Bodgers question - ...
[Closed] Bodgers question - screws in plastic, getting them tighter
I've got a dishwasher that is leaking slightly because the bottom plastic tray with the filter/motor in it isn't attached tightly enough to the main chamber. One of the 4 screws that holds it in place feels like it will strip if I turn it any tighter and it really isn't very tight at the moment. The rest feel normal
So, the question is can I do anything to make the screw tighter. If it were going into wood a matchstick would work but I'm not sure what I can use here. Would hard plastic glue do it for example or is that not structural enough
Posted : 01/11/2017 10:42 pm
Fill with epoxy and let dry.
Then drill pilot hole and fit screw.
Other wise through drill and epoxy a nut on the other side of possible ?
Posted : 01/11/2017 10:49 pm
Not a bad idea on the epoxy and pilot hole. Might try that
Can't drill all the way through though because of where it is
Posted : 01/11/2017 10:55 pm
You could removed the tray and apply a bead of silicon sealant before reassembling.
If needed you could break the seal in the future with a Stanley knife.
Posted : 01/11/2017 10:57 pm
You could use a slightly bigger screw. As in fatter not longer.
Or can you drill a new hole 10mm to the side of the existing hole and so have a new fastening place?
Posted : 01/11/2017 11:00 pm
that might be possible actually. It goes into a pillar but it's quite large
I decided against the silicone route as I don't know how it will react to the dishwasher chemicals and I'm trying to avoid dismantling the while thing if I can just bodge it
Posted : 02/11/2017 7:34 am
If the "fatter" screw is too long , just cut the end off , or pack it with washers.
I've got loads of self tappers in the shed you could have.... ๐Ÿ™‚
Posted : 02/11/2017 7:55 am
