Community
Anyone in/near got ...
[Closed] Anyone in/near got an engine hoist I can borrow?
I am removing the engine from my car and need an engine hoist. Ideally with someone who knows how to use it too. I can collect it and return it (with beer as well if necessary)
I will be removing the engine as soon as I find a hoist and will be putting it back once I have fixed it/f*cked it totally.
Posted : 16/07/2010 12:28 pm
I have one. It's in Bristol though!
Hth
Marko
Posted : 16/07/2010 12:31 pm
£30 to rent so probably cheaper than the diesel to Bristol and back.
Posted : 16/07/2010 12:34 pm
Where in the world?
Posted : 16/07/2010 12:57 pm
southampton
Posted : 16/07/2010 1:30 pm
This will end in tears 🙂
Posted : 16/07/2010 1:34 pm
I have done it with a winch attached to my dads garage rafters before. Will ask if I can borrow it you want. and lend a hand if you need one 🙂
Posted : 16/07/2010 1:37 pm
This will end in [s]tears [/s] flames
Posted : 16/07/2010 1:40 pm
Have rented one. Which size hammer to remove AirCon pump?
Posted : 16/07/2010 2:20 pm
I assume you are trying to leave the AC pump and all pipe work in position to save having the system de-gassed?
PM me the car you are working on and I may be able to help.
Hth
Marko
Posted : 16/07/2010 2:33 pm
soma - feel free to pop round if you want a laugh. Not sure i will get the engine out tonight but that is the plan.
Do you know anything about engines?
Thinking of trying to fix the 'tegra
Posted : 16/07/2010 2:34 pm
This the Type R with the borked bottom end?
Posted : 16/07/2010 2:57 pm
I thought these Vtec engines had a failure rate of zero. If so honda might be interested to hear that you have blown one.
Posted : 16/07/2010 3:08 pm
T'is the typeR
It wouldn't have failed if I had topped the oil up rather than thinking it would be fine to wait until the service at the weekend.
Posted : 16/07/2010 3:14 pm
 d4
Have one in Shirley? If that's any good to you?
Posted : 16/07/2010 3:43 pm
 d4
Oops just read the "rented one" bit.
Posted : 16/07/2010 3:50 pm
 tron
It's not the engines that have a zero failure rate, it's the V-tec mechanism which as never failed! Does nobody pay attention to my pedantry?!?!!
BBB, I seriously recommend having a couple of mates to help - you don't want to swing the engine into any bodywork.
I also wish you luck in freeing the exhaust manifold - might be best if you can pull the engine with the manifold on. You could split the exhaust system at the first join, or take the downpipe off if it's seperate. I wouldn't be surprised if a Type R engine has a big 4-1 manifold and no downpipe.
That way you can split the engine and mani at your leisure, with the help of a blowtorch and plusgas.
Do you have a stand to hang it on?
Posted : 16/07/2010 3:52 pm
I have an engine stand. I don't have any mates - will a wife do?
Posted : 16/07/2010 4:09 pm
is this just to repair the big end? Can you not do this in the car, with the sump off? I'm sure I've seen it done in-car on the telly.
Posted : 16/07/2010 4:14 pm
molgrips - not sure what the damage is but there is not much space under a TypeR and I don't have ramps to raise the car.
Posted : 16/07/2010 4:16 pm
How many miles on the car?
Posted : 16/07/2010 4:18 pm
 tron
Ideally you'd get someone on each side of the car to stop the engine swinging about. If you're careful you should be able to swing out out on your jack jones, but it's reassuring to have someone to help / point and laugh.
Posted : 16/07/2010 4:19 pm
"I have an engine stand. I don't have any mates - will a wife do?
Ha ha, mates usually watch in shiney new trainers/jeans mumbling that they might get dirty, then tell everyone in the pub afterwards what "we" did..
I'd be tempted not to use "the wife" except for cups of tea (usually cold) and comments like "have you nearly finished.
Take your time and check for randomly attached cables.
Good luck.
molegrips, if the bottom end is properly shagged the crank will need to come out
Posted : 16/07/2010 4:21 pm
1 out of the 3 exhaust bolts has now been loosened!
Posted : 16/07/2010 5:30 pm
Lol. Good luck mate 🙂
Posted : 16/07/2010 5:38 pm
You could indeed to mains and big ends with the block in the car, but it's hard work and involves pretty much the same as doing it out of the car, but without the extraction or the ease of getting to it. You CAN do a clutch in-car on mine, but it's a lot easier to do it out of the car.
Can I recommend getting an engine stand? So nice to work on an engine that's properly secured, not swinging from a hoist or resting on bricks!
Posted : 16/07/2010 5:42 pm
Do you really think with your alter ego, you really should be mucking about with stuff with chains and gearing.....oh hang on.
Posted : 16/07/2010 5:46 pm
 Stu
Posted : 16/07/2010 6:10 pm
What's your secret, you're getting a few offers whereas my trailer request is getting pushed off the bottom of the page. Damnit!
Posted : 16/07/2010 6:34 pm
The exhaust is free!!
I now just need a scissor knuckle breaker (or something like) that to get off the sticky out bits with the wheels on and then an 8mm drift to knock out a spring pin.
I have a picture of the scissor knuckle thingy to take with me to MachineMart tomorrow but what is an 8mm drift and what does it look like.
Posted : 16/07/2010 6:43 pm
A drift lets you hit something that has a sub-flush head with a hammer. So an 8mm drift is an 8mm diameter cylinder that you place on the end of the spring pin, then hit with a hammer until the spring pin pops out.
Posted : 16/07/2010 7:30 pm
I have visions of Mr Bash in A&E tomorrow. He has previous with diy engineering!
Posted : 16/07/2010 7:37 pm
so basically I can use an 8mm allen keyy?
Posted : 16/07/2010 7:45 pm
Yes, but i'r recommend using if socket that fits flushly in the hole, rather than an allen key. Or probably just buy a drift, as they're designed to be ****ted repeatedly with a hammer whilst swearing.
Oh and
Haynes: Using a suitable drift...
Translation: The biggest nail in your tool box isn't a suitable drift!
Posted : 16/07/2010 8:47 pm
Arent allen keys measured across the flats? wont that mean that the corners are more than 8mm?
Posted : 16/07/2010 8:51 pm
Use an extension bar from a 1/4 drive socket set .
This is on the advice that you a.- Have a 1/4 drive socket set
and b.- You havent already used it as a drift, and its fubarred
Are you trying to dismantle the driveshaft knuckles?
Normally they pop out with a **** from a hefty mallet or big lever ( well they do on some cars)
Posted : 16/07/2010 9:03 pm
Got a drift.
Gently tap - Nothing
Harder tap - Nothing
Smack it - Miss the end of the drift and take out my knuckles. Ow.
Is there a clever way of doing this or just repeatedly hit the bl00dy thing?
Posted : 17/07/2010 12:02 pm
