Audi repairs - gues...
[Closed] Audi repairs - guess the cost?
Needs a new diesel particulate filter (which is probably just corrugated carboard/paper), anyone like to guess the cost from the Audi garage?
(and yes we took it to another garage 1st, who advise the warning lights could be a few things and advised us to take it to Audi)
I will start the bidding with my left arm.
Grrrrrrrrrr, bloody cars!!!!!!
Posted : 25/06/2013 1:45 pm
 m0rk
Got to be £850+vat & fitting at something near £120/hr
£1200?
Take it to a decent VW tuner who will replace it with a piece of pipe, remove the coding in the ECU for the lights
Posted : 25/06/2013 1:48 pm
The magazines are right when they say that unless you drive half way around the world every week petrol engines are cheaper to run.
A blast up the bypass and back might solve the issue? Give it the beans, sometimes the collected muck just needs to be burned off
Posted : 25/06/2013 1:50 pm
Car wont go above 40 so not an option.
Posted : 25/06/2013 1:52 pm
Are they? My Honda costs me £150 for a full service which it needs once a year. Add to that the 45mpg that it gives me no matter how I drive it despite being the size of the QE2 and I'd really struggle to find a petrol car that would be cheaper.
As for the AUDI question, we take ours to the local edit: non-AUDI garage. Never had a problem with any warning lights being put out after a service and always reasonably cheap.
I'm going for 2000 pounds.
Posted : 25/06/2013 1:57 pm
£ 950?
£2100 including VAT. That will be for a new DPF and new pressure sensor.
Posted : 25/06/2013 1:59 pm
£1450
we're going for petrol next time, only get to about 8k miles a year
Posted : 25/06/2013 2:01 pm
LOL. Honda civic here. £99 quid a year service for the last three years, 60k on the clock, 2.2 turbo engine, 50mpg.
OP - £1674.67
Posted : 25/06/2013 2:02 pm
The DPF is so expensive because it's a combined DPF and CAT so has some precious metals in there. Platinum I think?
It's worth getting a second opinion as to it being gone and needing to be replaced. It might actually be fine and there be a fault elsewhere
Where are you based? Anywhere near [url= http://www.turnerdiagnostics.co.uk/dpf-cleaning-43/dpf-error-a-dpf-faults.html ]Turner Diagnostics?[/url]*
*can't recommend them unfortunately as not used but they look like they know their stuff
Posted : 25/06/2013 2:03 pm
4 shillings and 6 pence.
As for Audi servicing, mine cost less than the local "non" Audi, but Audi trained garage not far away.
I had an airbag light come on and a light for the exhaust, both sensors were taken out and cleaned and then put back in and checked, all good, no need to replace with new ones.
Just saying as not all Audi charges are expensive nor done for the sake of it.
Posted : 25/06/2013 2:04 pm
£2190 incl vat .
if its dpf and cat ata main stealership
Posted : 25/06/2013 2:07 pm
How much more does a Honda Civic diesel cost than a Dacia Sandero petrol?
Hondas are silly money here in France whatever the engine type.
Edit: and my guess is £1200
Posted : 25/06/2013 2:09 pm
Expensive car in expensive to fix shocker... 🙄
Posted : 25/06/2013 2:11 pm
[Mike Reed voice] FIVE GRAAAND [/Mike Reed voice]
Posted : 25/06/2013 2:12 pm
Unklehomered is closest. £1420 for a new DPF, £265 is labour which means the DPF is £1155, seen them online for £700, unless there are sensors like you say.
And I agree, petrol next time, we just don't do the mileage for a diesel to be economic.
Cars suck, I could buy a new bike for that, maybe 2!!
Posted : 25/06/2013 2:13 pm
 hora
What engine/BHP/generation/year is it? (I can't help -just to help me avoid ever owning that particular engine in a VW/Audi)
Posted : 25/06/2013 2:14 pm
2.0 tdi Quattro
Posted : 25/06/2013 2:16 pm
BOOM! Loosers!!!!*
*yup, i'm bored at work. 🙂
 hora
c2005/6?
Posted : 25/06/2013 2:17 pm
 hora
Christ. Is there anyway you can get it blanked off? Have you been on a VW/Audi forum etc?
Thats ridiculously expensive.
Posted : 25/06/2013 2:20 pm
Ford C-max petrol, 65k, £40/year service, 40mpg and none of the following:
Turbo
DPF
High pressure injection system
DMF
LOL 😛
In the interests of disclosure it did need a new power steering hose costing about £100 after 45k, and it's on it's 3rd set of tyres.
