Struggling to find an answer to this so I thought I'd ask the STW hive mind ๐
I have a kitchen that is separated from the lounge and stairwell by a single door, the door is currently a hardwood frame with 12 glass panels in it.
The question is, if I replace the door, do I have to replace it with a fire door?
Only if you are doing major building works to the property.
Not unless the existing door and frame are fire resisting, eg a lot thicker than a normal thickness door, unlikely that a 12 pannel door would be fire resiting
If it's your own home, no.
Gotta love the hive mind, thanks guys ๐
I thought that if you had more than two storeys then any door onto a landing / stairwell had to meet 30mins fire protection. Certainly when you do an attic conversion you have to swap out all hallway doors to fire resistant ones.
He's replacing doors not doing a conversion.
Yep, just decorating and a bit of plastering, no major work, house only has 2 levels.
Years back at work we had a visit by a fire officer who was not happy with the standard fire doors, So our MD just removed all the doors to all the offices, still remember the fire officers face when he returned ๐
20 mins is acceptable.
Standard 44mm will give you 30 mins, 54 mm will give you 60 mins.
Any glass needs to be pyrostop or similar.
And I'd suggest if that existing door was a fire door you'd be crying to the bank manager to get it swapped with the same amount of glass ๐
So long as its fitted in a suitable fire door frame, with intumescent seals all round and behind the hinges and any locks etc.
Not true project. Doesn't need intumescent in domestic. I thought it would but just built 5x 2 1/2 storey houses.
Holy thread resurrection.......
Drac - Moderator
What if the door he is replacing is already a fire door and there are no first floor windows that can be considered egress?
In the building regs, even when just replacing stuff, the idea on existing properties is to be at least, no less compliant than it was previously.
Edit: i do love the certainty, myself include, people have in their own comments based on very little information from the op, i love STW ๐
