android pc for netf...
[Closed] android pc for netflix & iplayer
 Olly
Getting pretty hacked off with the fan noise on my 360 while watching iPlayer and Netflix etc. That and having to have a gold account. I figure a n android based solid state pc would be able to run the native apps just fine. Ideally I want it to be plugged into am HDMI monitor, stereo jack out, and a wired ethernet connection. Any onecare to share?
Posted : 25/10/2013 10:24 pm
You can do domething similar with a raspberry pi. IPlayer is easy, Netflix needs another computer somewhere on your network to stream from aiui.
Posted : 26/10/2013 6:51 am
Ive been toying with doing the same - although I do use my 360 as a media extender from my W7 PC. I dont have a gold subscription.
However Im going to hold out for a google chromecast. There are going to be limitations, but if Im hoping developers will be able to get it to stream from a network with some kind of app, although that wont be possible form the beginning.
Posted : 26/10/2013 7:19 am
Loads of cheap ones from our friends in china... [url] http://www.aliexpress.com/wholesale?SearchText=android+mini+pc&catId=0&initiative_id=AS_20131025230349 [/url]
I have used my pi in the past as a media pc but it cannot come close to a quad core and android. You can pick one up for peanuts with a remote control or mini keyboard. Well worth a punt for the money.
Posted : 26/10/2013 8:08 am
For straight Netflix a little Roku box does for me. Works exactly as it should.
Has iPlayer also.
The Roku RT is about 8cm square and completely silent.
Cheap now at £35 I think and the new versions are out also.
Posted : 26/10/2013 8:31 am
Will a roku stream media files from the network as well danny?
Stoner B
Posted : 26/10/2013 9:11 am
Not directly but you can set up what Roku call a 'Private Channel' and stream that way.
Plenty of info on the web - have a read and see if it is something you want to fiddle with.
As a straight iPlayer/Netflix solution it is perfect - less so if you want to stream media around your own network.
Danny B
Posted : 26/10/2013 9:36 am
thanks, will go and read up.
Posted : 26/10/2013 9:46 am
Just as a comparison an Apple TV box does all that, solid state, hdmi out, wifi or ethernet in. I believe one reason the old Apple TV2 models sell for double new price (ie £200 vs £100) is you can hack them to work with android/non Apple streaming. You can also setup a mac mini with tv as main screen. Clearly neither are android and mac mini would be avery expensive solution even used but it would be a fully fledged computer and media library.
Posted : 26/10/2013 10:09 am
 Olly
Im likely to build up a steambox for the new generation of gaming (they couldnt pay me to fork out for a XBone) but building a little low power solidstate jobby into the same case could be cool, Boot into the steam OS for proper Games, boot to android for silent running film watching/casual gaming. I wonder if one could do this with a certain amount of overlap of parts.
Posted : 27/10/2013 4:58 pm
I just got one of these for £50 and plugged it in to my router to replace my noisy PS3;
Netfix and Iplayer work well and a HDD plugged into the USB port means I can watch MP4's etc.
[url= http://bit.ly/18ZiPbI ]Sony S1100 Blu Ray [/url]
Posted : 27/10/2013 7:26 pm
