Balloon in a car
[Closed] Balloon in a car
Are you expecting marks for your work?
Posted : 12/10/2011 4:06 pm
 5lab
i'd say backwards as well. assuming its full enough of air to float. interestingly, if you went round a roundabout quickly it should also move to the right of the car
ETA : unless the car was on a conveyer belt, in which case slowing the car's wheels wouldn't make any difference
Posted : 12/10/2011 4:07 pm
On to the floor as I would have burst the stupid thing.
Posted : 12/10/2011 4:09 pm
Is the question how does it move in relation to the world? or how does it move in relation to the slowing car?
Posted : 12/10/2011 4:17 pm
As TJ says.
My friend got asked this in an Oxbridge entry exam many years ago. He said forwards and ended up going to Bristol.
Posted : 12/10/2011 4:23 pm
 emsz
Does it make any difference if you've sucked out the helium to make your voice go all funny?
Posted : 12/10/2011 4:33 pm
Definitive answer...
Cool ta Milkie. Looks like TJ is right.
Posted : 12/10/2011 4:37 pm
[smug mode]I'm always right[/smug mode]
Posted : 12/10/2011 4:39 pm
This one is even better cos you can compare the balloons:
Not particularly related, but those vids made me think of this:
Posted : 12/10/2011 4:49 pm
Now [u]that[/u] is responsible driving 😀
Posted : 12/10/2011 4:59 pm
consider that the boiling point of Helium is (minus)268.93 (°C)
and then take in to consideration the figure 8.93(meters) being the world record distance a unicycle has travelled along the top of a beer bottle.
link: http://newslite.tv/2011/09/29/unicyclist-rides-along-a-row-o.html
remove without taking away, those figures, from each other and as if by magic, you have the answer to maths question of the day.
I hope that helps. (and no, I'm not about to tell you the answer to the boiling water question)
Posted : 12/10/2011 5:22 pm
If you stand in the aisle of a train doing 100mph and jump, what happens then?
Posted : 12/10/2011 5:36 pm
You fly through the air at 100mph and land exactly where you were before, still travelling at 100mph.
Posted : 12/10/2011 5:37 pm
How is that possible?
Posted : 12/10/2011 5:44 pm
Because you were already travelling at 100mph before you took off.
You go straight up relative to the train, but you're flying at 100mph relative to the outside world. And you land straight back down again. Still going at 100mph.
Posted : 12/10/2011 5:46 pm
so all the air goes to the front and the helium to the back
The car is full of air. How does the air go to the front?
Posted : 12/10/2011 5:51 pm
Given that whilst sitting in a chair spodding you're already doing around 1000mph due to the rotation of the Earth, would you expect to be able to jump in the air and land in Ireland?
(For the purposes of this example, let's assume that you're not in Ireland already).
Posted : 12/10/2011 5:53 pm
 5lab
because its heavier than the baloon, and, under braking, the axis of gravity pulls towards the front of the car. Same reason that the baloon rises when you let go of it
Posted : 12/10/2011 5:59 pm
But doesn't the earth rotate the other way, so you could jump from Ireland to the UK but not the other way round unless you started from the Atlantic.
Posted : 12/10/2011 6:03 pm
 5lab
no.
Posted : 12/10/2011 6:04 pm
x=mc4-speed of car x 22/7 divided by the circumference of the balloon - temperature inside of car. The answer is it bursts 🙄
Posted : 12/10/2011 6:12 pm
Yes.. balloon moves backwards, cos the heavier air moves forwards and displaces the lighter balloon.
Imagine a container half full of water. You brake, the water moves forwards.. the air in the container moves backwards.
Tch, stay off the forum for one afternoon and I miss the perfect opportunity to be right and subsequently vindicated... took you lot almost a page for someone to get in there.
Posted : 12/10/2011 6:54 pm
and then it was TJ 😯
Posted : 12/10/2011 8:26 pm
Yes, but if you're going at 100mph, how can you land exactly where you were before?
Posted : 12/10/2011 8:29 pm
Do you lot not understand the word 'relative'?
You're talking nonsense... you are talking about moving frames of reference (ie the train) but not specifying what you mean by 'where'.
Posted : 12/10/2011 8:47 pm
Posted : 13/10/2011 8:44 am
Forwards, much the same as my mates dog did.
Dog asleep on parcel shelf.
Mate drives into the back of someone at lights.
Dog hits windscreen with tragic results. 😥
Balloon wouldn't move with pooch killing velocity as it has a large area that is subject to air resistance and a small mass. The dog had a small area and a large mass. Well, large enough to put a hole in the winscreen of a Ford Granada. The driver broke his thumb on the steering wheel.
Posted : 13/10/2011 8:52 am
up, its filled with helium innit.
dont tell me i'm wrong, i've seen the film 'Up'
Phil is correct. The real question is why doesn't said driver add more balloons and float above the rest of the traffic?
Posted : 13/10/2011 8:53 am
Wait, is the car in the northern or southern hemisphere, and at what latitude? Is it travelling with or against the earth rotation? Are we ignoring the effects of charged ions? Is the car's headlining vinyl, velour, or something else. Do we know the coefficient of friction of the headlining? Is the vehicle on level ground? During braking, what attitude does the vehicle take due to weight transfer? Is the driver wearing a nylon jumper? Has anyone in the car eaten beans or radishes within the past 24 hrs?
Just polishing off my excel sheet, nearly there.
Posted : 13/10/2011 11:51 am
I think you'll need to account for the weight of the balloon too TuckerUK.
The contents may be lighter than air, but the foil/rubber of the balloon, plus possibly string and maybe lettering or a little party tag all need to be accounted for as the inertia throwing it forward must be overcome by the air "pushing" it back. 🙂
Posted : 13/10/2011 12:16 pm
Page 2 / 2
