Any washing machine...
[Closed] Any washing machine engineers? not spinning wae24162uk/01 ... help.
STW hive mind any washing machine engineers? Hi My Bosch Classix wae24162uk/01 did not spin on the last load, I set it to spin only and still no spin. I have cleared the pump at the bottom front, and blown throught he little tube there to remove anything else. I took the back cover off that exposes the motor/drum and set to spin again, (stood well back) it appears to not even try to spin. I've done a search for wae24162uk/01 and found nothing.
Posted : 13/05/2012 12:35 pm
 Aus
Hi, just fixed my Bosch which had e same problem. It may be your brushes in the motor, they wear down to the point it stops spinning. Go on espares, search Bosch carbon brushes, and they have a video showing how to replace. V easy to do
Posted : 13/05/2012 12:38 pm
ok will inspect motor cheers.
Posted : 13/05/2012 12:39 pm
If you haven't already, take out half the stuff & try again - we have a bosch and it won't spin if overloaded
Posted : 13/05/2012 12:41 pm
yer done it empty.
Posted : 13/05/2012 12:42 pm
As Aus said, try swapping the bushes, we had exactly the same symptons and new bushes cured it.
Posted : 13/05/2012 12:50 pm
taken brushes out, very worn. Happy days. Now where to get brushes on a sunday...
Posted : 13/05/2012 1:02 pm
sorry to hijack this thread but my gf just mailed me saying her washing machine sounds like its about to explode when on high spin. Time for a new machine or is this fixable? Dont have details on make/model yet
Posted : 13/05/2012 1:16 pm
If the machine is not going through its full cycle and the drum is not draining then the pump is your boy
Posted : 13/05/2012 1:59 pm
