[url= http://www.channel4.com/programmes/psychopath-night ]psychopath test[/url]
Cant really say its handy to know - but may get you out if shopping if nothing else 'sorry dear I cant possibly go shopping as it will set of my inner psychopath'
No idea if I am.
However I'mgoing to hunt you down adjustable wench and do you immense harm.
I now need a new tablet, the link wouldnt work trying to tap the start test, even taking a hammer to it wouldn't work, throwing it across the room and stamping on it seems to have been its death knell, as it will be yours 😈
Nope, I'm quite normal
YOUR
SCORE 52%
Though your conscience is in the right place you also have a pragmatic streak and generally aren’t afraid to do your own dirty work! You’re no shrinking violet - but no daredevil either. You generally have little trouble seeing things from another person’s perspective but, at the same time, are no pushover. ‘Everything in moderation – including moderation’ might sum up your approach to life.
27%
Synopsis: You are a wimp.
that is the wonderful cycle 'facilitity' at colwyn bay prom is it not yunky--don't tell me there is another like it somewhere else.....oh and yeah 1 in a 100 is the estimated density of such folk 😉
33%
I'm a lovely person. No really.
70%
A not very psychopathic 24%
same as cheesy, 2/3rds psycho.
I think that explains a few things.
Should I be worried at 83%?
Nope...
You are warm and empathic with a heightened awareness of social responsibility and a strong sense of conscience. You like to carefully weigh up the pros and cons of a situation before you act and are generally averse to taking risks. You are very much a ‘people person’ and dislike conflict. ‘Do unto others…’ are your watchwords. But, although you avoid hurting others, those residing at the higher end of the psychopathic spectrum might not be as considerate, so stay vigilant to avoid being hurt unnecessarily.
😕 Omg, boring bastard..
55% for me - a vast improvement since my stay at the farm
That pic was the first thing that google threw up when I searched cyclepaths rudebwoy
s'ok khani. We all knew you were a softy liberal wet drip anyway. 😉
You lot are a bunch of nutters..
It explains a lot...
42%
I do my own dirty work, and I'm no push over, but I'm empathic ( whatever that means) and everything in moderation is my motto apparently.
"I have to return some video tapes"
82%
Pity, I really wanted to run around in the dark shouting 'I can smell your chips'.
Oops double post
91%, but I think it's because I haven't had my morning coffee...
Pffft, Those getting high marks are just wannabes, no true psychopath would give [s]myself[/s]themselves away in a test obviously designed to ensnare them.
Watch out - 70% - and free from restraints today 😉
I'm actually quite disappointed not to get higher than 33%...
30% - Apparently I'm a big softy who's going to get ****ed over by everyone.
Cosmic!
24%
same text as khani
So it seems being level headed and confident makes you 70% Psycho
Ok the **** the consequences attitude might sway it a little. Good job I like small animals.
82%
but i doubt that i managed to answer everything truthfully
Imagine being this guy, he accidentally discovered that his brain is wired in the same way as psychopaths! [url= https://www.google.co.uk/search?q=James+Fallon&oq=James+Fallon ]https://www.google.co.uk/search?q=James+Fallon&oq=James+Fallon[/url]
50% bang on.. what the hell does that mean??
"Though your conscience is in the right place you also have a pragmatic streak and generally aren’t afraid to do your own dirty work! You’re no shrinking violet - but no daredevil either. You generally have little trouble seeing things from another person’s perspective but, at the same time, are no pushover. ‘Everything in moderation – including moderation’ might sum up your approach to life."
Oh, oh I see....... 🙄
Damn only 6% , i know ill watch Silence of the lambs followed by Bates Motel see if i can pick up some tips.
It's a shame the test didn't include some questions on political orientation,
Non psycho = left wing wishy washy liberal?
Psycho = right wing swivel eyed loon?
I wonder...
76%
ANYONE HAVE A ****ING PROBLEM WITH THAT..
76%
ANYONE HAVE A **** PROBLEM WITH THAT..
No. But then I got the same score. [b][i]You[/i][/b] got a problem with that?
i was 61%
Seems quite fitting i think.
(I am finding it hard to empathise with you Dales rider . . . .)
[b]21%[/b]
You are [s]warm[/s] and [s]empathic[/s] with a heightened awareness of social responsibility and a strong sense of conscience. You like to carefully weigh up the pros and cons of a situation before you act and are generally averse to taking risks. You are very much a ‘[s]people person[/s]’ and dislike conflict. ‘Do unto others…’ are your watchwords. But, although you avoid hurting others, those residing at the higher end of the psychopathic spectrum might not be as considerate, so stay vigilant to avoid being hurt unnecessarily.
The bits I've struck through are the bits that I think really don't describe me at all.
15% me. I think that makes me the least psychopathic person on here so far.
You all need help.
70%
You can play hardball with the best of them! You know what you want and are not afraid to go for it – even if it means bending the rules occasionally and putting a few noses out of joint on the way. Nothing fazes you. You are decisive, self-confident and pretty much up for anything. You are a ‘means-to-an-end’ person. For you, it’s not necessarily a matter of right or wrong, but of what gets the job done. ‘Bring it on’ is your mantra, but to help those around you keep their heads, you should learn some tricks to help you temper your self-satisfying tendencies...
