Battery Charging - ...
[Closed] Battery Charging - advice please
I have a battery charger with an output rated at 8.5V DC / 1.8A - it's charging four of these:
http://www.dealextreme.com/details.dx/sku.5790
If I tried to charge them with a charger rated at 8V DC / 0.5A - what would happen ?
Posted : 16/09/2009 6:56 pm
I assume you're charging a pair in series?
8V wouldn't be able to charge a pair in series to 100% capacity - but would come pretty close - charging voltage is normally 4.2V per cell.
Posted : 16/09/2009 6:59 pm
The battery charger MUST be Lithium specific.
4.2V per cell is a very precise voltage. 4.1 is not enough for a full charge and 4.3 is too much. Also they don't take overcharge, so a decent charger will have a timeout facility.
There should be a balancing facility to ensure each battery has an equal voltage across it when charging. If you're making up a pack, the individual batteries should be UNPROTECTED. Then they are connected to a specific circuit tailored for the right number of cells. This circuit then provides the power limiting and voltage balance.
Its more complex than most think!
Posted : 16/09/2009 7:12 pm
This made me laugh,
Photo taken just before the caliper went up in smoke?
Posted : 16/09/2009 7:35 pm
Cheers Dave - the 'other' charger is not lithium specific (came with a lead acid battery) [i]so I'll not be plugging that in :-)[/i]
Posted : 16/09/2009 8:00 pm
Dave- they're shrink-wrapped ๐Ÿ™‚
Posted : 16/09/2009 8:03 pm
If they are protected cells, then you'll struggle to damage then as the protection circuitry cuts out if you try and over charge them.
The cheapo Li-ion chargers from Trustfire charge a pair in series with no balancing - they (the chargers) also seem to blow up quite frequently as well ๐Ÿ™
Posted : 16/09/2009 8:53 pm
If you have a load in series and one is fully charged with the others at, say 75%, then the protection circuit on the first will cut in and prevent the others being fully charged. Result - reduced performance.
Posted : 16/09/2009 9:25 pm
