I used to read some of the competitions mags but got sick of the obsession with 0.007 of a degree geometry meaning you’ll transform into a god or a demon and the obsession with classifying updown shake it all around country.
Anyway, popped into my local library and discovered I can get both MBUK and MBR free in digital format via the library app.
Useful for the ride location info but the days of paper pullout and an actual printed map of the route have gone in favour of bit.ly links.
Not a single link opens. What gives? Is there some secret way to get a link to open?
Have seen a few forums not able to open bit.ly links but never an actual solution!
Try copy/pasting it.
No joy there. Just a “server not found” type message.
I’m trying to do it on Safari….are they the sort of thing that needs more freedom via windows / PC?
A bit ly link is just a shortcut to a longer url. If the url is points to is no longer there or has changed, then it won’t work.
Case-sensitive?
Does the URL change when you get that error? What does it change to?
