Anyone good with Cr...
[Closed] Anyone good with Crystal Reports? Maintaining aspect ratio of images
I've written a report that dynamically displays images for each line of data. The image location is a URL (e.g. www.myimages.com/12345.JPG) and the URL string is stored in the database I'm connecting to. So far so good, my images are displaying.
Since the images could be all sorts of different sizes I need to keep the image container static and resize the images within (again so far so good) but whilst also maintaining the aspect ratio. This last bit is the bit I'm struggling with. I know a mountain bike forum is an odd place to ask but I'm not getting my answers anywhere else so it's a last ditch attempt. I fear - judging by my Googling - it is a known weakness of Crystal, but I'm in denial.
Posted : 06/02/2012 2:49 pm
A hopeful *bump*
Posted : 06/02/2012 4:44 pm
dump Crystal and use PHP or even JavaScript on a internal web server?
Posted : 06/02/2012 4:50 pm
Assuming "dump Crystal" is not an option do you have any other ideas?
Posted : 06/02/2012 4:54 pm
Sorry. I doubt it can do it. I had an awful time with images in Crystal.
The other option is to have a load of images the right size and aspect ratio for the report.
Posted : 06/02/2012 4:56 pm
Sadly that is the conclusion I'm coming to, but since the image library already exists and there are 10s if not 100s of thousands if images, it could be a big job. Might need to look into software that can batch resize...
What's most annoying is that report writers I've used in the past have this function as standard ๐Ÿ˜•
Posted : 06/02/2012 4:59 pm
http://stackoverflow.com/questions/4254260/crystal-reports-image-squashed
Any use? It's only google, but its been a decade since I last touched Crystal Reports!
Mmm, maybe. My problem is that whilst I can write simple Crystal Reports (and I count showing images as pretty simple), I'm not a developer. I'll see if the dev team at work can do something with it.
Thanks
Posted : 06/02/2012 5:11 pm
There's BLOB field which will hold an image, it's got XScaling and YScaling properties. Might be worth playing around with?
Posted : 06/02/2012 5:13 pm
done that. The main issue is that the x and y scaling need to be dynamic with potentially each image it comes across. I once used a report writer for Delphi called - oddly enough - Report BUilder. Whilst it was limited in some places, what I'm trying to do here was simply a case of setting a menu option to "Maintain Aspect ratio". I assumed Crystal would have something equally numpty-proof.
Posted : 06/02/2012 5:20 pm
