[Closed] Buying artificial turf, any suggestions?
Artificial turf is a surface of synthetic fibers made to look like natural grass. It is most often used in arenas for sports that were originally or are normally played on grass.
It has so many advantages, such as:
1.Artificial turf from leading [url= http://www.ccgrass.com/about/ ]artificial grass supplier[/url] can be plant under any climate.It can keep the original color and condition.
2.Synthetic grass installed in a variety of base surface, but also on the basis of lower quality, you will not afraid of cracking.
3.Maintenance of artificial grass is simple, just rinse with water to remove dirt, with low maintenance costs, and also do not fade deformation characteristics.
4.Suitable for roof gardens,swimming pool surrounds and school field.
When it comes to the tips to buy artificial grass, several I know the following tips.
Climate matters.If you are looking for a low maintenance, Brand A and Brand B would be a good choice, while Brand C would be suitable if you want a frost-resistant variety. Cary Argos Turf, Village Green, Empire Turf, Palmetto Turf etc are some other varieties on offer. You should decide the kind of artificial turf that would suit your climate the best, and the effort it will need on your part to maintain it, before making a final decision. If you are not sure, you can always ask your short-listed turf suppliers to offer suggestions.
The size of the land you want to lay the turf. Since artificial turf is measured in square meters, you should have a clear idea about the size of turf that you would need before you seek no obligation quotes from a couple of turf suppliers.
Must ask 3 - 4 companies for price. You should always ask 3-4 companies to send you no obligation quotes, so that you can compare and pick the one that offers value for money. CCGrass is one of [url= http://www.ccgrass.com/about/ ]chinese artificial grass manufacturer[/url] i have asked.
Any others?