Posted : 25/06/2013 2:24 pm
there was also mention of an exhaust gas re-circ valve fault at an ADDITIONAL £433! but seing if filter sorts it 1st. hoping it will.
TBH, I dont know enough about cars to start trawling audi forums, have to trust Audi a little bit and realise you are going to pay a little bit more.
Sensor is £50 if it's the same as my Seat was. That price is actually pretty reasonable. Main dealer quoted me £2100 for my Seat, quite likely same part as will go on your Audi.
However I went the non genuine part route, that was £700. But I have a warning to heed, the non-genuine part did not fix the problem and because of this I ended up having to sell the car at auction at a much reduced price 😯
I think the car had a underlying fault that caused the DPF to fail (if it did actually fail) and look like it needed replacing. This was confounded by fitting a non-genuine part as Seat blamed it for the fault. It may have been fine but as non-genuine part it could have been causing issues. I suspect the underlying fault was with the ECU as the pressure and temp readings in diagnostics were all over the place.
In the end, I spent £1000s and got nowhere. So before you commit to changing DPF, get a decent diagnostics person to look at the car.
Posted : 25/06/2013 2:26 pm
 hora
ditto/me too but when a driveshaft went on a Subaru (they wanted 1k+) I posted the problem (as your first post) up on a forum(s) and found out an easier set of solutions.
(I also had an exhaust fail its MOT - again Subaru wanted 1k+ for a full system but a forum recommended a £390 solution).
At the least you'll get people who had the same problem and specialists/etc they used.
Main dealers are renowned for being fitters and plugging bits in to see if it'll sort the problem (at your expense) until the problem is eventually completed cured. A good specialist wont throw your money at a problem. He'll also know off-plan potential fixes.
Posted : 25/06/2013 2:27 pm
They must have seen you coming...
Posted : 25/06/2013 2:29 pm
OP
Are you sure it's the right diagnosis?
Friend had the same kinda problem on his Audi diesel and they went all round the (expensive )houses before finding it was a leaking intake hose 🙄
Go mad on google and Audi forums ( if you haven't already) ,see if there are any other areas that could be checked .
Posted : 25/06/2013 2:30 pm
 hora
As above, I honestly think you should avoid Audi on this.
Posted : 25/06/2013 2:31 pm
So do 10 miles at 40mph in 1st gear.
Seriously.
 hora
You could easily do 40 in 2nd - just get a nice dual carriage way. If you live anywhere near me- I'll do it 🙂
Posted : 25/06/2013 2:33 pm
Go to vagforums, plenty of informative people there. There is option of having Würth clean treatment but that you have to discuss there. Most people gut dpf and remap. On average it costs £600 plus more power and mpg.
The EGR could require cleaning if the mileage is high, won't cost £433 to do that though. It does need to be operating properly to allow the DPF to regenerate
The problem with main dealers is that the mechanics tend to be more "technicians" rather than engineers. Their fault finding methodology is to swap suspected faulty part, see if that fixes it, if not change something else..... all at your cost. More specialist independent garages might be able to employ a bit more logic to the fault finding and possibly save you money. However unless you've got a specialist you trust I'd possibly stick with Audi. You could always try another Audi dealer though?
Posted : 25/06/2013 2:34 pm
 hora
Heres what'll happen- Audi fit everything then they'll hand you their free 'critical safety report' which shows your discs are 70% worn.
Posted : 25/06/2013 2:35 pm
www.vwaudiforum.co.uk
choose your section and fire away
Posted : 25/06/2013 2:36 pm
they have already told me that the front tyres are 2mm off the legal limit.
Posted : 25/06/2013 2:39 pm
Problem is it's illegal and could cause MOT failure in the future*. It does in other EU countries (Portugal I think) so quite likely to come here soon.
*Or right now if you're unlucky, your car could be taken off the road by VOSA at a checkpoint. Oh and there is also the issue of tax evasion
Posted : 25/06/2013 2:40 pm
Had this with Honda car went in last year for service discs are 70% worn pads are 80%worn , new pads fitted by local garage didn't change discs this year the discs are 60% worn. 🙄
Posted : 25/06/2013 2:50 pm
 hora
Two weeks ago I had "70% worn disc/pads". The very next day I had a puncture. I could NOT get the wheel off. I had to pop the bolts back in 50% then drive round in a circle to get the front hub to debond to the steel wheel. In the tyre fitters I ask them to try the other front wheel. Also bonded to the hub.
How did they measure the pad wear THAT accurately without taking the wheels off?
OP - I know a respectable NWest bikeshop back in 2007/8 that told me me crankset and my rear mech was worn out/not fit for purpose and asked if they could fit new.
