Bristol: which bus ...
[Closed] Bristol: which bus number to go to Argos Racing Cycle from Temple Meads
Hi,
I try my best to work out which bus I should take to go from Bristol Temple Meads station to Argos Cycles. I found the nearest bus stop to the workshop, St Annes, but not sure of the number for the bus. The best I found was 36, but it does not pass via the train station. Any suggestion? probably I have to change somewhere. From the train station, which any bus numbers can I take to join the nearest bus stop for 36?
Cheers for any help,
Gilles
Posted : 25/02/2010 3:29 pm
 awh
Bike problems?
Posted : 25/02/2010 3:55 pm
bottom bracket shell worn out (drive side). TT cycles told me they can't fix it, has to be Argos. I heard that they are pretty good!
Posted : 25/02/2010 4:07 pm
 awh
I wont suggest combining it with a visit to Ashton Court then. How far is it? I have friends who walk from TM to the university and Floating Harbour areas every morning.
Posted : 25/02/2010 4:11 pm
transportdirect.info is your friend. Search a route between locations by 'public transport'. I've found it very good indeed.
Posted : 25/02/2010 4:15 pm
Bus? Seriously? It's not far to walk, under 2 miles. Could be an PITA if you've got to carry a lot though.
Posted : 25/02/2010 4:17 pm
You could walk it - it's 1.5 miles:
[url] http://maps.google.co.uk/maps?f=d&source=s_d&saddr=bristol+temple+meads&daddr=Bristol,+Avon+BS4+4ED,+UK&hl=en&geocode=%3BCUsdt4sRcGpeFfAXEQMdnBPZ_ynX5qHqU45xSDHYx9tYZkV7EQ&gl=uk&mra=ls&sll=51.451888,-2.550884&sspn=0.01031,0.019376&g=Bristol,+Avon+BS4+4ED&ie=UTF8&z=15 [/url]
otherwise number 36 (blue line heading down and right from Bristol City Centre) and stop just after you cross the river/feeder. You'll probably have to walk to the bus stop to catch it though.
[url] http://www.firstgroup.com/ukbus/southwest/bristol/map/bristol/bristol_overground.pdf [/url]
Posted : 25/02/2010 4:19 pm
The busses down that way are terrible! Expensive and take for ever. TBH you are probably as quick walking- it's only a mile or so.
Posted : 25/02/2010 4:20 pm
or get a taxi - won't cost a lot for 1.5 miles with little traffic.
Posted : 25/02/2010 4:21 pm
Or post the frame?
Posted : 25/02/2010 4:24 pm
mmm I will walk then. I can post the frame but I like to have a chat with them to understand why it went wrong like that. Thanks guys.
Posted : 25/02/2010 4:49 pm
Strip the frame and tie it up to a backpack etc now you can walk or cycle there now.
Posted : 25/02/2010 7:42 pm
Posted : 25/02/2010 7:46 pm
