Car Battery - diffe...
[Closed] Car Battery - different physical size OK?
Just put a new battery in the car...should be the correct one as used the Reg number identifier on the Halfrauds site to get the correct car model yada yada. Anyhow, it is a different physical size....basically its only about 3/4 as long. Its gone in fine, and seems secure as a retainer bar sits across the top, but is there any rule that says the physical dimensions should be the same?
Posted : 11/01/2011 5:09 pm
a smaller form factor battery can still have the same Ah and cold cranking as a bigger one. Check the Ah and cold cranking figures against the specification for the car.
Posted : 11/01/2011 5:10 pm
OT: Do you hail from the mighty Middlesbrough? ๐Ÿ™‚
Posted : 11/01/2011 5:11 pm
Ex Parmo smuggler....live in Richmond these days.
Posted : 11/01/2011 5:31 pm
Posh! Was just curious as to your username. glad to know i'm not the only one. hope you sort your battery stuff out.
๐Ÿ™‚
Posted : 11/01/2011 5:33 pm
I remember once fitting the battery from a MkII Escort into a MkIII. It was a bit of a fiddle because it was a different shape, but I managed to jury-rig it.
Everything went well until I shut the bonnet after a job well done, to discover that the replacement battery was also a bit taller than the old one. The positive terminal earthed itself onto the rapidly descending bonnet, and the engine stopped abruptly to the accompaniment of a loud bang, a bright flash and the acrid aroma of electrical burning.
Posted : 11/01/2011 5:37 pm
