Any plumbrs in the ...
[Closed] Any plumbrs in the house?
Is replacing a thermistor on a Chaffoteaux & Maury boiler a DIY job? The emergency plumbers have been round in the past and it seems to be a 5 minute job. It involves draining down the boiler and replacing the part (for which I have the number) and I have the instructions.
Otherwise I'm thinking of buying the part locally adn calling a certified plumber.
It doesn't involve going anywhere near the gas but just wondered whether I should just do it. Emergency plumbers won't come out as currently its an intermittent fault and it takes them 3 days to order the part alone, thats after 2 days to come and confirm that the hot water is not working.
Posted : 11/04/2012 9:29 am
Don't ask here; go and ask on DIYnot.com
Posted : 11/04/2012 1:20 pm
The thing I have found with those forums is that they will tell you it's not a DIY job and that you need to consult a tradesman immediately or they will go one further and ask that you consult building control as it's possibly notifiable under building regs Part J or some jazz
Edit: If you have the Destructions and can get the part and assuming it's not part of the gas fittings - go for it.
Posted : 11/04/2012 1:23 pm
 Bear
or involves removing anything like a case which could be part of combustion chamber?
Posted : 11/04/2012 2:37 pm