That's not bad, is it? I mean, not really bad?
Er,, that's bad, that's really really baaaaad...
You'll know if you have a psychopath in your midst, their games and lack of consideration (whilst simultaneously appearing to be unaware of the damage they're causing) are breathtaking.
They're usually the person that everyone is really angry with (because they've been repeatedly screwed over), and no-one can understand why nothing's been done about them... the reason being the people in authority are as screwed over by their manipulations as the rest of us/scared of the consequences if they do stand up to them.
It's not actually a very amusing experience...
This is an eye-opening read...
[url= http://www.amazon.co.uk/Without-Conscience-Disturbing-World-Psychopaths/dp/1572304510/ref=sr_1_1?ie=UTF8&qid=1386757188&sr=8-1&keywords=without+conscience ]Robert Hare[/url]
55%
As with most things, bloody average.
30% pfft
Apparently I'm in with the Guardian reading bunny lovers 🙁
Later this week I'm going to send an hour on the phone with a psychologist to go through some recent psychometric test results.
I'll get the assessment then....
EDIT: oh, and given the ratio of psychopaths to non-psychopaths is somewhere between 1:100 to 1:150, have a quick think about the number of people in your workplace, and figure out the rough average.
I reckon we've got 15-20 here. And I'm pretty sure my boss is one of them....
83%
But then Mother answered for me
Sorry, didn't have time to do the quiz, been busy dissolving my colleagues in battery acid after they pushed in front of me in the canteen queue............
Knowing your line of work, I'd expect them to be over represented 🙂
Fair point 🙂
I'm going to buy some flowers and fluffy kittens to compensate for my high score.
And then eat them.... 😈
uselesshippy - MemberI'm going to buy some flowers and fluffy kittens to compensate for my high score.
Good name buddy!
I'm 27% apparently I need to make sure I don't get taken advantage of...but that's why I'm on PoF in the first place. 😆
I can highly recommend the psychopath test by Jon ronson , a really good read . If your worried about being a psychopath it means you are not one
Allegedly anyone who scores over 65% in that test is cheating on their partner.
48%
i wonder how the scores would be different if they'd included the questions:
'could you kill someone if you knew you could get away with it?'
and
'do you think you would you enjoy it?'
I have a criminal client up for something really serious . Just for fun I and a collegue ran through the Hare's checklist he scored 36 out of 40 the worry point is 20 and over . We then got a lad we work with to do a "proper" graded one with his own answers . I was getting worried as we did it as lots of his honest and reasoned answers seemed to be going in a certain direction . The print out was essentially " you are not a psychopath but you may benefit from treatment you should seek help and take this print out with you"
70% explains a lot,and yes I did get away with it......
Same text as Edlong
27% - Disappointed, I liked Patrick Bateman.
67%
I'd #### you over but feel bad about it afterwards.
Sorry
30% here
that puts 7% below the average guardian reader
i need to hug my bunny wabbit
88% that's not too bad surely? 😯
61%...should i be worried!?....pfffft...nope!!!
Got all the way to the end, pressed next and nothing.
Mother f*?&^%$£%^$%^&^%$£%^$%$£%^$£%^%$£"$%^&%$££$%^%%$£$%^%$£%^$£"$%^%$£"$%$£%^$%^$£%^$£$%^$£$%^$£$%^$%$££%^$%%^$%%$%^%£%£$^&^$%£$^£$^%$%£^$%£$"£^%^£$%"££^£$%"£^$^£$"£%£^%£$£%£^^$£^£$%
breathe
and relax.
27% seems to be a very popular score. Not totally convinced about being a "people person" or having lots of empathy though.
I thought research has revealed psychos can mimic empathy but dont actually feel any.
58% for me, still exhibiting too much empathy which is surprising given work this year!
36% 😈
I am right. You are wrong.
36% too.
67%
Off to masturbate myself with a cheese grater for scoring so low.
Also 27%.
i think someone of my colleagues may doubt my empathy skills though. Apparantly they're not all lizard people.....
55%
I'll eat your legs. Then drive you home.
33% here.
I am a wet hen.
36%
So 3% less of a wet hen than Rusty ^^
I'm worried that I'm scoring higher than the other bleeding heart liberals with whom I'd associate and am on a par with The Malverncestershire Sasquatch. 😐
I thought about shopping in Ikea, tried it again and it went up to 39%. 😐
Still not the 'Evil Genius' I always aspired to be.
Tomorrow, I'm going to go to Tesco and deliberately drop a packet of crackers.
I might even poke a finger through a custard doughnut.
Go me, destroyer of worlds.
Steady on.. 😯
24 %
Sums me up on STW perfectly I feel 😉
If you like piranhas, read the financial times and listen to metal you are a psycho - wow Channel 4 have really surpassed themselves.
Almost as daft as passing Embarrassing Bodies off as educational as opposed to a freak show.
52% and happy to kick asses when necessary (it seems)
Are all these low % you quote for real?
I did the test quickly to see what sort of questions were asked. I planned to do it again to get a really high and then a really low score to show how rubbish the test was. I got 88% first go with honest answers and I am a nice guy.
I reckon I could fake the answers to drop another 20-30% but how do you get below 50% without really choosing your answers to do it?
That kind of test is pointless, unless you're told you're doing it for some other reason.
