Anyone replaced (re...
[Closed] Anyone replaced (repaired) a cush drive on ZZR600?
 Aus
Pretty sure my cush drive is v tired. Fancy having a go at packing it out with some inner tube / car mats.
Any tips / pointers of doing this?
Ta
Posted : 07/09/2011 11:47 am
I'd personally not go down that route .... I'd replace them.
mandp do complete sets for about 50-60 notes.
an alternative that I've used in emergencies is to cut up an
old belt to pack out the cush rubber. I've used leather belts
twice now 🙂 Not tried the inner tube idea though.
Posted : 07/09/2011 11:51 am
I packed mine with thin Brass strips seemed to work well and improved the ride.
Posted : 07/09/2011 12:27 pm
I'm sorry maybe I'm missing something here, how does a cush drive affect ride quality, all it does is cushion the takeup on the sprocket?!?!
Posted : 07/09/2011 12:34 pm
In exactly the way you just mentioned
the take up is better and smoother so accelerating out of corners is smoother down shifts smoother etc so the quality of the ride is improved.
Posted : 07/09/2011 12:38 pm
wow, I was also interested in this for my zzr600.
STW, a font of knowledge for all areas of 2 wheeled life!
I was considering the innertube road as opposed to dropping 60 quid on rubbers for it.
Posted : 07/09/2011 1:03 pm
 Aus
thanks, am I right in thinking I whip the wheel off, lift the sprocket and there it is?
Posted : 07/09/2011 1:27 pm
 momo
Aus - Member
Yep, pull out the sprocket carrier and you expose the cush drive.
Posted : 07/09/2011 1:32 pm
I did mine on my ex ZZR1100 a few years ago. It was around £30 for the part and took 5 mins to fit and another 10 mins to get the wheel off, on and aligned. Sprocket carrier off, old rubber thingy out, new rubber thingy in. P.O.P.
Posted : 07/09/2011 8:56 pm
This thread needs pics of your ZZR's, past & present. 😉
Posted : 07/09/2011 9:00 pm
 br
Just buy a new one, not worth pi55ing around with something that's got upwards of 100bhp going through it.
Posted : 07/09/2011 9:03 pm
 Aus
thanks all ... rather shamefaced, 😳 I tightened my chain a touch and that seems to have helped significantly
Posted : 08/09/2011 6:28 pm
Well heres my take on it...
The OEM cush drive went baggy pretty quickly in under 20k miles. (160 bhp going through mine if the dyno chart is to believed).
Whip the back wheel off. Pull the sprocket carrier and sprocket off. Cut up the thickest inner tube you can find into squares. Stick these to the cush drive with glue. Lube the metal blade of the sprocket carrier with fairy liquid so it slides in easily to the snug gap between the rubber. Make sure the carrier when replaced is a good snug fit.
Remount and tighten up the back wheel.
Seems to have worked and is still working for the 74,000 miles since I did it...... currently on 94,000, original clutch and engine not been out of the frame or split....
No pics of mine immediately available so here's Mrs Rickmeister's heavily re worked XT 600
Posted : 08/09/2011 6:52 pm
 Aus
If anyone's interested, removed the wheel and cush, slipped some strips of inner tube into the worn cush area, refitted and, loads better. Really noticeable. How long it'll last I don't know, but easy to do so thanks for the guidance
Posted : 12/09/2011 2:04 pm
cheers for the update- I'll have a shot at mine some point this week I think. Did you use regular mtb innertube?
P
Posted : 12/09/2011 3:18 pm
 Aus
It was easier than I imagined (a small block of wood under the wheel when removing is worthwhile). And yes, used MTB inner tube.
Posted : 12/09/2011 3:33 pm
