Blood test question
[Closed] Blood test question
How long does it take for the body to replace blood after blood tests? I'm meant to get a test tomorrow, but I'm feeling really run down/anaemic at the moment and wondering whether I should delay my tests until I'm feeling better...?
Posted : 13/01/2010 4:49 pm
A standard FBC, U&E, clotting and a bit for luck comes in at about 15mls, and your total blood volume is about 5 litres.
It's not a lot of blood, and certainly not enough to make the slightest difference to you, anaemic or not.
Posted : 13/01/2010 4:53 pm
How much blood do they take at your Docs?? Mine only take a small amount, Are you sure they're not vampires??
Posted : 13/01/2010 4:54 pm
 jond
Mebbe more reason to have the blood test now ? - it'll tell you if you really are anaemic, rather than just feeling a bit run-down - a few times whilst at uni I was turned away from donating blood 'cos I was anaemic, despite feeling fine.
They don't take that much blood IME, certainly nowhere near as much compared to donating blood.
last time i had tests done, they took 3 syringes full. i don't think it will be that much this time but i usually feel faint and or pass out afterwards. i'm not getting tested for anaemia so it won't make a difference to the test - i'm just wondering whether its a good idea when i'm feeling so bad. ๐Ÿ™‚
Posted : 13/01/2010 4:58 pm
The three syringes normally total 15-20 mls,not enough to have any physical effect.Based on the usual haematology rule of thumb,that 500mls is replaced in a week,it will take about 16 hours to replace,unless you have a serious problem,in which case,the result is more important than the blood loss.
Ian
Posted : 13/01/2010 5:04 pm
according to my sister who works for the vampires(national blood service)the fluid taken during a full donation is replaced in about 24 hours , the red and white cells/antibodies ect take about 72 hours so you should have your 15ml back in an hour or so.
Posted : 13/01/2010 5:08 pm
 ski
You could be like me and needles just make us feel faint ๐Ÿ˜‰
Speak with the Nurse/Doc if you are concerned.
Posted : 13/01/2010 5:11 pm
Its four months between blood donation appointments but I think the fluid lost is replaced within 24 hours - and that's a whole pint! A bit longer for red blood cells to recover.
Have a couple of pints of Guinness the night before?
Make sure they know when they take the blood that you need plenty of recovery time and a cup of tea. Don't let them whisk you out.
okay, i guess i will have the test then. i just don't really want to feel worse than i do at the moment whilst i'm "lower" on blood even if its not that much (i'm seriously struggling to function normally, no energy, can't sleep etc and my iron tabs are taking a while to kick in)
ski, its not the needles as i don't look and i'm fine when i get acupuncture. it happened when i got my piercings as well, just a blood sugar/adrenaline thing.
Posted : 13/01/2010 5:17 pm
 ski
Guinness sounds a good cure, must try that one ๐Ÿ˜‰
Posted : 13/01/2010 5:26 pm
