Bread Makers ,crumb...
[Closed] Bread Makers ,crumbling at day 2
Hi folks, make my own bread n rolls from the good flour in Aldi n seeds pine nuts .
Tastes good on day one but by second day it's crumbly n dry n day three a sausage "buttee" is a disaster .
More water , flour quality, oven temp ???
Advice please .
Posted : 21/10/2019 12:47 pm
more oil/butter?
Posted : 21/10/2019 12:48 pm
Proper bread needs fat (in the form of butter or olive oil) to make it last. For 500g of flour you want to add about 30-35g of 'fat'.
Posted : 21/10/2019 12:50 pm
I use olive oil , so perhaps more then usually just wizz the bottle round the bowl once or twice .
Posted : 21/10/2019 12:54 pm
Its more than you think. If you don't use digital scales already I'd recommend them as volumes can be fairly critical.
Edit: even then, don't expect bread (especially rolls) to last as log as the plastic versions.
Posted : 21/10/2019 12:56 pm
Proper bread that's not full of 'improvers'and additives doesn't last unfortunately.
Fat as mentioned above is one way to do it. Other way is to 'refresh' the bread - wrap it in baking parchment and stick it in the oven for 10-15 minutes on about 180/200 (this all depends on your oven) - the crust will sort itself out and the crumb will soften.
You can do this several times.
I tend to make several loaves at a time, then when they're cool, cut and freeze sliced. You can then pop then in the toaster from frozen, or use the above method of you want bread.
Posted : 21/10/2019 1:02 pm
