Best Padlocks?
[Closed] Best Padlocks?
15 Users
Fed up of mine rusting and seizing up. What are the toughest, most secure padlocks for general home use?
Posted : 04/02/2018 6:43 am
Alloy are pretty rust resistant and secure.  Like most padlocks they can be cropped with a pair of Records but Network Rail use them as a standard lock over most of the SE (you get the odd sticky one to open but on the whole the hundreds I use a year a pretty good).
Posted : 04/02/2018 8:04 am
I normally use a place called simplypacklocks and get outdoor rated ones. I still use a bit of Green Oil "slip" in all my locks though to stop them seizing (it's a bio based oil so doesnt matter if you get it on your hands for the first few times using the lock).
Posted : 04/02/2018 9:00 am
Sorry, missed the autocorrect it’s Abloy
Posted : 04/02/2018 9:05 am
Abus laminated
Abus that keeps my shed locked has been rust free and easy to open for about three years now.
One of these  http://abuspadlocksonline.co.uk/abus-padlocks-by-material/abus-laminated-padlocks/abus-41-30-laminated-padlock-keyed-alike.html
its not actually that big...
Posted : 04/02/2018 9:19 am
Same with everything. You get what you pay for. Abloy expensive but good.
Ive got a masterlock padlock as one of 3 on my shed. Doesn’t ever seize up whereas the other two do.
Posted : 04/02/2018 9:27 am
Squire?
Posted : 04/02/2018 9:36 am
Abus titalium, for the price they are excellent, well made and very secure.
Posted : 04/02/2018 12:01 pm
><span style="color: #444444; line-height: 15.360000610351563px; background-color: #fbfbfb;">Abus that keeps my shed locked has been rust free and easy to open for about three years now.</span>
The cheap ones on our garden sheds / ladders etc must be getting on for 20 years old now. Still work fine.
Posted : 04/02/2018 2:33 pm
Just oil the mutha.
Posted : 04/02/2018 8:48 pm
on youtube theres a guy picking a selection of diskus type locks. He gets into masterlocks in no time, Abus ones get harder to pick depending on price
Theyre harder to cut due to the shape
Posted : 04/02/2018 10:08 pm
 Gunz
WD40
Posted : 04/02/2018 11:25 pm
drip a small amount of chain lube into the key slot, and into the openings where the hasp goes into the body.
operate the lock a few times to move the lubricant around.
Repeat before each winter.
Posted : 05/02/2018 11:08 am
Squire Stronghold:
Choose Closed Shackle if you can.
https://www.toolstation.com/search?searchstr=89931%2059527
Toolstation is very cheap compared to some of the security specialists.
Posted : 05/02/2018 11:11 am
Abus diskus (hardened steel version), requires two cuts with bolt croppers which makes it harder, especially if you have a good hasp which makes it more difficult.
Posted : 05/02/2018 11:22 am
