Alloy wheel balance...
[Closed] Alloy wheel balance weights
 stox
Ok I accept this May be somewhat trivial to some but I've had a new tyre fitted to the car this evening and when I've got home I've noticed that the guy has put the balance weights on the outside edge of the wheel so they are VERY noticeable.
The wheels have been recently refurbished ( he know this) so I'm a bit pee'd at how bad this looks.
Question is, does it matter if the weights are further in ? ie has the guy been lazy and just stuck them on without giving it a second thought?
Thinking of going back tomorrow . don't want to look like a moaning bugger but I'd like to see if they van be moved further back out of sight
Posted : 30/10/2013 7:08 pm
Not unreasonable at all - I can only imagine the guy had a momentary lapse, to put them on the outside...
Posted : 30/10/2013 7:30 pm
you can balance the on the inner no problem.
Posted : 30/10/2013 7:34 pm
I always specify adhesive weights on the inside.
Posted : 30/10/2013 10:20 pm
On a steel wheel acceptable on an alloy adhesive weights only and on the inside
Posted : 30/10/2013 10:24 pm
 stox
They are on the inside....just not far enough in for me.
I've taken a pic....I'd really have liked these to be further in out of sight
Posted : 30/10/2013 10:26 pm
what brand tyre is it?
Posted : 30/10/2013 10:30 pm
So the outside edge of the inner wheel then. That's where they always go as far as I know and if you wanted them 'hidden' you should have asked.
Posted : 30/10/2013 10:33 pm
 JAG
The weights in the picture are exactly where they're supposed to be - Sorry.
I design brakes for a large VM and we check the wheel weight position to make sure it clears the brakes - what you're showing in your picture is just where they're supposed to go.
HOWEVER - he could have hidden them behind a spoke in the wheel design. Maybe go back tomorrow and ask him to re-do-it. He will probably charge for it though ๐Ÿ™‚
Posted : 30/10/2013 10:38 pm
Pardon my irnorance but how can he hide it behind a spoke if the wheels out of balance between two spokes then surely the weight has to go between the spokes not behind one.
Posted : 30/10/2013 10:44 pm
How could he have put them behind a spoke? Surely if they're for balancing the wheel they have to go in the position shown.
the balancing machine will have several modes, starting with the steel wheel one for knock on weights with the weights furthest apart, then for alloys, various positions depending on the style of the wheel, ending up with just one weight in the middle, using stick on weights.
i'd leave it myself, doesn't look too bad, if the paint has only just been done peeling the old weight off will probably pull the new paint with it because if wont have hardened yet, and it wont be as good as factory paint anyway.
i always put a bit of silver gaffa tape on the weights as a belts a braces type of thing
Posted : 30/10/2013 10:45 pm
I'd be more worried about the blemishes in the new paint job personally ๐Ÿ˜‰
Posted : 30/10/2013 11:05 pm
oh to have such trivial concerns...
Posted : 30/10/2013 11:27 pm
From your original description I thought they had fitted the clip on rim-weights. I don't think its an issue, though I think the weights on my car are a bit further inboard, but you can still see them - you've not asked them to align the tyre brand with the valve have you? I really don't think anyone but you will notice.
Posted : 30/10/2013 11:31 pm
Quite a few weights there. Im wondering whether the tyrehas been fitted correctly. By this I mean there is usually a yellow dot that should be oppostie the valve. This is because the tyre is manufactured with a little more mass where said yellow dot is to counteract the weight of the valve
Posted : 30/10/2013 11:33 pm
With winter coming they'll soon be covered in shit anyway..real 1st world problem.
Posted : 31/10/2013 11:26 am
you say that stu - but in the real world that varys from manufacturer to manufacturer.
some say the dot signifys the lightest spot - others the heaviest .
and then it depends wether the were fitted to weight or uniformity matching.
Posted : 31/10/2013 11:42 am
