Another IT Question...
[Closed] Another IT Question - How To Move My Documents from C Drive to D Drive?
as the above states - I have 2 separate drives on the laptop and want to move my documents from the c drive which is full to the d drive, which isn't
cheers
Posted : 10/10/2009 10:38 am
Can't you just physically create the new drive & copy everything across?
Posted : 10/10/2009 10:41 am
uplink - you need to explain in more detail! sorry!
Posted : 10/10/2009 10:42 am
From MS
Change the Default Location of the My Documents Folder
To change the default location of the My Documents folder, follow these steps:
1. Click Start, and then point to My Documents.
2. Right-click My Documents, and then click Properties.
3. Click the Target tab.
4. In the Target box, do one of the following:
* Type the path to the folder location that you want, and then click OK. For example, D:\My Stuff.
If the folder does not exist, the Create Message dialog box is displayed. Click Yes to create the folder, and then click OK.
-or-
* Click Move, click the folder in which to store your documents, and then click OK twice.
If you need to create a new folder, click Make New Folder. Type a name for the folder, and then click OK twice.
5. In the Move Documents box, click Yes to move your documents to the new location, or click No to leave your documents in the original location.
Posted : 10/10/2009 10:43 am
uplink - excellent, just what I need , will try now ๐Ÿ™‚
Posted : 10/10/2009 10:45 am
