Artists, anyone kno...
[Closed] Artists, anyone know about colour mixing?
Mad question I know but....we bought some paint that we thought was a Darkish Pink that turns out to be more purple! Can we add some different colour(s) to make it less dark & pinker? Put some on a wall & thought 'yuk',
Help!
Posted : 04/02/2016 10:33 pm
 Euro
Not really. The amount of 'lighter' paint you'd need wouldn't make it viable. Best to buy a new tin and keep the purple for something else.
Posted : 04/02/2016 10:39 pm
Dusky pink is a crime in our house!
If it's purple then it is both too dark and too blue.
Add white to achieve the desired lighter shade then red to get the colour value.
*Edit - Agree with Euro - is easier to buy a different tin, but if you already have some white it might be worth buying a small tin of red and having a bash. Experiment with small measured amounts until correct mix ratios achieved then scale up.
Remember pink is just red and white (lighter shade of red) so purple (blue) would have to be reaaaaaaly diluted out. So much so that why really bother?
Posted : 04/02/2016 10:40 pm
In theory if you use the same brand they should mix fine as the base technology will be the same. My suggestion would be to only try white to make it lighter since anything else becomes hard and you'll end up with a dirty brown.
As malvern rider says try it on a small scale then scale up. I'd suggest you mix all of it when you go for it as if you make a mistake you'll end up with two tone walls. Colour mixing is a bit of a dark art - results aren't alwas what you would expect, even with pure stainers - when you are dealing with existing mixed colours you have little chance of getting to exactly what you want.
Posted : 04/02/2016 10:48 pm
 Euro
A good pink will have a touch of yellow too if you decide to to try and mix it lighter, which if you're not fussy about the result, might be worth a try. I doubt you'll get the pink you liked originally, but you may get something pleasant (or a brown of some sort ๐Ÿ˜€ )
Jonba, you seem to know your paint sir. How come (if you don't mind me asking)?
Posted : 04/02/2016 11:01 pm
If the paints not what it is shown on the label (or a match to the colour you had it mixed to) just take it back to the shop.
With the sample area you've painted on the wall keep in mind the hue can change a bit as the paint properly cures, so it can dry to one shade in a few hours but over the next few days the colour can keep altering.
We used to have a really, properly purple wall in a gallery I used to work in - every time we had to repaint sections after re-hanging work we'd be certain we'd used the wrong paint the new stuff looked so different, it took around week for the new paint to settle to the right colour.
Posted : 04/02/2016 11:04 pm
 ctk
If you have some white paint I'd be pouring the purple into the white rather than vice versa.
Posted : 04/02/2016 11:08 pm
I watch paint dry for a living.
I do product development and have done for a few years. Last few years I've been on heavy duty intumescents so I mostly work in grey.But I did do a brief stint in finishes. All mine is industrial, never done decorative, that is a different site.
Posted : 04/02/2016 11:36 pm
 Euro
๐Ÿ˜†
Not just any old paint though - magical fireproof paint! Thought it was something technical, sounds pretty interesting. Cheers.
Posted : 05/02/2016 8:52 am
Goth room?
Posted : 05/02/2016 10:05 am
I agree with all of the above..
Especially what ctk said..
I spend half of my waking life mixing paint and it can be truly maddening..
Infinite monkeys spring to mind for some reason
Posted : 05/02/2016 10:12 am
Sounds like a plan, I'll give it a go!
Thanks chaps.
Posted : 05/02/2016 11:11 am
