Bit of an emergency...
[Closed] Bit of an emergency: Can you answer a car wheel question?
I need to get two replacement wheels for my Peugeot Boxer, and someone on ebay is selling exactly what I need. Or at least I think so.
The size of my wheels is: 6J x 16H2 ET68
The seller's is: 6J x 16H2
however, he says nothing about the last bit. His are from a Fiat Ducato.
Should I assume that they will be exactly what I need? If the ET## bit is different to mine, will they still work?
Any help much appreciated!
Posted : 03/02/2017 11:38 pm
ET is offset. Needs to be the same or very similar I'd say
Otherwise width and diameter is the same but it might not be positioned right against the hub
Not sure how much variation there is in that wheel size though
Posted : 03/02/2017 11:41 pm
Fiat Ducato wheels are also ET68.
They will be fine.
You can use wheels with a different offset though, they would just sit further in/out depending on the change.
Www.willtheyfit.com
Posted : 03/02/2017 11:44 pm
 P20
Isn't it the same van with different badges? Should be a straight fit I'd have thought.
[url] http://www.wheelfitment.eu/car/Peugeot/Boxer%20(2006%20-%20).html [/url]
Posted : 03/02/2017 11:47 pm
Buy them. If they don't fit put them back on ebay.
Posted : 03/02/2017 11:54 pm
I have just notified the seller that I shall buy them.
Thanks all. You are great. 8)
Posted : 04/02/2017 12:04 am