I told them no ta. The rear mech is still going strong. As we know a good bike mechanic would fit new parts or simple ignore cosmetic wear.
Posted : 25/06/2013 2:54 pm
If you are in the South East I can highly recommend Merc Medic just outside Woking
Our 2.7 TDI Quattro has done 100,000 miles owned since new in 2007 and been very reliable with limited servicing costs. The franchise dealer in Guildford I don't have a single good word to say about.
These "warning lights" are a car manufactures dream as it's very hard to sell the car on with the lights illuminated and how do any of us really know if they are "legit" ?
EDIT: never change the tyres at the franchise dealers, so much cheaper elsewhere. IMO new tyres required is a common dealer revenue generator.
EDIT2: We were told on a Toyota RAV4 that a new Cat was required, it was replaced under warranty then warning light on again and dealer had same story - new cat required. We looked on Toyota forum and as a result I bought a new battery, warning light never came on again
Posted : 25/06/2013 2:57 pm
i share your pain. among other laughably expensive fixes i have just paid £250 to have a new rear wiper motor fitted to my a6
Posted : 25/06/2013 3:28 pm
This DPF malarky is suspect, I reckon. It's an inert thing with no moving parts, how can it fail? If it gets blocked up, then something else is causing it to either block quickly or not regenerate properly. Unless you address that it's only going to block again.
Posted : 25/06/2013 3:37 pm
Hahaha, this is why I don't go near main dealers
Posted : 25/06/2013 3:41 pm
the fact that the car doesnt get any motorway miles is likely the cause, probably 10-15 minute journeys at the most.
Should of got a Ford Ka
Posted : 25/06/2013 3:44 pm
£250 for the rear wiper motor fitted!?! I have exactly the same motor in my A4 (its a known weak point). I bought the genuine motor for £80 and fitted it myself with the whole job taking just half an hour, one screwdriver and 2 sockets.
Posted : 25/06/2013 4:05 pm
Er yes. Did you not get a DPF light on the dash before this? Did you follow the regen instructions in the manual when this happened?
You only need to get the engine revs high btw, you don't hav eto actually drive fast (although it helps). Take it for a spin at 40mph in 2nd, that should clean it out some.
Posted : 25/06/2013 4:14 pm
battery disconnect overnight?... loose ecu fault/limp mode?.. drive like its stolen?... fixed?
Posted : 25/06/2013 4:17 pm
Don't worry I spent over 2 grand having various bits and bobs removed from a bmw. Turns out it was probably the turbo which was gone (even after having un dpf'd and decatted, new exhaust etc etc). I sold the car to an enthusiast who could be arsed to keep going through a long line of incorrectly diagnosed problems...
Posted : 25/06/2013 4:22 pm
Don't disconnect the battery unless you want a bill of 50-80e for a reprogramme (assuming it's like a BMW or Peugeot). Driving at 40 in 2nd won't help unless it's up a steep hill with the brakes on (if it'll let you). You need to raise the exhaust gas temperature which the limp mode is intended to prevent. There are companies in Germany that specialise in cleaning these things for about 500e - Anything similar in the UK?
Posted : 25/06/2013 4:37 pm
Disconnecting the battery does nothing to my VW, apart from sometimes causing the ESP to get confused for 5 mins or so, but that resets itself.
You can get DPFs cleaned out, yes. Driving at high revs does raise the exhaust gas temperatures, possibly not enough, but if you have the car it's an easy thing to try just in case.
Posted : 25/06/2013 4:51 pm
My clutch/dual mass just cost me £750.00 at a none Audi garage. A quick google suggested main dealer prices @£2300.00 😯
Exact same thing on out T5 transporter went the week before costing £650.00 🙁
That could of been my new Transition Bandit frame
Posted : 25/06/2013 4:56 pm
Sheesh! And people slag of Renaults on this forum. Or do Renault have special rip-off-Britain prices?
Posted : 25/06/2013 5:01 pm
dmorts - Member
[citation needed]
Posted : 25/06/2013 5:04 pm
Nope, they are just aren't very good cars.
Posted : 25/06/2013 5:10 pm
i had a A6 2.5 tdi quattro sport many moons ago...was a brilliant car except for when it went wrong....
got a letter once from Audi offering a free brake inspection..so i took it in...3 hours later they told me the rear pads were worn - near metal and needed replacing...they charged me £300...i complained and said that they had left me waiting for 4.5 hours for something they said would only take an hour to do...they reduced the bill to £190...
