Ankle Surgery
[Closed] Ankle Surgery
Anyone on here had surgery for an unstable ankle? Ligament repair i suppose?
Was it a success and how long off your feet?
Posted : 21/04/2022 9:48 pm
 ton
yes mate, i had a ankle fusion 5 or so years ago.
involves chopping the bottom or one bone off and the top of another. a metal plate is bolted to both bones with a small gap. then new bone fills the gap to make a whole solid joint.
it worked perfectly.
i was bed ridden for a week. then 12 weeks of zero weight bearing, then a support boot for a month.
i did my physio very strictly. did what they told me to do. ankle is spot on now, apart fron no bend in it. but i would have it done again tomorrow no worries.
go for it. be strict and good luck with the outcome.
Posted : 21/04/2022 10:00 pm
Posted : 21/04/2022 10:31 pm
World of difference between an ATFL graft repair and an ankle fusion gents.
Posted : 21/04/2022 10:41 pm
Think mine is potentially an ATFL graft
Posted : 21/04/2022 10:48 pm
Sounds likely if instability is the main issue, presumably following a bad sprain when you tore your ATFL? Fusion used to treat end stage degeneration where a joint replacement isn’t wanted/likely to work.
Posted : 21/04/2022 10:56 pm
Also a world of difference between ankle fusions depending on why they are carried out. Mine has been less cheerful than Ton's although is relatively stable now and deteriorating slower than the last three attempts.
Posted : 21/04/2022 10:59 pm
 ton
should have said, mine started in 1990 with a ankle ligament repair. this did not work, and arthritis took hold. hence the fusion.
Posted : 21/04/2022 11:00 pm
Multiple bad sprains, it now very unstable.. if i am going to have it done i need to understand how much time before back to normalish activity
Have you seen an orthopod yet or still at the GP referral stage?
Posted : 21/04/2022 11:05 pm
Gp land at the moment, i can live with it and use an aircast ankle brace when working on rough ground but it will need something at some point
Posted : 21/04/2022 11:16 pm
I’d suggest you need an ortho referral, you can then talk though the options with them and likely recovery period - as this will be influenced by surgical technique used, patient factors etc etc.
Posted : 21/04/2022 11:45 pm
