Bouncy Floor Joists...
[Closed] Bouncy Floor Joists - Help!
So i'm working my way round the new 'old' house and have a slight problem with the floor joists downstairs.
I removed a (decorative) brick fireplace and it looks like the support pillars under the floor joists have dropped a little at some point so now there is about 1/2 inch of bounce - i guess the weight of the fireplace was hiding this and they have risen up now it's gone.
I am thinking it will be fine to just jack up the joists (assuming they are in good nick) and add a wedge on top of the original brick pillars to remove the gap.
I am hoping this has happened over a long period of time (house is 1930) in which case further movement should be mininal....
Or should i call in the professionals for a more detailed survey / investigation of the problem!?
Would appreciate any suggestions?
Posted : 30/08/2013 2:12 pm
strip floor boards, investigate whats going wrong- could be rotten timbers, warped over time or the supporting wall could have subsided. Carry out remedial works as required
Posted : 30/08/2013 2:15 pm
Don't call professionals, they will recommend all kinds of solutions. Follow your instincts.
Thanks...
I have had a good look under the boards & joists. All seem to be fairly sound, no rot or anything like that.
Just not sitting firmly on the the supports. An eyeball investigation suggests that the supporting wall has dropped a wee bit.
It only affects the end support row, all others are sound.
But i want a floor that doesnt move so much.
Posted : 30/08/2013 2:22 pm
if its not damp or rotten
just resupport it .
if i stacked a heap of bricks on top of you for 80 years and then removed them i doubt you would return to the same height either !
Have you experienced bouncey floor boards before?
Nothing to be embarrassed about.
http://www.****/health/article-2406651/Healthy-obesity-exists-say-scientists-physical-fitness-important-BMI.html
Posted : 30/08/2013 2:27 pm
I'm just big boned
Posted : 30/08/2013 2:34 pm
I had a bit of this in a property I renovated a few years ago.
Basically the extension had moved a little and allowed some slack in the joists. After checking online I fixed it by jacking up the joists with an acro-prop and then packed the bottom with slate, then dropped the joists back down.
It has been fine for 5 years so far since, with no further movement.
As others say if you think there is rot then poke around, if not slate is your answer!
Posted : 30/08/2013 4:14 pm
Cheers ali, a friend (who built his own extension) had a look and also suggested this.
I think i will get me some slate.
What Slate For Joists Over Chalky Soil thread to start soon... ๐Ÿ™„
Posted : 30/08/2013 4:32 pm
Welsh!
๐Ÿ˜†
Posted : 30/08/2013 4:33 pm
Spat tea.
Posted : 30/08/2013 4:36 pm
...actually - where is the bet place to get slate!?
Posted : 30/08/2013 8:44 pm
Wales?
Posted : 30/08/2013 8:48 pm
Next doors roof?
Posted : 30/08/2013 8:59 pm
Wales, thanks, I will keep an eye out for any Bales
Posted : 30/08/2013 9:10 pm
ย I will keep an eye out for any Bales
I would, you'd make about 70mil profit on each one.
Posted : 31/08/2013 3:36 pm
You might want to consider why the wall has sunk. This is definitely a bigger issue than the bouncy joists which are a result of a bigger underlying problem from what you describe.
There could be a broken drain or some other reason there is subsidence. Either way jacking up and packing the joists is not a permanent solution unless you can confirm the subsidence has halted or been resolved.
Posted : 31/08/2013 6:34 pm
