their fogs on (but they're dimmed vs actually having fogs on). Agree though, you can't go anywhere without seeing some idiot with their actual fogs on no matter what time of day or night it is.
Posted : 10/01/2014 1:13 pm
Automatic cars still have handbrakes usually, don't they?
Posted : 10/01/2014 1:19 pm
A lorry driver mate says rear fog lights should be banned. His argument being that, aside from misuse, they encourage people to drive faster in poor conditions. I know what he means, but suppose ultimately that way of thinking would take us to no rear lights at all.
Dont think this will make any difference
Was driving out of Lakeside the other day behind a guy with no lights on about 9:30pm. Gave him a quick flash as a reminder but nothing, pulled up alongside at the traffic lights and his entire centre console was black. So he had no idea how fast or where he was going. Mental.
What really winds me up is the latest craze for a fog light to illuminate when people are turning a corner. Why? Can you suddenly not see round? Headlights are designed with almost 180 degree lighting so you can see as you drive around a corner.
Posted : 10/01/2014 1:24 pm
I reckon I've been online pretty intensively for the last fifteen years and that that is the most boring link I've ever read.
Posted : 10/01/2014 1:36 pm
OK, I'll rephrase my statement. You've never driven an automatic have you?
I sometimes wonder if rear fogs are a UK only requirement. The switch is usually amongst the auxiliary buttons rather than with the rest of the lighting controls. In my van the switch isn't illuminated and for most drivers (depending on their height) its occluded by the steering wheel too so you have to feel for it on the dash.
Posted : 10/01/2014 1:37 pm
The Highway Code is a code of conduct, not a book of laws, although laws are also listed in it. But for drivers the knowledge of, and adherence to, the code is one of the conditions that your license to drive is contingent on.
So a 'should' is only advice for pecs, cyclists, horse riders and the like because their use of the road isn't restricted by a license, but its more onerous for a driver as they can only use the road with the permission of that licence.
Posted : 10/01/2014 1:47 pm
Hear ,hear
Side lights only available with engine off.
Posted : 10/01/2014 1:52 pm
The whole brake lights in a queue thing really annoyed me too, until I saw your comment. Forgot you have to sit on the brakes in an auto. Some brake lights, then, are overly bright. Gives me a splitting headache when I've got a new audi or BMW in front with the driver resting his foot on the brake pedal.
Having your brake lights on in a queue is safer IMHO - makes some of the less observant drivers think that your car is at most slowing and may be coming to a halt and encourage them to react by braking in good time.
Fog light use front or rear when not in fog really annoys me. It is especially bad in rain, where it is so bloody dazzling!
I have LED running lights and they are bright enough to let me drive down out adjacent unlit rear access - even when pitch black. I think they should probably be a bit dimmer - I sometimes think they could dazzle...
Posted : 10/01/2014 1:57 pm
Singletrackmind of this parish came up with a great idea - Fog lights also switch on a speed limiter (20-30mph) - if the fog is bad enough to need fog lights then you need to be going bloody slow.
That'd stop the morons from using them in the rain.
Posted : 10/01/2014 2:00 pm
My car like many similar autos comes with a 'P' for Park and 'N' for Neutral. so auto drivers don't need to depress the brake to stay stationary... I choose to always depress my brake pedal though.
Posted : 10/01/2014 2:01 pm
http://www.legislation.gov.uk/uksi/1989/1796/regulation/27/made
Restrictions on the use of lamps other than those to which regulation 24 refers
27. No person shall use, or cause or permit to be used, on a road any vehicle on which any lamp, hazard warning signal device or warning beacon of a type specified in an item in column 2 of the Table below is used in a manner specified in that item in column 3.
Col
1 11
2 Any other lamp
3 Used so as to cause undue dazzle or discomfort to other persons using the road.
Given the intensity of some brake lights and having 'seen' a Merc with 3 high levels I wonder what a nice policeman might say
Posted : 10/01/2014 2:05 pm
I could give you all a very long lecture on the full legality of car lights and exactly why things are the way they are, historical background reasons, technical info, UN ECE homologation etc. but as that all seems a lot like being at work I wont (even though I am at work, so it would actually feel like work regardless)
However, if you really feel the need to trust your life while driving at night to a pair of 5w sidelight bulbs that would struggle to illuminate the inside of a small fridge...
..wanders off mumbling about the important and fundamental differences between Lumens and Lux.
Posted : 10/01/2014 2:11 pm
I think it means in a stationary queue. The advice in Roadcraft IIRC is, when you come to a stop, to show your brakes lights to make yourself more visible until the car behind you has stopped. Then you know that they've seen you and know you've stopped, so you release the brake pedal to avoid dazzling anyone (handbrake on, obviously).
The problem is people who sit at a long light sequence, completely stationary with their foot on the brake for a minute+, especially very recent cars with the really bright brake lights.
Roadcraft also says not to dab your brake lights if you're not actually slowing down. It's because when you actually do start slowing down the following driver is less likely to notice because your brake lights have been showing for the last 300 metres with no deceleration.
edit: Also annoying are people who don't use the handbrake or footbrake. They pull up to a red light on a slight upslope, come to a stop then roll forwards a few feet veeeery slowly. Then roll back down the hill a few feet. Then roll forwards again, then back, then forwards. YOU'VE GOT NO CLUTCH CONTROL, JUST USE THE BLADDY HANDBRAKE!
