Best way to remove ...
[Closed] Best way to remove a tick head
 DT78
So just noticed I have what looks like the remains of a tick attached to the inside of my elbow, think I must of accidently scratched the body off, or it is really small (about 3-4mm across)
How should I remove it, what else do I now need to worry about.... googling is worrying me....
Posted : 01/05/2012 3:00 pm
I can tell you that setting fire to it with a lighter is not the best idea, burning hair stinks 🙂
You can get tick remover tweezers or alternatively I've been told if you smear vaseline over it the tick starts suffocating and pulls itself out.
If it is just the head left I guess you'll just have to gouge it out, but hopefully there'll be a better way!
Posted : 01/05/2012 3:19 pm
Big Bowie knife and suck
It worked in all the films I saw as a kid - that was for snakebite though 🙂
Posted : 01/05/2012 3:27 pm
You will just have to remove the head with a clean needle. Nothing to worry about, I have had loads of ticks been tested for lyme when I'm worried. The sign to look out for is a large ring type rash around the bite. A tick should be removed with in 24 hours to minimise the chance of disease transition. Even if you do get ill the main thing is that you are aware of the risks and can get treatment quickly. Most people who have had long term illness have not realised it was caused by a tick therefore they may have not been diagnosed for lyme or treated accordingly. So to sum up don't worry, check yourself regularly and be aware of symptoms. A natural insect repellent works well.
Posted : 01/05/2012 3:39 pm
spando - Member
You will just have to remove the head with a clean needle. Nothing to worry about, I have had loads of ticks been tested for lyme when I'm worried. [b]The sign to look out for is a large ring type rash around the bite[/b]
The ring is not guaranteed to appear.
Posted : 01/05/2012 4:54 pm
When my mum had a tick on her back her doctor sent her to the vet.
Posted : 01/05/2012 5:00 pm
I thought the title implied you were Irish and had a hangover.
Ah, my coat's over there.....
Posted : 01/05/2012 5:03 pm
 DT78
Well looking closer it turns out its not just it's head as it;s legs are wiggling around, just a very small one. People have been telling me to go to a walk in centre to get it removed and not to try digging it out myself
Google tells me vaseline isn't a great idea and causes them to burrow deeper.
Posted : 01/05/2012 5:31 pm
Do not put Vaseline on it! If it is intact, you need to get it off in a way which does not cause it to vomit. If you can get to a vets, they will sell you some tick remover tools for about £4.
Posted : 01/05/2012 5:34 pm
If you don't have - and know how to use - the correct tool to remove it, get it done professionally. do not attempt to smother it, dig it out, drown it, poison it etc etc etc
Posted : 01/05/2012 5:36 pm
It's pulling out a tick, not open heart surgery. Pair of tweezers, grab it be the head as close to the skin as possible (you will have to press into the skin with the tweezers) and pull it out.
Tool does make it easier though.
Posted : 01/05/2012 6:26 pm
Tom o twister - 4 quid - DONT vaseline / burn it etc - can use a cotton lasso or tweezers BUT I would suggest a vet - doictors are very hit n miss re ticks
I have had lyme tests too - ticks arent to be taken lightly
www.bada.org.uk and lyme disease action are worthy reads on the web
paul
Posted : 01/05/2012 6:31 pm
 DT78
Ok wife got it with tweezers, tough little bugger. Off to worry myself silly by reading about lymes now. How do you get tested?
Posted : 01/05/2012 7:40 pm