1 year later the brake light comes on so i took it to my local independent garage and he says the rear pads are shot...they had been put on wrong and had been rubbing the discs and had worn the outer pads...contacted audi blackburn where the pads had been fitted and their response was you should have told us as soon as you noticed...but there is nothing we can do now...my response was stick yer pads where the sun dont shine cos i'll not be using you ever again...
fast forward another year and the auto gearbox starts to play up...wont go above 20 and only changes up to 2nd...had to drive back from work really slowly...
contact another audi garage who say oh its an ECU problem...they cost £900 + vat and there are 2 ECU's that could be affected...i take it to my local garage and he plugs his computer in and says it seems like a gearbox sensor fault...he recommends another garage that has a proper audi computer who check it out and confirm its the gear shift ratio sensor....i contatc the audi garage again and they say no this cant be the fault but bring it in and we'll stick our machine on it and suss the problem out..the cost of this would have been £100 an hour and it would take on average 6 hours to diagnose the fault as they have to eliminate all possible fault codes...they garage the car was at did take about a whole day to suss out the exact fault...they charged me £250 to repair it (£25 for the sensor and the rest for time on the computer)...less than half of what audi wanted to look at it...
another year passed and the headlights failed the MOT as the manual adjusters on the headlamp units were broken...you have to replace the whole unit as they adjusters arent available on their own...again contacted audi for a price and was quoted £750 + vat for the pair and then more for fitting...got it done by my trusty local for £600...
the car was a gift from my brother...but when he sold his x5 and needed a another car i gladly gave the car back to him and went and bought my own....bought an old honda civic and in the 3 years i had that civic all it needed was a new exhaust and 2 new tyres...had the audi for the same period and it nearly bankrupted me!!!
just relieved the DPF behaved itself!!
Posted : 25/06/2013 5:16 pm
dmorts - Member
[citation needed]
To quote directly from an email from Honest John when I asked him about DPF removal
DPF removal is illegal under EC Type Approval and
Emissions regulations because it modifies the car not to
meet its certified emissions on the basis of which it is
taxed.
The fact that VOSA in the UK does not currently enforce
this in the MoT does not mean that it will not in the
future. Nor does it mean you could not be stopped in a
roadside VOSA check and have your car taken off the road
for not complying.
If you don't disclose the modification to your insurer
your car is automatically not covered (though 3rd party
damage has to be).
And, if it felt so inclined, HMRC could pursue you for tax
evasion.
So anyone thinking ore removing their DPF needs to be
aware of the potential consequences.
Honest John is The Telegraph's motoring expert and has a website here - [url= http://www.honestjohn.co.uk/ ]http://www.honestjohn.co.uk/[/url]
[url= http://www.honestjohn.co.uk/askhj/answer/44251/removal-of-dpf-system ]Recent HJ comment on DPF removal[/url]
The only thing I can't currently reference is that it is enforced at MoT in other EU countries
Posted : 25/06/2013 5:20 pm
 br
Has the car been regularly Audi serviced, is there anything in the service regime regarding the DPF?
tbh You're almost spending what my last two cars have cost me, but then we had an equivalent bill for the injectors on my wife's diesel.
I'm not a diesel fan, well not since I was forced at work to have one in 1996 as I did a lot of miles - whereas my colleagues could have petrol cars because they were office based. They got 323i's and C240's - I got a Xantia 1.9 TD!
Not had one since.
Posted : 25/06/2013 5:35 pm
I miss read that as Au Pairs 😳
Posted : 25/06/2013 5:48 pm
Bought an Audi..... never again
Posted : 25/06/2013 5:50 pm
How exactly does it cost so much to replace a DPF? It seems to be an issue I hear over and over again with VAG cars? It's just a flippin' filter isn't it? So why so expensive to replace? (Genuine question from a worried VAG car driver 😐 )
Posted : 25/06/2013 6:06 pm
DD, the DPF in VAG cars is a combined cat and DPF, so it's full of catalyst metals and stuff. I think a lot of people don't know that you need to take care of them, but I also think a lot of garages are happy to just slap a new one in and charge you for it, without figuring out why you're in that situation in the first place.
It's like replacing your toilet every time it gets blocked.
Posted : 25/06/2013 6:19 pm
dmorts - Member
taxed.
Well that's a pretty strong assertion, very surprised about that.
Posted : 25/06/2013 6:58 pm
organic355 - Member
Diesel filter you said ... hmmm ... starting price £1,400 ... plus being rip off for the rest I say the total cost will be £1,800. 😯 (okay just re-read the threads ... close ...)
I say Japanese car anytime ... or Skoda at a push. The rest are just money pit IMO if something goes wrong.
