Bikes with drops, f...
[Closed] Bikes with drops, fat-ish tyres and MTB gears
What's out there? I'm aware of Salsa's offerings, but you cannot get Genesis Longitudes any more.
Posted : 18/11/2021 12:04 pm
Smokestone  Mr Harry.....
Posted : 18/11/2021 12:09 pm
Nice, that, but not cheap.
Posted : 18/11/2021 12:16 pm
Mason ISO?
Posted : 18/11/2021 12:23 pm
Mason looks like a Cutthroat but in alu and more expensive.
Posted : 18/11/2021 12:25 pm
Brother Cycles, Big Bro.
Posted : 18/11/2021 12:26 pm
pipedream alice?
To get MTB gears in terms of high range 1x I think you need electric shifting or aftermarket mods.
Posted : 18/11/2021 12:45 pm
and in a lineup of lovely looking frames, it is the one hit with the ugly stick
Posted : 18/11/2021 12:48 pm
On One Free Ranger with a smaller chainring swap?
Posted : 18/11/2021 12:52 pm
 PJay
There's been a 'new' version of the Singular Swift in the pipeline for a long time now but it's failed to appear. However, since the new Peregrine is due early in the Spring, a new Swift (or other suitable steel Singular) might show next year.
If you're flush, a titanium Pegasus and Gryphon are also available!
Posted : 18/11/2021 12:57 pm
How fat do you consider fat tyred?
And by MTB gears are you specifically wanting a 10-50 1by drivetrain with clutch, or are you just wanting a range that allows off road climbs and road sprints?
Posted : 18/11/2021 1:00 pm
You didn't mention cost....
In that case..... (They also do a 'cheap' ti version)
https://nordestcycles.com/en/product/albarda-2-frame
Posted : 18/11/2021 1:37 pm
Kona Sutra LTD. Super bike and (reasonably) cheap.
Posted : 18/11/2021 8:30 pm
I just popped another £100 off this as we are trying to freshen up the display...
https://www.pedalsbikecare.co.uk/products/2020-bombtrack-hook-adv?_pos=1&_sid=34b05bedd&_ss=r
Posted : 18/11/2021 8:45 pm
A Longitude won’t really take drop bars, it’s too long (otherwise mine would have some on)
There’s usually a couple of hardly used ones for sale on FB tho. I got mine that way, it only had about 60 miles on it.
The Vagabond is designed for drop bars and 29er with 2.1 tyres but will go fatter. Mine came with a 2x10 Deore MTB setup
Fugio also (27.5/29)
Bombtrack Hook EXT?
Bearclaw have some nice spendy offerings too
At the other end of the budget scale there’s Polygon Bend R2 or Bend R5
Posted : 18/11/2021 9:32 pm
stooge rambler
Posted : 18/11/2021 9:33 pm
take advantage of the longitudes terrible depreciation - i have (twice)
https://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p2380057.m570.l1313&_nkw=genesis+longitude&_sacat=0
Posted : 18/11/2021 9:39 pm
 aP
Whilst the mason ISO isn't the most elegant bike, it rides superbly and will take 2.8" tyres easily. The structural mudguard is really useful for packed riding as well.
I'm waiting for the Rambler - then herself and I will be matched in terms of rubber 😉
Posted : 18/11/2021 10:31 pm
Well this is for my mate who likes woodsy Chilterns riding but is a roadie, so he likes drops for distance and needs low gears for steep bridleways of which there are plenty round there. 50c might do it but probably 2.1 at least would be required IMO.
He's quite taken with the Stooge Rambler but f me that stem it comes with.. urgh.
Posted : 18/11/2021 10:44 pm
my rambler has normal stem rather then super steep mone one. goes like a fker with 27.5 2.5 rubber on it.
Posted : 18/11/2021 10:47 pm
 aP
The Rambler doesn't come with a stem. It's frame and fork only. The moné stem is a neat solution for what it's supposed to do.
Posted : 18/11/2021 10:48 pm
Go retro or go home!
Posted : 18/11/2021 11:17 pm
I really want an iso, but it's dream bike money for the GRX DI2 I fancy 🙂
Posted : 18/11/2021 11:21 pm
The new Fearless, whatever it's called, will take 50, I think. The newer Croix de fer claims clearance for 45 or 50.
The Light Blue Darwin Darwin will take 50, and there is an optional fork that'll take a 2.1. if you've got the readies you can get a galvanized one. Adjustable dropout at the back. I quite fancy one. Imagine doing chip touch ups with a soldering iron!
Posted : 19/11/2021 3:00 am
Shand Bahookie..?
Stock build or custom geo.
Bit expensive but at least it's made here, not Taiwan/China.
Posted : 19/11/2021 8:23 am
https://www.gooutdoors.co.uk/16185429/polygon-bend-r5-gravel-bike-16185429 might fit the bill, loads of clearance up front, but limited by 420mm chainstays on the rear.
Posted : 19/11/2021 8:59 am
This came up on my YouTube feed this morning. He builds one out of a canyon 29er. Still only standard gravel gears though.
Posted : 19/11/2021 12:43 pm
They want a Thunderhawk
Posted : 19/11/2021 1:55 pm
OK so your into main stream gravel bike territory there provided you accept the compromise of 650b.
My mutant bike fits this brief and does get ridden in the Chilterns alot. Although the far East which is a touch smoother and less steep
It started out as Arkose but with the old model with a less wide fork. Step one was lower gears. Spa cycles chainset 38 26 and 36 11 cassette. This works with my road shifters amd mech just fine. Then I fitted a wider for and built up done 650b wheels. These ran 50mm tyres all summer I now have something a little narrower on. It's turned about to be great fun off road
Ideally I'd have a space 2.1 inch tyres but it's not the end if the world. I thought 650b would be a bit rubbish but they work fine and the bike feels lively and fun
Starting from scratch I'd build up a Sonder Camino. But there are loads of suitable bike out there
With cash to burn maybe a Fairlight secan
Kinesis do an alloy gravel frame as do ribble. Both sold as taking 650b 47mm tyres. But the tyres I ran last summer were badged as 47mm but were actually 50mm. Ask for owner feed back but I think they'd do
Posted : 19/11/2021 6:20 pm
Stayer Groadinger OG+ looks nice, up to 2.3" clearance
Posted : 19/11/2021 7:20 pm
@stainypants - that is so much a copy of the Tomac Yeti I posted above, except he’s gone for what look like carbon rigid forks, instead of the Manitou suspension forks on Tomac’s bike.
I saw Tomac ride at the Vail Worlds, in ‘93, or was it ‘94, not sure; amazing rider.
Posted : 19/11/2021 9:52 pm
Singular Swift
https://flic.kr/p/2mJqZgQ
Posted : 19/11/2021 10:45 pm
Just to say I was in Vail too
1994 I think
Posted : 19/11/2021 11:06 pm
@countzero if you watch the beginning of the video there’s a absolutely gorgeous replica of Tomacs bike he then builds the Gravel bike as a tribute to that bike using modern components.
Posted : 20/11/2021 1:08 am
