(Another) Xbox 360 ...
[Closed] (Another) Xbox 360 question - "getting online"
Got a Xbox this week...
Now, I brought my wireless modem router downstairs and plugged the Xbox in wired up and connected to Xbox Live yesterday to see how it all works but the router is needed upstairs because the PC has no wifi on it.
I obviously don't want to have to keep doing this so IS the official Xbox wifi adapter (I've seen it for £39 in one place) the cheapest/best way to get it online? Another alternative is to put router downstairs and wifi the PC but although I have built PCs in the past (ie. I know how to do it) don't want to risk invalidating its still-active guarantee by opening it up.
I notice there is a new adapter coming out next week (according to play.com) should I wait for that?
TIA for any info, as always.
Posted : 21/11/2009 10:55 am
Hard wire it back down to the XBox?
Posted : 21/11/2009 11:01 am
Funnily enough I *do* have a 30m ethernet cable from when I first got my PS2 online back in the day but SWMBO would certainly baulk at having a cable running all the way from the front bedroom to the lounge!!
Posted : 21/11/2009 11:04 am
Do it properly
Posted : 21/11/2009 11:09 am
That is my intention. I will edit my original post if I am still able to include the caveat that I don't want to be drilling or lifting carpets...
[edit]16 mins, too late. Thanks anyway.[/edit]
Posted : 21/11/2009 11:12 am
You don't need to there is ways of using other wifi adapters but if you can get the official one for £39 then take the plunge. I'd not bother with cable connection if it such a hassle to do for little benefit.
Posted : 21/11/2009 11:14 am
Powerline, something like these [url= http://www.ebuyer.com/product/150599 ]http://www.ebuyer.com/product/150599[/url]. Networking through the mains. Plug into a socket by the router and connect the ethernet cable between router and powerline. Do the same by the xbox. easy peasy.
More reliable than wifi, and faster. Might even be able to stream HD video from PC to TV.
Cor vinnyeh, that truly does sound like electrickery... It's not April 1st though is it?? I don't have to install it with a left-handed screwdriver or anything?! 😯
I will look into that, I like the sound of it!!
Posted : 21/11/2009 11:17 am
Ah - I thought you wanted cheap?
Anyway another Homeplug starter kit here
http://maplin.co.uk/Module.aspx?ModuleNo=98007&DOY=21m11
Posted : 21/11/2009 11:26 am
You can wi-fi the PC with a dongle that fits in a usb slot,no need to open the case.The Router manufacturer probably does a specific one,but any generic will do,then wire in the X-box.The dongle should only be about £10-12,like this one. http://www.cclonline.com/product-info.asp?product_id=31904&category_id=865&manufacturer_id=0&tid=ew-7711utn
Ian
P.S. I know this works,cos that's how I networked the 2 PCs and Xbox,when son had one.
Posted : 21/11/2009 11:29 am
Cheers uplink, just been scouring the intertron and seems like the powerline stuff, while interesting, will be significantly dearer than the 39 quid adapter when all's told... May come back to that in a future life.
May be moving in the next year too, hence further reluctance to drill and make permanent any fittings.
Posted : 21/11/2009 11:30 am
That thought has crossed my mind Ian - I used to have one though and found it to be tempramental at best. Do they actually work??
Posted : 21/11/2009 11:37 am
I've had one fail on me about 3 years ago,but no probs since.I've got an old one lying about you can have for nowt,as I upgraded from g to n recently,email me on iscarfe at lineone dot net if you want it.
Posted : 21/11/2009 11:41 am
You are a scholar and a gent sir.
I may do that, however I may equally get very impatient today and go and buy one and see if it works... 😳
Will let you know.
Posted : 21/11/2009 11:44 am
No probs.
Ian
Posted : 21/11/2009 11:47 am
You know I said I may get impatient? Well in the 49 mins since I posted that I've been to PC World, bought a [url= http://www.pcworld.co.uk/martprd/product/seo/369188 ]£17 Belkin adapter[/url] and (so far anyway!!) it is working great on the PC so can plug the XBox in downstairs... Thanks all for suggestions.
Posted : 21/11/2009 12:37 pm