Posted : 25/06/2013 7:11 pm
 hora
Or a 2.8 or 3.2..
Posted : 25/06/2013 7:22 pm
Skoda IS VW/Audi
And the thread's pretty much concluded it was probably user error/driving style not the car. Reviews of the latest Toyota's in Germany pointed out it didn't like Autobahns as when the DPF cleaning cycle tried to clean it whilst doing 100mph+ it just spewed black smoke for mile after mile. So they're hardly the pinnacle of greatness in this respect!
Posted : 25/06/2013 7:31 pm
get it chopped out and egr and dpf mapped out problem solved lots less mate of mine just hadit done on a A6 2.0tdi cvt
Posted : 25/06/2013 7:40 pm
Skoda at a push
Skoda containing the same engines and DPF technology as the OP's Audi of course....
DPFs are a POTENTIAL issue for all diesels, I suspect that people don't understand them, and mechanics understand them even less.
My car has no DPF, does the OP want to swap? 🙂
Posted : 25/06/2013 7:51 pm
About right, we paid £600+labour on a Passat at independent garage.
Another reason not to stay with VW/Audi/Seat/Skoda IMO.
Posted : 25/06/2013 7:53 pm
What, other cars don't have clutches or DMFs?
Posted : 25/06/2013 7:57 pm
The DMF on my Astra 1.9 cdti was 1k at an independent! Rang around loads of places to get it that cheap too.
Petrols still have EGR valves and DMF's too, they just tend to go wrong less often due to less soot/torque.
Posted : 25/06/2013 8:00 pm
thisisnotaspoon - Member
Well on the bright side at least it's still doing 100mph+ 😀 rather than slowing down etc
Posted : 25/06/2013 8:01 pm
If you cane your car up and down the Autobahn regularly I'm sure the DPF doesn't need to be regenerated that often 🙂
Posted : 25/06/2013 8:07 pm
Guess you had the engine management light on then the dpf symbol then the glow plug flashing at you which means its gone in to limp mode it wont pull your hat off
had it in Feb on my audi a3 170hp tdi Quattro 57 plate take it in as you will only clog it up more and you will not get it regenerate now, they will plug into the laptop and do a force regeneration and hopefully not have to replace the dpf the exhaust pressure sensor is cheap enough think it was about £50 fitted when they done the force regen not had a problem since
Gary
Posted : 25/06/2013 8:11 pm
I had a quote of $7250 for new brakes for my RS4. It did need them. 15 minutes on the phone and I got them dhl'd from Stoke Audi, landed inc tax for $2300. Took it all to Audi who refused to fit them because they had a strop. Rang Audi nz who promptly told them to jog on as they were OEM parts and thus they had no issue with that and my warranty was not invalidated as they said etc etc. Fast forward 2 years and the garage are now trying to persuade me to buy a car from them. No chance, never ever ever ever again will I give them a $ of business. My local euro specialist is superb so I just us him, have seen some pearlers from the main dealer inc my colleagues van that got hit while in their workshop and they claimed that it arrived like that - he had photos dropping it off which slowed that argument down somewhat.
Posted : 25/06/2013 8:27 pm
molgrips
They do, just often don't cost as much as VW/Audi/Seat/Skoda parts.
And if you get a petrol, no they don't.
Posted : 25/06/2013 8:33 pm
I sometimes think leasing with maintenance is probably a sensible option these days for how expensive some of the more modern cars are to fix.
Posted : 25/06/2013 8:37 pm
Well my last e class diesel - just traded in, was 2008 and didn't have a clutch or a DPF. It was an auto and was one of the last diesels without DPF. No issues in 80K miles. I've got another eclass and at least with the bigger diesels there aren't many issues at all reported with DPF (I lurk on the Merc forums). Also I tend to use it largely on the motorway so hopefully it should be OK. There are a few complaints about the 220/250 diesels but nothing like as many as you hear about from VAG.
To the OP - on a 2007 Audi - why are you still getting it repaired within the dealer network. It's probably time to find a good independent and get it sorted at a fraction of the time. Dealers are fine for standard servicing but you need to be aware that they will be charging you to be in the s****y showrooms!
Posted : 25/06/2013 8:40 pm
hora - Member
Most modern cars have pad wear sensors. They'll have just plugged in the diagnostic machine and it'll have read out the current wear on the pads.
matt_outandabout - Member
[i]molgrips
What, other cars don't have clutches or DMFs?[/i]
Woah, Hold the phone! Modern petrols done use clutches?!
Posted : 25/06/2013 8:44 pm