Posted : 10/01/2014 2:13 pm
ooo, muddy@rseguy - while you're around...
quick "work" question if you dont mind! 😉
This image on the westfield site shows where lights and reflectors need to be mounted to pass the SVA
the MOT however doesnt specify the exact location of the reflectors
http://www.motuk.co.uk/manual_150.htm
My dad wants to replace the reflectors on the back of his 1960's Austin Healey 3000 with indicators so that the stop lamp no longer acts as an indicator. He then wants to fit some reflectors to the underside of the rear bumper. They are likely to be very close if not lower than 250mm from the deck - would that be a problem for the MOT?
Posted : 10/01/2014 2:21 pm
That's exactly what I do!
Posted : 10/01/2014 2:31 pm
I appreciate that some brake lights are brighter than others. But are people honestly 'dazzled' by them? "a splitting headache" -really?
Is there a rabies outbreak I was unaware of? If not I think some people need to clean their windscreen or their glasses or their eyeballs properly 🙂
Posted : 10/01/2014 4:50 pm
"side lights" need to be renamed as [s]"parking lights"[/s] utterly pointless vestigial lights
Posted : 10/01/2014 4:54 pm
maccruiskeen - Member
Yep.
People who sit in traffic jams or at a level crossing with their foot on the brake - complete tools. Bit different if it's slow moving traffic and you are in an auto, but to sit at a level crossing with your foot on the brake for 5 mins rather than putting the handrake on (and the car out of drive if an auto) just shows a lack of consideration.
This has happened to me on occasion when driving back from night rides and I have debated the merits of getting my twin lumi's out and aiming them at the mirror of the offending car in front. Never done it ('cos if would be petty and stupid), but it has crossed my mind.
As for sidelights - pretty pointless, apart from as 'parking' lights. The ones on my Ibiza are particularly feeble.
Posted : 10/01/2014 4:59 pm
I never had the need to keep my foot on the break on an automatic just simply put it in neutral and apply the handbrake or place it on park.
As for the fog lights when turning a corner, they're not fog lights and are great for lighting up blind area that headlights don't catch. Handy for spotting pesky cyclists.
Posted : 10/01/2014 5:18 pm
I never realised being dazzled by break lights as an issue. I probably always sit with my foot on the break pedal if it's an incline/decline (and possibly also if it's flat?).
Using the hand break seems to be a very british thing to do - but I've started doing it more so since i got hit from behind when stationary.
Striving to not be a tool is always good - but I've never reflected on dazzling people with my break lights.
Posted : 10/01/2014 5:27 pm
Penny has just dropped about the automatic comment. You mean in stop start traffic not stationary got you now.
Posted : 10/01/2014 5:55 pm
My left or right "foglights?" turn on when I indicate.
I've wondered how this works with the law on foglights which says they MUST NOT be used unless the visibility is less than 100m.
My guess is through some technicality they aren't considered foglights otherwise the manufacturer would be selling an illegal car.
Posted : 10/01/2014 6:25 pm
I'm going to buck the trend here and say that I think the use of headlights during the day and dipped beam at night in built up areas is actually more dangerous than beneficial.
In poor conditions it's important to be seen and appropriate levels of lighting should be used in those situations. However in most daylight situations, or where there is adequate street lighting, the use of dipped beams is dazzling and/or spoils your night vision. It's harder to judge the speed of oncoming vehicles and bright lights can make it harder to pick out cyclists/motorcyclists.
I would not be surprised if a number of SMIDSY type accidents are due to the excessive use of lighting on cars.
Posted : 10/01/2014 6:32 pm
Stoner, I'm off work now (and slightly beered up) but here goes.
If you alter the lighting of your car from the manufacturers original specification without legal approval then you are effectively making the car illegal, it can also can screw the insurance too. This does apply even to classic cars when they are built to different specs and legislation compared to present day vehicles.
Moving the reflectors and fitting new turn indicators in a different position is probably a risk as the car could fail its MOT or be classified as unroadworthy if you are pulled over by the police ( if they know what they are looking at...)
Unless you get approval to do this by getting the car SVA'd and even then its not quite as simple as "I will just move them to this place as that's where I have space" However I would not recommend getting a classic car SVA'd either as it could fail on something totally different as its being tested as a modern car.
I could be wrong as I'm used to working on new cars where we have to fully homologate stuff to stricter rules
To be honest I would leave well alone and use hand signals! 🙂
Posted : 10/01/2014 8:16 pm
cheers muddy@rseguy.
Assuming (quite reasonably) that the fuzz wouldnt know the difference between the locations of the original rear lamps & indicators, then I guess it comes down to having a tame MOT garage. Which fortunately we do have. But it's still unclear on what basis the MOT could be failed anyway.
Posted : 11/01/2014 8:02 am
I drive an auto and usually keep my foot on the brake when stopped in traffic. It's a tall pick up too so suspect the lights are in peoples eyes.
I hadn't even considered it could be a problem before. I'll do my best to remember from now on.
Posted : 11/01/2014 8:33 am
Beggars belief. People use fog lights at the wrong time" "people use their brakes in queues"."I flash people to tell them they are wrong".
Are you lot very old? I see these things all the time, and just let them get on with it. Someone using their foglights does me no harm.
You lot would be shouting at cyclists for not having bells if you weren't cyclists yourselves.
Posted : 11/01/2014 9:01 am
I don't do that well with lights at night, I often feel dazzled. However I've never felt dazzled by brake lights in a queue. Well, maybe once or twice when very close to the car in front maybe, not sure.
Posted : 11/01/2014 9:10 am
