Best and easiest fi...
[Closed] Best and easiest fire pit?
Really fancy a fire pit in the garden. Anyone got any ideas? Don’t really want to pay an artisan blacksmith to forge something up for £££. Is a simple brick one ok?
Posted : 30/08/2020 8:50 pm
 grum
I've seen ones made with old washing machine drums before but I think a bit of welding might be required ideally.
Edit: this guy uses a drill/screws
Posted : 30/08/2020 8:52 pm
My experiance of fire pits is that unless it's calm someone's always sitting in smoke.
I'm looking at a frontier camping stove for my garden
Posted : 30/08/2020 8:56 pm
I bought one from FB marketplace, half a gas canister cut in half with legs welded on. £25, works a treat.
It is a bit smokey though if you're sitting in the wrong side.
Posted : 30/08/2020 9:00 pm
I've got one of these for camping. Really good and can be had for a few pounds off eBay.
https://www.amazon.co.uk/dp/B08F7SG4ZY/ref=cm_sw_r_cp_apa_i_wN.sFbA6N20VY
Posted : 30/08/2020 9:13 pm
13kg gas bottle fill with water and degas then cut out 8” x 12” rectangular section out of face. Cut 5 or 6” circle out of top (basically remove handle from top where valve you’d be. Purchase 1m of solid stove pipe (5” or 6” depending on hole size)and weld on to create chimney. Best fire pit/out door stove going in terms of heat and also draws smoke up and away so it’s not swirling around you. A fabricator could do this all in an hour if you have stuff ready
Posted : 30/08/2020 9:16 pm
We used the washing machine drum as a fire pit when in the scouts.
Theres a spindle on the back that you can stick into the ground for some support, then we supported the rest on 3 bricks. There wasnt anything we couldnt sort with a hammer.
You could make a low brick circle, really only a couple of bricks high with a lip of snug enough so it slides in and is supported. Being removable, emptying it will be easier
Posted : 30/08/2020 9:21 pm
Unless you live in the middle of nowhere, could I ask that you consider not getting a fire pit.
Evil things.
Posted : 30/08/2020 9:58 pm
Place a dustbin lid on the ground, cut out the circle of turf, dig down around 4", sorted.
Posted : 30/08/2020 10:07 pm
Washing machine drums are petty efficient smoke wise becasue they get ALOT of air definitiely less smoke than some of the chimney round here spewing our thick grey smog from presumable damp wood. But ultimately its faff so rarely gets used
Posted : 31/08/2020 10:31 am
Does anyone have a metal chimnea / fireplace with chimney? I'm interested to know if they draw up better as they warm.
Posted : 31/08/2020 10:53 am
Does anyone have a metal chimnea / fireplace with chimney? I’m interested to know if they draw up better as they warm.
We've got a metal chiminea - don't notice a difference drawing as it warms, doesn't seem to to not draw up from cold, if that makes sense. I guess the chimney's too short for it to make a significant difference.
We're planning on building a simple firepit - circle about three foot across, dig down about six inches, line with a row of bricks on end and fill with gravel. Four simple benches around it and job's a good 'un.
Posted : 31/08/2020 11:08 am
My experiance of fire pits is that unless it’s calm someone’s always sitting in smoke.
get it hot enough & it’s not an issue. I’ve got a washing-machine one which is brilliant (loads of airflow as mentioned... it’s actually even better on a windy day as there’s so much air blowing through it!!) Chuck enough proper kiln dried logs on it plus I’ve got a little metal extending tube now which I bought for camping which lets you get it up to temp really quickly.
Posted : 31/08/2020 12:22 pm
I had a washing machine one, it was brilliant but my wife could only see it as a piece of junk from a washing machine, whereas I saw it as a nice perforated stainless drum that the heat had turned into a nice bluey purple! I lost and it ended up in the scrap metal.
Super easy to make, just unbolted the pulley and put it back on the other way so it raised the drum off the floor.
Gives off a huge amount of heat and burns nice and hot so there is practically no smoke.
Posted : 31/08/2020 3:53 pm
I also have the washing machine drum .... and would recommend one to anyone.
Posted : 31/08/2020 9:25 pm
The washing machine drum looks like a good call - and it's presumably a bit cheaper than a Solo Stove Bonfire. So, how do you get hold of a drum - the one in our washing machine probably needs to stay there?
Posted : 31/08/2020 10:54 pm
Check your local council estate. Or Facebook group, someone always wants one lifted.
Posted : 31/08/2020 11:10 pm
Another vote for the washing machine drum.
I ask at the local recycling place, they are happy for me to strip down a bust one.
Posted : 31/08/2020 11:55 pm
In Salford it’s traditional to use a Vauxhall Corsa
Posted : 01/09/2020 12:15 am
@onewheelgood just tell the wife her washing machine is broken and that she needs to buy a new one. Take the drum out of the current one. Viola.
Posted : 01/09/2020 12:57 am
I have a Weber fire pit. It wasn’t cheap but is beautifully made. I use it more than the bbq. I only burn properly dried wood. Smoke has not been a huge issue.
Posted : 01/09/2020 11:16 am
I like that Weber fire pit a lot, I’ll have it run it past the CFO tho.
Posted : 01/09/2020 5:21 pm
