Please?
Doesn't seem a popular size.
Need to go from 1" down to ½"
In brass as the plastic one I used 4 years ago just broke.
[url= https://i.ibb.co/dtX1p7q/10mm-8mm-3-8-5-16-steel-reducer-hose-connector-joiner-1900-p-ekm-320x320-ekm.jp g" target="_blank">https://i.ibb.co/dtX1p7q/10mm-8mm-3-8-5-16-steel-reducer-hose-connector-joiner-1900-p-ekm-320x320-ekm.jp g"/> [/img][/url]
Larger one with a female thread and a smaller one with a male thread and screw them together?
Or two males and an interconnect?
Good idea but still can't find anything at the moment.
Back to Google.
have you tried 25(or 26) to 12 or 13mm ?
Have a look for Geka couplings they should be able to do it.
25 to 13 finds plenty of plastic ones, but no brass / metal.
Will take a look at Geka cheers.
Aha, Geka will do it. How well do they look together? Well enough to hang under the back of a camper van and occasionally get bashed on the ground?
They should be fine , we use them with our irrigation equipment so get dragged across concrete and occasionally get driven over.
Thinking of Margaret Thatcher on a cold day tends to make my hose reduce from 1" to 1/2"... Not sure that's helpful for your purposes though?
Sorted cheers. Finally found some barbs both with 1/2" threads and a coupler.
