We have a fusebox with traditional fuses, ie bits of wire. The kitchen is on a separate circuit and that fusebox has circuit breakers. These look to be plugged in just like fuses, but obviously are easier to reset if they blow.
Question...is it possible to remove the wire type fuses and just plug in circuit breaker type fuses of the appropriate value, or is there more to it than that?
It's possible if you have a Wylex board, which many rewireables are. You probably need these:
[url= http://www.tlc-direct.co.uk/Main_Index/Consumer_Units_Index/Wylex_Standard_Range/index.html ]Plug-in MCBs[/url]
You can get plug in replacements, but you may need to replace the plastic covers into which they connect (these are supplied with the plug in resettable fuses). An easy 5 minute job with an electrician's screwdriver and AFTER you turn off the main breaker. Always employ a qualified electrician if you are in any doubt.
As spongebob said but
But Circuit Breakers do not make your house garenteed safe, if you have had fuse blowing issues in the past there is anothere issue????
Just because your lights go on and off everthing may still not be alright
if you cant afford to replace the whole thing, they are safer...
WHat sizes do you need? I have loads of old ones i could maybe sell you for alot less than that - eg postage plus a beer.
lyons - Member
Not if you cannot meet the disconnection times!!!!!
As above.
Sometimes the lid covering the rewireable fuses wont fit back when you replace with MCBs. Might or might not be a problem.
Think only Wylex are available, old MEM is all used up I think.
If they say Proteus I think that's the same as Wylex.
Must stop saying I think.
lyons - Memberif you cant afford to replace the whole thing, they are safer...
Hi thanks for that. The fusebox is a Wylex, though several years old. I need 2 each of 5, 15 & 30 plus the plug in covers. Not worried about the fuse cover not going back on - the kitchen circuit box doesn't have a cover and that works OK. mail me if you want to discuss. Cheers.
