Anyone scrapped a d...
[Closed] Anyone scrapped a domestic copper hot water tank recently?
How much did you get for it?
Posted : 21/07/2011 10:00 am
No scrapped a tank, but have scrapped plenty of copper. Its worth around £1500/ton. But its only worth that if its 'clean' in the sense that anything not copper has been stripped off of it. You'll get a much lower (but still quite attractive price) price if there is any other metal or plastics still attached
Posted : 21/07/2011 10:04 am
Strip any insulation of it first before you take it to the scrappys
Posted : 21/07/2011 10:10 am
It is clean.
Posted : 21/07/2011 10:11 am
 wors
i'll give you 20 quid for it.
Posted : 21/07/2011 10:13 am
liftman - doesn't make any odds
got £25 for ours 2 summers ago
Posted : 21/07/2011 10:19 am
Got £42 for one last year, and it was still covered in that insulating foam stuff.
Posted : 21/07/2011 10:34 am
There are two rates for copper, clean an dirty, more money for clean copper.
Posted : 21/07/2011 10:46 am
I got £200 for the tank and a shed load of copper pipe after having a new boiler fitted earlier this year.
Edit: If I remember right I [u]think[/u] It was about 57kg.
Posted : 21/07/2011 10:50 am
As said up there /\
take the insulation off before weighing it in.
The new cylinders weigh 12kg each, the older ones weigh more (bigger and thicker copper used).
We buy them in at around £4/kg so you should expect atleast £50.
Posted : 21/07/2011 11:05 am
Got £80 for a large tank the other week.
Posted : 21/07/2011 11:08 am
ANy one know wheres a good place to sell to in the southampton area?
Posted : 21/07/2011 11:18 am
The only time I scrapped one was years ago, only had a loose insulation jacket on it. Cylinder weighed a ton, rubs hands together in expectation, took it to the local scrappy:-cue big hammer & tin snips-smack smack smack with the hammer-snip the top off, empty out the old limescale-instant 50% reduction in weight. Still got good cash for it though!
Posted : 21/07/2011 11:41 am
cut the top off and use it as a plant pot, can use the coils inside to grow plants up as well
Posted : 21/07/2011 12:04 pm
I phoned scrap yard other day £4400 ton clean copper and £3900 braized (solder on etc)
Posted : 21/07/2011 12:29 pm
Many years ago, when I was a student, I did a week on the bins (I needed the money). One house had a hot watr tank outside and the owners paid the grunts I was working with to take it way. Said grunts then laid the tank in the road and drove the bin wagon over it to flatten it so they could hide it in the cab before taking it to weigh it in at the local scrappy!
Posted : 21/07/2011 1:02 pm
We've just got £100 for a back boiler which wasn't copper, just metal (don't know which type).
Posted : 21/07/2011 1:20 pm
now you know what it's worth (around £4 per kilo?) take the bathroom scales outside, then you will know roughly what it's worth.
Posted : 21/07/2011 4:03 pm
go the whole hog.. clean off the insulation and take off all the brass you ll get close to 5 a kilo. we sell our scrap in three styles clean pipe no fittings, copper with copper fittings, brazery ( copper and brass mix) and brass only plus of course general scrap ( rads pumps etc) this been the cheapest at about 155 a tonne.
we used to chuck all our boilers in as general scrap but now get the apprentice to strip them down and a scrap boiler can easily fetch 30 quid that way as opposed to a tenner max otherwise.
dont forget you need a licence to transport waste at 155 a year..
Posted : 21/07/2011 6:51 pm
Sorry for the slight hi jack but how much is cast iron worth?? At my work we have about 2-3 tonnes of old obsolete cast iron die punches. I want the space but i have to make a good pitch to the boss to see if we can sell them. I have googled it but to no avail
Posted : 21/07/2011 7:09 pm
Cast iron is more like 150 per ton
Posted : 21/07/2011 7:28 pm
Thanks!
Posted : 21/07/2011 8:06 pm
